Issue with DVD-RW drive, needs calibration?
  • TacoLoco
    • May 2019
    • 20
    • mexico
    Hello!
    I have this old 2014 LG, CD DVD-RW Sata drive that stopped reading certain discs, i don't know why or how but suddenly the drive wouldn't recognize any Polaroid dvd-r discs i previously burned with nero or imgburn software.
    The weird thing is that this LG drive can successfully record data in those polaroid dvd's but it can't read them afterwards like if the burning process was a failure but it wasn't, the drive did his job because i could read the discs data anywhere else (other computers, blu-ray players)
    Then i tried with Sony dvd's, it was the same problem, it can't read anything and shows the discs as "blank discs" rdy for recording BUT the drive reads with no problem many of my old phillips or verbatim discs, why is this happening?
    Anyway i've read in many spanish websites that i have to adjust two potentiometers inside the dvd drive, already took apart the dvd drive and yep i can see two little screws one with the C letter and another with the D for dvd i assume. So these websites said CD potentiometer must be 600 ohms' and dvd 700 ohms or bit more but they never tell you why.
    With my multimeter set to 2000 ohm i got 185 for the C screw and then 264 for the D screw, thats way too off compared to 600 or 700 ohms plus the screw for the D (dvd?) doesn't reach 700 ohms it just reaches 670 or something but i couldn't get 700 ohms and if i keep turning the screw it goes back to 0.20, 100, 200 and on.
    Im just wondering if this dvd drive can be saved but im not sure what would happen if i go from 185 to 600 for the C screw and 264 to 670 or something for the D screw.
    ps: and the drive is the problem because i bought 2 different dvd sata drives and all of them work just fine without issues, i even recorded with some of the same polaroid discs with no problems, apologies for the engrish thx in advance!
    • 31142
    Re: Issue with DVD-RW drive, needs calibration?
    the wesite that said 600/700ohms is full of shit,
    you need to set it with a scope.
    if it was just a matter of 600/700ohms, dont you think they would have fitted resistors instead of pots!
    • R_J
      • Jun 2012
      • 9579
      Those two adjustments are for the laser output current, If you turn it up you will just shorten the laser diodes life. Try cleaning the lens first, its often the laser pickup sensor that goes bad and is not as sensitive to reading the disc. spend the $20.00 and replace the whole drive.
      • TacoLoco
        • May 2019
        • 20
        • mexico
        LOL that's what i thought i mean, those websites never explained in detail the reason why you should move the potentiometers to 600 and 700 ohms they just said "that's the number you need to fix it".
        Youtube has many videos with people doing this 600-700 ohms technique even with Xbox and Playstation consoles, anyway yeah np i already bought two drives i just had this one getting dust, btw i tried to restore the original values but lol it's hard those screws are very sensitive so i just managed to get 187 ohms for the C (previously 185) and for the D screw 271 (264 previously).
        • petehall347
          • Jan 2015
          • 4430
          you can up the current a tiny bit to get enough time to sell it on if you are lucky . if you go over a tiny bit most times its game over . still have a box full of ps2.s in bits .
          • jaco2d
            Hisense calibration
            by jaco2d
            Hi i recently purchased a Hisense u7hqtuk TV, there is 2 different version of this set, the UK, Europe one and the America one, i have the UK and Europe version.
            I have searched for calibration for the TV but i can only find it for the America one which has 1000 nits, the version i have has got 600 nits so the calibration settings will not work.
            Has anyone got this TV and managed to get good picture setting for it or can anyone find a link to the calibration settings?
            The picture is good enough but if possible i would like to get the best possible picture settings for the...
            09-20-2023, 12:20 PM
            Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
            The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
            Securing a good thermal interface between...
            10-07-2024, 04:35 AM
          • Prott
            PS5 - long screw damage, via to ground layer short?
            by Prott
            Hello dear Badcappers,
            I came across a PS5 that was longscrewed. The screw went through the HDMI IC (which I replaced + repaired the traces it damaged), however the screw also bend the board and slightly cracked it on the other side. It still seems like it could be fixable though as the area might not have lots of traces going through it (fingers crossed).
            Can somebody, please, measure their board and tell me if my assumption of an inner short between the via and ground layer is correct? These 3 pads have almost no resistance. I would like to make sure those are not some data...
            07-27-2024, 08:54 AM
          • draag de wereld
            ATTEN ST 8800 D calibration ?
            by draag de wereld
            I have an ATTEN ST 8800 D. I tried it out and I have a problem with this machine. When I get the machine at 500°C at 50% airspeed. My motherboards (I tried on several) barely heat up to 180°C. I know how to calibrate the machine, but it can't be a calibration of 300°. Anyone has the same problem with this machine. I know buying cheap is buying expensive but a 300° difference is a rip off.
            02-28-2025, 05:17 AM
          • zman78
            Screw-In Barrel Adapter for LED light array gets really hot?
            by zman78
            Hi All,
            I have an LED Light array that had a built-in AC-DC 24v 45 watt power supply. The power supply failed so I desoldered the LED Light array power input wires from the power supply and then screwed it into barrel connector jack (ends still tinned with the original solder).
            This is the barrel connect or jack https://www.amazon.com/gp/product/B07Q6YMM6F/
            Then I bought an external 24Volt/3Amp power brick (with same size barrel connector output) and plugged it in.
            Everything works fine, except that the screw-in barrel connector gets...
            06-28-2021, 03:35 PM
