Topcat's Dream Service Bench Reborn!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Topcat's Dream Service Bench Reborn!
    ....and last but not least, the CM2000 monitor tester.... This one still worked.
    Full test of all its patterns....
    Circle/crosshatch
    Color Bars
    Color Steps
    Windows
    Text
    Raster
    There were a couple others not shown, they didn't photograph well.
    All the accessories were found.
    My original full collection of Sencore pieces back from the service center days...and a soon-to-be HTPC for the benchtop...since its the same color & size of these machines, it'll fit in well.
    Several of which were never taken out of service in over 20 years! The external power brick for the LC102 died about 8 years ago....so I cobbled one together from a charger from a dead Toshiba laptop until I found a real replacement....but all the rest has been solid during its useful lifetime....the storage rot on a few of the above doesn't count!
    Some of this stuff I bought new (the LC102, PR570, CM2000, SC3100, and VC93)....some came from a defunked shops (VG91, TV92, CVA94, all the vintage Sencore, the bench supplies, and most of the rest).
    That concludes this portion of this little experiment....next is to actually build the bench...and I haven't got that all figured out yet.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Honorable mention for an old Sencore scope I bought cheap on ebay....I don't know what inspired it, but I've started a weird collection of old test equipment to go along with the vintage pieces I already have (not shown)...old test equipment has a majesty & marvelous aura about it....
      Anyway, Sencore PS148 scope, in mint condition with probe.... It seems to work fine....but y'all know me... I had to see what was inside... I opened it up and realized there was an empty tube socket, yet it still seemed to work. I looked through the paperwork that came with it and googled a little, apparently it was a modification which eventually became the "PS148A" version, where a heavier transformer was used and the rectifier tubes were replaced with diodes. This one has had those modifications. This one also included its original glare visor, which is also extremely rare....something that's been pitched in the trash long ago, so for it to still be there on a ~50yr old scope, not bad!!
      Quick test from 110VAC.
      Glowing tubes baby!!!
      Team : 49813
      Join in!!
      Team Stats
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Unexpected pick-up....A cheap ebay score (open bidding for $21.00). Basically a small PC with a dead CMOS battery, so it wouldn't boot....seller didn't have a clue.....so:
        ...yea...a rather unusual piece...I didn't even know this existed till I stumbled upon it.
        2 dead batteries....the onboard is the CMOS, not sure about the other.....but both are dead as farts. The 2 replacement batteries cost me more than I paid for the unit.
        Once I set the paramteres in the BIOS, it would boot and function. The monitor on the right is the test output, the monitor on the left is just a mirror of what's on the internal display.
        The output connector is a standard EVC connector....so for testing, what better than a voodoo3500 VGA dongle....
        Internal HDD with DOS and its proprietary software. I will make a full image of this HDD and store it....I imagine obtaining a copy of this would be near impossible if it ever had to be reinstalled.
        Getting to the nitty-gritty....the dead Varta CMOS battery leaked and damaged the PCB and one of the memory slots.
        Battery removed and PCB cleaned up.
        memory slot cleaned up....not that it'll ever get used....it has 1mb RAM in it and likely doesn't need more.
        This sorry piece of shit.....I did order an identical replacement since it's a rechargeable 3.6v, not a standard 3v....but I'll likely relocate it to a self-contained unit off the PCB....so if this one leaks eventually, it won't further harm the PCB.
        Awaiting the batteries.......so to be continued....
        Team : 49813
        Join in!!
        Team Stats
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          ^Quantum fireball? Yeah, image that shit. And put in a different HDD that isn't as failure prone.
          sigpic
          (Insert witty quote here)
          • TechGeek
            Computer Geek
            • Jan 2015
            • 2254
            ^quantum fireball? Yeah, image that shit. And put in a different hdd that isn't as failure prone.
            qft
            Permanently Retired Systems:
            Kooky and Kool Systems
            sigpic
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              Yep, Quantum 'furball' isn't known for its long lifespan...the only reason it's probably still alive is because this machine probably wasn't heavily used.. It's already in the works. My attempt to cure this is a CF card with an IDE adapter. That hdd is 2.1gb. The OS (IBM DOS) and the control software consume 740KB <--yes, thats KILOBYTES....so a 64mb CF card + adapter on the way.
              I might have to dig out an old copy of norton ghost.... clonezilla would not recognize the partition for some reason.....I guess fat16 is too old for it. I did dump all the files off it though, and being DOS-based, making it all work again probably wouldn't be too difficult. The machine was made ~2003 (that's what the calibration tag said), but the technology inside it is very early 90's.
              Team : 49813
              Join in!!
              Team Stats
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                I replaced the batteries, that fixed the obvious (checksum errors and bios settings)... I haven't tried the CF card mod yet, the adapter isn't here yet.....but I've been diddling around with custom resolutions......and with all the timings & frequencies, its a tad confusing....so its something I'm just going to have to research and tinker with.....
                After repairs & reassembly....I also located the correct EVC to VGA cable.
                1920x1200 test....
                still some more diddling around to do....but not bad for a $21 gamble.
                Team : 49813
                Join in!!
                Team Stats
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  Well so much for the CM2220.... The CF card mod was a success...but a couple days after completing that, it began popping up 'video card firmware error' messages @ boot and it had no output. Eventually the errors went away, but it still has no output....even if I go back to the original drive. It still boots fine, and goes through all the motions....it just has no output... :-/ I have no clue....and as rare as it is, the odds of finding another to donate the output card is probably on par with winning the lottery.... Ohh well, lots of time wasted.....but thankfully not much money.
                  Team : 49813
                  Join in!!
                  Team Stats
                  • TechGeek
                    Computer Geek
                    • Jan 2015
                    • 2254
                    This may be worth a shot:
                    https://www.tulsa-ads.com/Sapulpa-/A...r-w-manual.JSP
                    sigpic
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      Originally posted by TechGeek
                      I saw that yesterday when I was googling solutions.....the pics are 11 years old and theres no contact information....
                      Team : 49813
                      Join in!!
                      Team Stats
                      • TechGeek
                        Computer Geek
                        • Jan 2015
                        • 2254
                        Could you try tearing it down completely and cleaning all the boards, interconnects, etc thoroughly and see if maybe that'll bring it back?
                        sigpic
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16958
                          Already done, it was the first thing I did. no-go. Interesting thing turned up through the googling, there is a CM2250-PC, which is an ISA PC card with a windows95 based control software package..... That would be a neat one to find....I could use my own PC with it....but I'm sure the odds of finding one intact with the software would be on-par with winning the lottery.
                          Actually, the control board in the CM2220/CM2250 IS the ISA card fitted into their case....but without drivers/software, a conversion would be impossible....and the problem appears to be on that control board. If I remove it completely, the CM2220 still boots/loads the DOS-based software.
                          Team : 49813
                          Join in!!
                          Team Stats
                            • 31159
                            does it have a video-rom?
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16958
                              It appears to, on the control board. The ROM itself wouldn't be difficult to find....the binary that's on it OTOH...
                              Team : 49813
                              Join in!!
                              Team Stats
                                • 31159
                                the rom content is probably generic matched against the gfx chip - other than the boot strings.
                                it just sets up the bios to access the correct registers and such for the chip.
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16958
                                  I have no idea....its what drives the test output. The internal display/VGA out is another GPU all together.
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                    • 31159
                                    i was refering to the internal display - i didnt know you wreent.
                                    post some decent pcb images.
                                    it could be a dead ramdac - had those fail in the past.
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16958
                                      I got annoyed with it the other day and reassembled it and set it aside..... I'll take it apart and get some pics here pretty soon.
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                        • 31159
                                        if you have a good multimeter, see if it's generating goot H & V sync pulses.
                                        • BigTroll
                                          • Sep 2010
                                          • 1317
                                          • LAMBDA SOND
                                          #40
                                          1920x1200 test....
                                          Nice! now if only topcat could do housecalls for a widescreen CRT convergence adjustment.
                                          My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                                            LCD LED TV Service Menu Codes
                                            ALL LCD LED TV SERVICE MENU CODES
                                            Service Menu Code with Board Name
                                            China Universal Board / Jumper Board Service Menu Code
                                            Changhong Ruba Service Menu Code
                                            Ecostar LED TV Service Menu Code
                                            Orient LED TV Service Menu Code
                                            Haier LED TV Service Menu Code
                                            TCL LED TV Service Menu Code
                                            Samsung LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            Videocon LED TV Service Menu Code
                                            Supra LED TV Service Menu Code
                                            Toshiba LED TV Service Menu Code
                                            Symphony LED TV Service Menu Code
                                            Veste/ LED TV Service Menu Code...
                                            10-31-2024, 03:58 AM
                                          • AustinCER
                                            Dell XPS 8940 | Manufacturing Mode? | No Service Tag
                                            by AustinCER
                                            Hello, I currently have a Dell XPS 8940 in our office for repair.
                                            Service Tag: HG1Y673
                                            The most recent BIOS is pictured below -- being available as an .exe on Dell website.
                                            Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
                                            Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
                                            07-15-2025, 05:28 PM
                                            Acer Aspire A517-52-54PS + Extended Service Plans Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire A517-52-54PS + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-52-54PS + Extended Service Plans boardview and A517-52-54PS + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 02:20 AM
                                            Acer Aspire A517-52-33HD + Extended Service Plans Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire A517-52-33HD + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-52-33HD + Extended Service Plans boardview and A517-52-33HD + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            Acer Aspire A317-53-5342 + Extended Service Plans Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire A317-53-5342 + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-5342 + Extended Service Plans boardview and A317-53-5342 + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
