HDD drive greyed out in Disc management
  • 6BW6
    • Jan 2015
    • 55
    Got a Satta HDD showing in 'My computer' HDD (D) when trying to format it say's 'insert disk'.
    In Disk management, Drive D is my disk 1 and all greyed out - no media! Using CMD and Diskpart, it won't let me do anything .... maybe I'm doing something wrong here. I did have a disk like this some while ago and managed to get it running - but not this time.
    Any advice please? Thanks, Dave
  • pecrie
    • Nov 2011
    • 182
    Re: HDD drive greyed out in Disc management
    Hi ,
    Normally in Windows the disk on which the OS is installed is the Disk 0 (zero).And it is the C: drive.
    You are talking about Disk D: and it is Disk 1 - to me it looks like the DVD Rom drive.
    And yes , you need to insert a cd or dvd to play or look at the content.
    So , all looks good to me ...
    Oh , forgot to ask what OS is installed and if you have more than 1 HDD or more than 1 partition
    • 6BW6
      • Jan 2015
      • 55
      Re: HDD drive greyed out in Disc management (Sorted)
      it sorted thanks, right just after I'd posted.
      Ah, sorry Win 7 pro. x64 I didn't mention, clicking on the drive it kept telling me to insert a disc.... Oh no crying out loud, the penny just dropped it meant a CD or DVD disk of course it did
      I tried always, now I cured the same problem moons ago using Diskpart but can't remember how.
      All I did was lob it on a multi socket converter adapter with a USB out onto a Acer note Aspire pad, this runs Win 7 home x32 bit.... and it worked, this Acer pad is slower than a 90 year old snail - 'the slowest computer in the West'. I transferred it back the desktop and did the rest.
      The thing was thinking it was a CD...! If you hadn't had said I still wouldn't have known, thanks. Dave
      • madura2010
        DAY11AM6E0 hard disk drive and optical disk drive not detected
        by madura2010
        Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
        i checked the connectivity of ribbon=good communication with hard and motherboard
        changed hard disk and checked=3f0 error persist
        sata power=+5v available
        Then checked data capacitors=all good
        Then checked data lines path connectivity to pch=all good
        reflashed...
        03-12-2023, 09:09 AM
      • steveoski
        PS4 Launch Model Disk Drive Issue (disc drive no power won’t accept discs)
        by steveoski
        Hey guys, so I have a weird one. I have been working on PlayStation 4 since they come out. I have fixed almost everything that hasn't required BGA soldering. Just a little background.
        Now this particular PS4 had a broken HDMI port. It was replaced and it works perfectly. Upon reassemble the disc drive stopped taking in discs. Now I have seen this before and it has ALWAYS been the BD drive daughter board or the BD drive itself. I first replaced the BD Daughter board to see if the drive would start accepting discs before I started soldering the chip over to a new donor board. Still...
        02-13-2019, 10:15 PM
      • federalhouse
        **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
        by federalhouse
        I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
        **Background:**
        I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
        **What I've Tried So Far:**
        1. I accessed
        08-01-2024, 07:03 PM
      • reformatt
        Intel iMacs, 3rd party SSD failures and Fusion setups
        by reformatt
        I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
        As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
        So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
        12-18-2024, 10:34 PM
      • perfm2
        HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
        by perfm2
        So I've worked on dozens of HP and Dell laptops and have never encountered this before.
        Steps taken in my usual process.
        Reset security settings in the BIOS
        Ensure existing HD comes up into the OS
        Shut down the laptop and disconnected the main battery
        Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
        Replace battery connector and close up the laptop
        Insert my USB drive with my Windows 10 image I've...
        03-21-2023, 08:45 PM
