SSD Data recovery from KINGSTON HYPERX 3k
  • Roli
    • Jun 2010
    • 42
    Hello , my 9 year old ssd just died yesterday , so basically i turned on the computer , and accesed google chrome then everything froze , i restarted pc , again accesed chrome but it crashed , i managed to remove chrome , and after that the computer again crashed , after another restart the pc would hang at the windows loading screen, thats when i realised that or the pc is infected with some virus , or the ssd failed , then i tried to acces the ssd with a usb adapter , it will recognize in my computer only 1 partition but i cannot acces it , no matter what recovery aplication i try ( easus etc ... ) the drive cannot be accesed .
    Tried also an app called DMDE , it finds the ssd , but it gives me only errors
    Also i want to point that everytime my pc started , hdd sentinel started and stated the ssd-s life at 89%...
    Maybe someone knows a method for example putting the ssd in safe mode by shorting 2 pins or something to recovery data ?
    I atached a picture of the inside of ssd .
  • Roli
    • Jun 2010
    • 42
    Re: SSD Data recovery from KINGSTON HYPERX 3k
    Managed to recover data succesfully , by connecting it not with adapter but with normal power + sata cable in computer , and using Easus Data recovery ( the newest version ) i could recover everything that i needed , also donno how but windows saw the partitions and i could format the drive .
    • diif
      • Feb 2014
      • 6978
      • England
      Run the toolbox and see what it says. https://www.hyperxgaming.com/en/supp...on-ssd-toolbox
      Also take it as a warning and and implement a backup strategy.
        • 31281
        9years for flash is impressive, i wouldnt trust one longer than 2-3years before making daily backups and looking to re-purpose it for something less important.
        • volinakis
          Chromebook recovery failed - how to fix it
          by volinakis
          So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
          Finally I found a site where they suggested to try with an older image and ... it worked!
          What I did:
          - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
          09-18-2023, 03:26 PM
        • myth77
          macbook pro a2141 can not make recovery
          by myth77
          So, i dont know almost anything on macs..but this is my nephews so i had to try. Its 16 inch macbook pro from 2019...It all started when he left something on the keyboard when closing the mac and there it was the crack on screen. At first it was like working but later no. After that he told me that it wouldnt power on?...hear fans but nothing..tried like 100 of stuffs but nothing helped.
          So, he bring it to me...first i open it and figured he did also. there was lots of dust i cleaned everything...and started it...the broken screen showed only backlight but nothing on the screen. I...
          06-19-2022, 11:21 AM
        • ugamazing
          820-00850 & 820-01949, No WiFi *In Recovery*
          by ugamazing
          I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
          1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
          2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
          01-25-2023, 05:39 PM
        • alfredposadas09
          cant enter recovery mode lenovo c13 yoga chromebook
          by alfredposadas09
          cant enter recovery mode lenovo c13 yoga chromebook try esc+refresh+power at first scenario i was able to enter recovery mode but it was failing to reinstall os .. i try to change ssd and when i try this i cant enter recovery mode now...
          11-09-2024, 10:09 AM
        • conghuyms
          Macbook air m1 can't access the recovery options by pressing and holding the power button
          by conghuyms
          I have an M1 MacBook Air (A2337) 2020 that came in for water damage and will not turn on. Upon opening it, I saw that the audio board was severely corroded. I disconnected it, and the device started working.
          After that, I dealt with the issues on the audio board by removing the capacitors that were shorted to ground, and the device started working. However, I encountered another problem: I can't access the recovery options by pressing and holding the power button. I'm not sure if it's a hardware issue or if the recovery partition has been lost. Currently, the system's time isn't updating,...
          10-14-2024, 06:43 AM
