PC will only start when I clear CMOS through jumper
  • IamPritesh
    • Aug 2017
    • 356
    • India
    I have this dell desktop that runs only when I use jumper to clear cmos. Works fine until shutdown. TO start again, I have to start the process again.
    What could be wrong and how to fix it ?
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: PC will only start when I clear CMOS through jumper
    Does "runs only" mean that without the jumper in place, the computer SHUTS DOWN (i.e., powers itself off)? Or, does it just not boot into the OS properly unless the jumper is in place??
    • IamPritesh
      • Aug 2017
      • 356
      • India
      IF the jumpers are removed or placed in default location it wont start at all on pressing the power button.
      To power on the pc, I have to place the jumper in pin 1 and 2 to clear the bios.
      • Huscarl17
        • Apr 2018
        • 8
        do you reload the defaults using the bios option before you reboot?
        Make & model of the motherboard might help define the problem better
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          If your BIOS supports it, you may also want to "install factory defaults" and then "save current settings AS the default" -- in addition to just putting them in place (i.e., some machines have a "defaults" and a "factory defaults" -- which can be different, as a feature!)
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8188
            Try taking everything off the main board including RAM, CPU, HDD, everything... then reinstall all components.
            • piernov
              • Jan 2016
              • 4436
              • France
              Tried to update the BIOS?
