Obscure power supply replacement suggestions
  • bluto
    • Oct 2007
    • 560
    I need recommendations for replacements for this power supply. It is a Seasonic SSF-160U1. It is 160 watt, open frame and has a 24 pin ATX & 4 pin +12v connector. It needs to fit inside of a 1U server chassis (WatchGuard Firebox firewall). The original is discontinued and I need a source of reliable new replacements. Cost is not really a factor, but ideally the replacements should be less than $150-200 each.
    Any ideas?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Obscure power supply replacement suggestions
    What about an internal ITX PSU? It just looks to be standard ATX plugs.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • R_J
      • 9588
      I think Sunpower makes some, like the PX-6160A1, What about repairng them? or are they just missing from the units
      • bluto
        • Oct 2007
        • 560
        I have considered ITX. I actually purchased one of these to try: https://www.fspgroupusa.com/ecommerc...guru-250w.html
        But it required modifying the modifying the AC input which I would like to avoid. So I thought I would ask here.
        As for repair, that would be nice but there some issues at play. While these are nice power supplies (they even have UCC KY series caps not the usual crap caps), they are covered in glue that is turning conductive and causing them to malfunction. Removing the glue is difficult since the components are tightly packed. And soldering on them is also proving difficult since the PCB seems to have a heavy duty conductive layer that takes a lot of heat to solder unlike run of the mill junk power supplies. The one in in the picture I actually sent in for repair and it took the guy over two months to work on it before sending it back still malfunctioning.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          I have another old watchguard 1U firewall, its cooling solution was just not designed well and the psu failed due to overheating (heat exasperating capacitor failure).
          Yeah this PSU's PCB is a 2-layer board. Ouch. Makes it that much harder to work on.
          • llonen
            • Sep 2014
            • 495
            • hampshire
            You probably just need a decent solder extraction system for working on these boards, I mean not sure what soldering system you are using but through hole plated double sided boards can have quite a high thermal mass. I work on quite a few of these types of boards and with the right soldering system its often easier to remove components to break up and remove glue etc. If you have a lot of these to rework or anticipate such then a decent solder extraction system will pay for itself quickly.
              by sam_sam_sam
              03-31-2024, 02:12 PM
            • Goldenmonkey
              Samsung pn59d530a3f no picture after power supply replacement
              by Goldenmonkey
              My samsung plasma pn59d530a3f recently had a loud pop and stopped working. after opening it up, I found a blown resistor and capacitor on the power supply board. The circuit board was damaged where the resistor connects so I opted to buy a replacement board.
              after installing the replacement power supply, the tv powers up but has no picture. The electronics store I bought the power supply from said the next likely culprit could be the Y Main board.
              Is there a way to test the Y Main board before just buying a replacement? Or if there are other areas I should check?
              04-07-2023, 09:39 AM
              by sam_sam_sam
              07-01-2024, 06:34 AM
            • samoelec
              Trying to understand how to find best replacement cap for old parts.
              by samoelec
              Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
              Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
              The power supply board is exactly the same from this post so I'll just steal it for now.
              I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
              04-01-2024, 03:39 AM
