How to use Mac OS software in Windows?
  • Ricky Miller
    • Feb 2020
    I want to start using Garageband for my music production but its operating system is macOS and I don't have either MacBook or iPhone. So, I was wondering if it is possible to use Garageband on my Windows system. I cannot afford MacBook right now.
    I used softwares like Audacity previously to create music but now I want to go to the next level and I have heard lots of good reviews about this software.
    Please let me know if it is possible.
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: How to use Mac OS software in Windows?
    [Disclaimer: I know nothing of Mac apps nor OSX]
    I would think you would have to run it in a VM. But, no idea how tolerant OSX is of that approach nor if the app has specific requirements that the VM might not support, cleanly.
    [A VM might carry too much run-time overhead for some "real-time" applications, depending on the power you have available on your hosting system]
    • piernov
      • Jan 2016
      • 4437
      • France
      Simple answer: if you want the Apple experience and Apple software then buy Apple hardware.
      And software planned obsolescence is a whole part of the Apple experience (not just theirs though). If you want to use up-to-date software you need up-to-date hardware. Basically if you need to get work done, always go for a machine that supports the latest release of the operating system (and the next release if we already know what machine it will support).
      It is simply impossible to run macOS applications on Windows itself.
      It is possible to run macOS in a virtual machine but the performances will not be great. Especially, you cannot have video acceleration with the GPU hardware simulated by a virtual machine so the user interface is barely usable. You'd need to use PCIe pass-through with a GPU supported by macOS but that's not necessarily easy to set up and may not work reliably.
      There's also the hackintosh route. But still not the solution if you want to get work done. It may be fun to do, but still a huge waste of time to set up and maintain, and may not be reliable either.
      Note that both those approaches are not allowed according to macOS EULA.
        • 31094
        hackintosh or maybe using Linux - there was a project to run mac soft in Linux but i dont know if it ever got completed.
        • sean121
          • Apr 2020
          Well, Garageband is designed for Mac OS and iOS users but with the help of some emulators like VMWare and iPadian you can successfully run Garageband on your windows.
          Obviously, you won't get the performance as you would with Macbook but you can run it though.
          It will take some technical knowledge to do so. I hope you are familiar with what emulators are? If not then you can take reference.
          There is a well explained article there with explanatory video. Just go through it and follow the steps mentioned there.
            • 31094
            http://www.garagebandforpc.com/
            https://techonation.com/best-garageb...tives-windows/
            • Curious.George
              • Nov 2011
              • 2305
              • Unknown
              I've used FLStudio and Cubase. Both are nice products. Presumably, the OP has some experience with these sorts of tools so will be able to hit the ground running... (otherwise, the learning curve can be a bit steep as things aren't often "obvious")
                • 31094
                are they just "trackers" or is there more to them?
                • Curious.George
                  • Nov 2011
                  • 2305
                  • Unknown
                  Not sure what you mean by "trackers"...
                  You can obviously play the "loops" game with them. And, compose with a virtual keyboard (mapped to a particular instrument or set of instruments). I suspect you can also use a MIDI device (though I don't own any for input).
                  And, can modify existing tracks with effects, ASDR envelopes, etc.
                  I can't comment on how good/bad any of these would be for a "true musician" trying to augment his own performance. But, I've found them "capable" for creating scores from scratch (where you don't have the urgency of "live" interaction).
                  [I also can't comment on how intuitive a musician might find the interface as I can easily adapt to it by viewing it as a "computer interface" (with all of the yuck that normally comes with that).]
                    master hoarder
                    • May 2008
                    • 12175
                    +10
                    I am not a musician myself, but I have tried FL Studio out of interest and it's a nice product, indeed. Garage Band is pretty amateur stuff. It may be "more intuitive", but you will find it lacking in options quickly should you become more serious about music production. FL Studio, on the other hand, is probably not as intuitive (but not any less than any of the other known music production softwares out there.) However, there are a TON of How-to/learning videos on YouTube for using FL Studio. So giving that a try may be easier than setting up a Mac OS on a PC to run Garage Band.
                    Oh, and Audacity is not a music production program - it's a wave editor. Wave editors are used quite often in music production, but not solely for producing/composing. More often, it is used for editing "samples" and "waves" that can then be used in FL Studio.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      Adobe Audition?
                      <--- Badcaps.net Founder
                      Badcaps.net Services:
                      Motherboard Repair Services
                      http://folding.stanford.edu/
                      Team : 49813
                      Join in!!
                      Team Stats
                      • Curious.George
                        • Nov 2011
                        • 2305
                        • Unknown
                        Originally posted by Topcat
                        Adobe Audition?
                        There are a LOT of Windows DAW products. They all, basically, do the same thing. But, have different price points and "goodie bags". The goodies may not be important if you're creating original content. But, if you're trying to synthesize a score from existing loops, more is usually better!
                        [OTOH, unlike visual things that you can quickly review with "thumbnails", it's pretty hard to peruse a collection of audio clips/loops (cuz you have to actually LISTEN to them).]
                        Cubase, FLStudio, Audition, Cakewalk/SONAR, Presonus, Logic Pro X, Avid, etc.
                        It's best to pick one (or two) and hitch your wagon to it/them. While learning one gives you a leg up instead of starting from scratch, on another, its rare for two products to do the same thing in the same way.
                        I despise "demo products" as a way of evaluating software. IMO, the only way to truly get a feel for a product is to use it to do ACTUAL work. Playing with some "examples" hides too many of the details about which you will likely later complain!
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16958
                          FWIW, I use a really old program called "Cool Edit 2000", its great for editing audio files, including MP3. It was very simple to use and very effective. It was bought out by Adobe and eventually became 'Audition'.....which is a typical pita to use.....meaning you need a degree in overkilled gibberish to figure out how to make it do anything....very counter-intuitive...
                          Team : 49813
                          Join in!!
                          Team Stats
                          • Curious.George
                            • Nov 2011
                            • 2305
                            • Unknown
                            Yeah, I ran cool edit pro "a long time ago" (with "loopology"). Modern DAWs are more featureful. VSTi support, track stretching, pitch correction, vocal syncing, Dolby, integration with video editors, autoducking, etc.
                            CEP was good for mixing and applying some effects but it was harder to be a "one man band" using it than more recent DAWs.
                            Of course, the added capability brings with it added interface complexity.
                            And, some of the UI seems like it was designed by folks who never thought about how it SHOULD be used.
                            Adobe tends to be like Apple in thinking THEY have a "way" things should be done. If you live entirely in their ecosystem, then you learn THAT way and all is fine. If, however, you mix and match tools (like I do), then "their way" always seems tedious when moving back and forth from "some other way".
                            • a_p3rson
                              Apple Watch Charging Controller Schematics / Boardview - 820-02601
                              by a_p3rson
                              Hi there,
                              I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                              You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                              This daughterboard uses an interesting...
                              04-21-2025, 11:41 PM
                            • ktmmotocross
                              Apple macbook - How to remove Dynatrace software?
                              by ktmmotocross
                              Hello.
                              Have apple macbook pro that have some controlling software on it Dynatrace. Reinstall not help as this software self install again. So how to remove this software?
                              09-28-2023, 11:05 PM
                            • japlytic
                              DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                              by japlytic
                              In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                              Tried (only with keyboard/mouse connected):
                              • BIOS + database update
                              • Using latest Windows 11 image built with official image creation tool
                              • Previous setup version for Windows 11 installer
                              • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                              • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                              • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                              06-19-2025, 04:59 PM
                            • Topcat
                              The 2025 Operating System Thread
                              by Topcat
                              What OS are you running these days? I am down to 3 Windows workstations and one Windows Server on my LAN, everything that doesn't have a windows-specific need has been moved to Linux. Printing abilities with my large document centers are Linux's kryptonite; the reason for 2 of the Windows machines. The third machine still has Win7 on it, and isn't connected to the outside world. It has tons of software on it I use for diagnostics and updating various hardwares. My main rig is still Win10 Enterprise, so I had to vote Win10 in the poll...but I have overwhelmingly more linux machines than windows...
                              Windows 11
                              29.41%
                              15
                              Windows 10
                              23.53%
                              12
                              Windows 8/8.1 or 7
                              13.73%
                              7
                              Windows Vista (I'm a glutton)
                              0%
                              0
                              Windows XP (I just can't let go!)
                              3.92%
                              2
                              Windows 2000 / ME / 9x (Ok, this one is a funny, maybe!!)
                              0%
                              0
                              Some flavor of Linux (brag on your distro in a post)
                              25.49%
                              13
                              MacOS - OSX (Poor diluted souls!!)
                              3.92%
                              2
                              Google Chrome/chromebox/chromebook
                              0%
                              0
                              What's a PC? (The option for those with a phone stuck in their faces)
                              0%
                              0
                              01-01-2025, 10:19 AM
                            • AppleLover123
                              Acer Aspire A515-52G-53PU crashing during windows installation
                              by AppleLover123
                              Hello Guys,
                              got an Acer here with the problem that when i'm installing windows it just crashes (turns off) and not going back on as soon as i press the power button.
                              I've tried it with different sticks and windows versions and also with windows 10 and 11 but it's the same problem.
                              The only difference is that when i want to install windows 11 it crashes during the installation screen when "getting files ready for installation" at 25% - 30% progress and
                              when i install windows 10 it goes trough until the restart and at "getting devices ready" it...
                              03-08-2025, 05:05 AM
