another ball bearing liar with a twist
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    a red o ring loose in the bearing cavity?
    btw its a sleeve bearing.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: another ball bearing liar with a twist
    Have to tried taking apart the fan by removing the retaining washer? There might actually be a ball bearing on the other side.
    Label says "ball bearing" without the "s". Technically that means one ball bearing only. Some carefully chosen words by the manufacturer, I guess .
    The red ring, though... that's bad to see it like that. It should be under the retaining washer, not on top of it.
    Otherwise this fan looks allright to use as a case fan.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      this thing has typical end play of the sleeve bearing it is.maybe there is a bb in the other side of the housing.as in 1 ball!
      at least this one has a rubber plug to give it at least a chance of holding the oil i added.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Yeah the rubber plug does make a difference. The ones without it are a mess after you remove the sticker. Oil gets on it and you can put it back on which makes the fan almost useless as it has to be oiled frequently.
        If you actually add oil to that fan above, it's best to take it appart and give some to the ball bearing. Makes worn and noisy ones quiet for a while. Those plastic retaining washers are also really easy to remove with a small screwdriver.
        • Newbie2
          • Sep 2005
          • 885
          Not the best fan available but slightly better than the lower end sleeve bearing fans. It would be a cost effective solution for applications not demanding high reliability in my opinion.
          My gaming PC:
          AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
          ASUS M4A77TD AMD 770 AM3 Motherboard
          PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
          G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
          TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
          WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
          ASUS Xonar DG 5.1 Channel PCI sound card
          Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
          Antec Three Hundred Mid-Tower Case
          Microsoft Windows 10 Pro 64-bit
          Microsoft Windows 7 Ultimate SP1 64-bit
          • gdement
            • Jan 2007
            • 690
            I suppose, but my thinking is that anytime there's a fan, it probably needs to be reliable.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              good one
