Multilple Boards and Very HOT SOUTHBRIDGE S
  • darylsutor
    • Jul 2009
    • 8
    Puzzling Hot Southbridge Phenominon...
    I've got two a7n8x deluxe and 1 gigabyte GA-7vAXP board. All setup independently and all suffering from can't hold my finger on the southbridge without burning it. These boards did not used to be this way and are all socket A with rubicon capacitor. Newegg sought after boards and ran very well for many years. The capacitors look mint on all these boards. 1 board is dead and i'm assuming the other 2 will follow shortly. Installed heatsinks and still too hot to handle. All boards have the Nvidia MCP southbridge and when the ran properly, they give me very little reason to upgrade to todays technology.
    Can anyone pinpoint a few a capacitors to replace for this type of problem. I can't see recapping whole boards full of seemingly great rubicons.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Multilple Boards and Very HOT SOUTHBRIDGE S
    Power supply, check the 5vsb on it, it might be too high and is destroying them.
    • darylsutor
      • Jul 2009
      • 8
      Or most likely have I used my boards caps to and beyond the lifecycle of even a good rubycon CAP?
      No sign of failure but if a cap is like a battery... It's time to replace my motherboard Caps?
      • everell
        • Jan 2009
        • 1514
        If you are using the same power supply to test these mother boards, it may be a bad power supply. Read the brand name and model number of the power supply and tell us what you have.
        The 5vsb rail feeds the southbridge chip. Try removing the main 20 pin power supply connector from the mother board. Then measure the voltage between the purple wire and any one of the black wires. Should measure 5 volts. If not ..............................
        Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
        • darylsutor
          • Jul 2009
          • 8
          So according to you, I would then be testing 3 different power supply's and a couple antec's. I may just do what you say. Of course I would have to strongly believe that not one of my power supplies are in spec.
          My power supplies are...
          Antec true power 2.0 480 watt
          Antec Smart Power 350 watt model SL350
          xconnect 600 watt
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            If they are the older antecs with the fujiyuu, I wouldn't be surprised.
            • darylsutor
              • Jul 2009
              • 8
              instead of adding another post i edditted and gave some model info... let me know if you need more and i'm getting ready to test these puppys thanks for the information on how to test the 5v rail i'll get back with my results but I may have to go fetch my meter at work....
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                ya the older smartpowers, truepowers, Neo's and so on had problems with the dreaded fuhjiyuu capacitors in them. The xconnect may also have a high 5vsb.
                As everell said, you just put the positive lead of your dmm on the purple wire on the 20(+4) connector and the negative to any negative, it dosen't matter which negative as they all terminate in the same spot.
                • darylsutor
                  • Jul 2009
                  • 8
                  OK Im excited and have to go get my good meter at work ill post back within 30 min...
                  • darylsutor
                    • Jul 2009
                    • 8
                    OK, I measured all and they vary from as low as 5.09 to 5.17 with the
                    xconnect 600 watt being the highest. I even measured a 4th powersupply that I have running to post here that falls inbetween. Is it possible that with a load on the P.S. these readings would change?
                    Otherwise, these readings are acceptable correct?
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      i have seen many nvidia southbridges that ran to hot for my liking.stuck on a heatsink.
                      i would still open the antec's and look for the evil "F" word.
                      replace any you find.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        or find a delta/seasonic/( other brands; please post) to test with. although a recap would help too.
                        sigpic
                        (Insert witty quote here)
                        • darylsutor
                          • Jul 2009
                          • 8
                          On a side note, I opened another antec 350 watt power supply that i had on the shelf as labeled bad. What a mess that is inside. A cap leaking nightmare.
                          I was hoping someone could tell me if the blue esr tester or please list the one you have that is helpful for testing onboard capacitors. If i'm going to order caps, I want to check the seemingly good rubicons too and get my order done in one shot.
                          • KeriJane
                            Mac Enthusiast
                            • Sep 2008
                            • 681
                            Hi Darlysutor
                            Why, yes the Blue ESR meter does well at testing onboard caps. The caps in the PSU are pretty straightforward (discharge them first!).
                            The Blue ESR meter (or any ESR meter) will test caps on the motherboard for ESR in place with one caveat: If there are multiple caps in parallel (such as the vCore caps very near the CPU socket) the ESR reading will be of all the related caps combined, and very likely an extremely low or even unmeasurable figure.
                            You cannot usually test the caps for Capacitance in place, but ESR is probably more important in this instance.
                            The "Low ESR" and "Ultra Low ESR" caps that you will find in the PSU and motherboard must be replaced with caps of a suitable ESR rating.
                            When you're ordering, it's a good practice to get some extras.
                            Good Luck,
                            Keri
                            PS. Practice on an old PSU first. PSU's are usually way easier to desolder/re-solder than multi-layer motherboards.
                            The More You Learn The Less You Know!
                            • ugamazing
                              Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                              by ugamazing
                              I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                              We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                              12-17-2024, 07:05 PM
                            • ugamazing
                              Apple M1 Boards & Exclamatory Error?
                              by ugamazing
                              We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
                              Has anyone else run into this...
                              02-20-2025, 09:24 AM
                            • ugamazing
                              Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                              by ugamazing
                              I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                              08-31-2022, 07:34 AM
                            • hopkok
                              Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
                              by hopkok
                              Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
                              3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
                              I checked for low resistance on coils, no low resistance.
                              Anyone with same issue like me?
                              Thanks for any help.
                              05-24-2025, 04:21 AM
                            • midnightg35x
                              Panasonic TC-P65S2 SU or SD Boards Bad?
                              by midnightg35x
                              I have a TC-P65S2 that blew an SC board (I had a previous post about some cross references). When I put the repaired SC board in, it worked with the SD and SU boards isolated and SC50 jumped. I reinstalled the SD and SU boards. I did forget to remove the SC50 jumper, but from what I understand about how that jumper works, that should not cause SC board destruction with properly working SC/SD/SU boards. When I turned the TV back on, the SC board blew again. Based on the fact the SC board was working without the SU and SD boards, it at least makes sense that one or both of them is bad.
                              04-22-2019, 05:29 PM
