Hi guys!
I've got some hardtimes understand a few things. BadCaps guys here always recommend to replace the failing caps with better quality ones and of course, with the same attributes or above, such as more uF and voltage...I am to show the opposite in this thread and I'd like to ask for your clarification/approval.
Ya'll definitely know what the Abit VP6 looks like - 2 FC-PGAs, SDR, AGP...
So I have these 6 of them
(I just love this one), including a one that has never been used and still has those Jackon caps (what a rare)...the other 5 have been already recapped - but differently
See this:
On this picture, I show the original one - the circled caps are the ones that have been replaced. I picked one of those 5 which behaves the best (and stable). And now we begin:
Red (for CPU & RAM & AGP): 1500uF 6.3v replaced by 2200uF 6.3v
Green (I guess for chipset): 1000uF 16v replaced by 2200uF 6.3v (!!!)
Purple (I guess for AGP & chipset): 1000uF 16V replaced by 1000uF 16v (better quality)
I am particularly concerned with the green couple (what is it for anyway?) and that's why I'm referring to the tradition of not replacing with lower attributes. I'm asking if this could be done and if it's okay...but partially, I have the answers on my hand right now:
1. It boots and runs
2. Since it is a board for PIIIs, I consider the PIII as the older CPU (correct me if wrong) which uses the 5v & 3.3v rails - there is no extra connector for 12v rail, which is used for the CPU (for example in P4 CPUs)
3. It behaves even more stable in OC'd status
I have my machine fully loaded (USB2.0, LAN, sound (PCI) and video card (AGP) inserted + HDD with DVD + some fans), 2x 1GHz @ 1245Mhz OC'd at 166MHz FSB, 41.5MHz PCI and 83MHz AGP. The SDR are Tonicom PC166 single-sided 128MB modules, so it's OK. I tried this config for about 1 hour playing Rainbow Six LV2 and no issues. The Vcore is at 1.85v and Vcc3.3 at 3.5v (but in real its 3.4v, if I raise it to the 3.6v, it's gonna be 3.5v - in Everest). Everest shows all basic rails OK but the 5v is quite lower than should be. When I boot into winxp and run everest, it shows 4.80-85v in idle, stress test lowers it to 4.61v - that doesn't seem right. The PS is Fortron Blue Storm II 500W. Any thoughts?
So what do you think? Is it ok in this board to leave it with those 6.3v instead of 16v? I suppose I'm right that PIIIs have no need to have 16v capacitors, but doesn't the board need those 16 volts? Please explain me this.
Just for fun: on another board, there are the 16v 1500uF replaced by better quality 16v 1500uF, but the system won't run stable unless I remove the LAN NIC and USB add-on card, though tested this only for 15 minutes, will try again. But the 6.3v 2200uF seem to be more stable - does this mean that higher capacitance equals to better stability?
Sorry not providing the brand of the caps, will post later.
See this:
