Where are these no-name x79 motherboards coming from?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    https://www.newegg.com/Product/Produ...=-1&isNodeId=1
    China, of course.
    No-name motherboards, with ecc and some support without the expense of impi? Avoid? Or like use a cheap with an e3 xeon? My current server has dual 110w netburst xeons, maybe, get a single 95w instead?
    Also, it says it supports e5 series, now some of the ones listed as "dual cpu" (2600 series) are priced fairly well. The 1600 are priced pretty high.
    I would like a simple lower power server with ecc support. So, no atom or those itx boards
    • 31294
    Re: Where are these no-name x79 motherboards coming from?
    china makes a lot of motherboards for industry, they power everything from videogames & gambling stuff, to robots.
    i'v not seen them export them before though.
      master hoarder
      • May 2008
      • 12175
      It's a fairly new thing for PC components like motherboards and video cards.
      For example, "retro gaming" has pushed the prices of AGP video cards quite a bit in recent years - especially the high-end cards from nVidia and ATI. Because many of these are also no longer made by nVidia and ATI, used cards and NOS has been the only options up until a few years ago. Now China exports all sorts of unbranded AGP video cards with actual genuine ATI and nVidia chips (probably recycled, but who cares). And you can tell the cards are unbranded, because they use different PCB design... and also typically shit Sacon FZ capacitors.
      Anyways, the point is, there's money to be made in some of these markets and the Chinese have figured it out for some of them.
        • 31294
        thats good, maybe the 8800GT will be cheap to get at last.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Reminds me of DealExtreme, IIRC, LOL.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
            master hoarder
            • May 2008
            • 12175
            The 8800GT cards are cheap (here in the USA anyways). Though I personally don't like them at all and don't recommend them to anyone either - heatsinks on most are crap and the cards run absurdly hot. With that said, don't expect the Chinese to do a better job with the cooling if they made a 8800GT card. If anything, you'd probably have to rip out its stock HS and fan and replace with something else... at which point, the deal really wouldn't be worth it.
              • 31294
              8800GT is used in a lot of sega equipment - and cant be substituted.
              infact it even needs a special bios - but that's not an issue
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Looks just like what I expect with Apple...
                Arc A770 16 GB
                • ChaosLegionnaire
                  HC Overclocker
                  • Jul 2012
                  • 3266
                  • Singapore
                  the 8800gt and 9800gt both use the same gpu chip: the slightly faulty g92 core with 112 out of 128 working cores. there is also an oem only version of that called the gts 240 (NOT gt 240!) so any three of those cards should work since the underlying hardware is the same.
                  i even noticed the full 128 core g92 cards like the 8800 gts 512, 9800 gtx(+) and gts 250 actually sell cheaper than the 8800/9800 gt cards! they come with better coolers too! so u could get those full g92 cards instead and load the 8800/9800 gt bios on them! much cooler with the better heatsink too!
                    • 31294
                    the bios sets the core voltage and ram speeds- you cant pull that shit.
                    and afaik 9800 is a smaller die, so probably lower voltage than 8800
                    • ChaosLegionnaire
                      HC Overclocker
                      • Jul 2012
                      • 3266
                      • Singapore
                      no they used 65nm g92a and 55nm g92b cores on the 9800 gt and 9800 gtx cards interchangeably so they both have to be electrically compatible. i have also examined the bios from these cards with nibitor and they both run the core voltage at around 1.1-1.15v depending on what the manufacturer sets. a difference of 0.05v isnt going to make a difference.
                      from a mass production manufacturing standpoint, it doesnt make sense to have two different bios versions each for the 9800 gt and 9800 gtx cards that are going to have either a g92a core on it or the g92b. that just unnecessarily complicates the manufacturing process when u already need different video bioses with different ram timings depending on the brand of video ram that is going on the card. samsung, hynix, qimonda etc.
                      that way, less things to worry about during manufacturing. lower likelihood of human error and lower chances of things going wrong or mistakes at the factory before the product is even shipped out!
                      • Stefan Payne
                        • 1267
                        China, of course.
                        Well, they are rather simple and scrap some features of the LGA2011 plattform...
                        Then you're totally wrong on LGA2011.
                        For that you have to look for AMD (FX or Ryzen CPU, NOT APU).
                        As for Intel, the i3 also is said to support ECC.
                        So that's your opions...
                        BUT: you have to look for ASUS, maybe Gigabyte and Asrock Boards.
                        As for Power Consumption: LGA2011 (32nm) is similar to AMD FX in all possible ways.
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5045
                          • US
                          It's hard to find a good motherboard that actually has a bios to enable ecc. I know asus has some but it's not something they usually list in specs
                          • brethin
                            • Dec 2008
                            • 1907
                            Asus has many that support non reg ecc, they don't always document it though.
                            • madscientist750
                              Replacing electrolytic caps by solid caps on old motherboards
                              by madscientist750
                              I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                              I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                              I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                              10-19-2025, 06:10 AM
                            • qwerty99
                              Xbox 1.6 Motherboards and Polymer Capacitors
                              by qwerty99
                              Hello!
                              I need to change the capacitors on my three original Xboxes.
                              Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
                              The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
                              The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
                              I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
                              06-26-2022, 12:53 AM
                            • Foetuss
                              Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                              by Foetuss
                              Hi all
                              Hope this is in the correct place.
                              I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                              Could use some double checking to see if I'm not doing something stupid .
                              Pictures of the boards are attached.
                              What I will be replacing with what : (planned)
                              Soltek Golden ::
                              4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                              6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                              01-18-2025, 11:44 AM
                            • madscientist750
                              Looking for capacitor lists for Motherboards, Video Cards, Home Appliances
                              by madscientist750
                              I would like to ask if there is some kind of capacitor lists for motherboards, power supplies, video cards, audio cards, microcontroller powered home appliances, and so, that i could try to find and download. I use to repair those things and i would find it helpful if i could know in advance what parts may i need for common repairs.
                              07-09-2024, 09:24 AM
                            • blues_spirit
                              practical courses for troubleshooting pc motherboards
                              by blues_spirit
                              Hello from France,
                              mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                              Do you think this is feasible for me? I...
                              12-18-2022, 12:56 PM
