Dell 1800 fp screen blown power board
  • jepezus
    • May 2009
    • 8
    the wire diagram for a dell 1800 fp if your power supply is blown
    Intel Pentium Dual Core E2200 2.2 GHz
    Asus 775 P5KPL-CM
    Asus EN9400GT Silent
    4gb ram
    Cat 32 inch monitor
    2x 500gb maxtor ide and western digital sata
    Fixed projects:
    dell 1800 fp 18,1 inch screen
    cicero lcd 17 inch screen
    hd44780 2x20(from isdn phone) lcd screen on parralel port displaying pc stats
  • jepezus
    • May 2009
    • 8
    Re: Dell 1800 fp screen blown power board
    there is only one wire cabel that is like this so its easy to fix it no need to worry about the power for the backlight its on the smaller board that gets power from the molex if your done making the connector keep in mind not to exceed 1 mtr of cabel becouse if you will it will not give you any screen @ all
    Asus 775 P5KPL-CM
    4gb ram
    Cat 32 inch monitor
    Fixed projects:
    • Wizard
      • Mar 2008
      • 2296
      That is because the device to be powered doesn't have sufficient capacitors, due to cable length and resistance (thin wires are like that) is enough to drop voltage and increased ripple.
      Careful with the color and labeled wires, this one you show is poorly drawn. Be accurate. There are many who take this at face value and their monitor blows up.
      Cheers, Wizard
      • Wizard
        • Mar 2008
        • 2296
        Careful with the color and mislabeled wires, this one you show is poorly drawn. Be accurate, put info on which is which for each wires. There are many who take this at face value and their monitor blows up.
        Also, there is no such as -5v and +5v WITHOUT ground. We always draw ground if the pins measures fraction of ohm to the chassis ground.
        Just a note: very rarely a unit might have isolated supply island that is seperated from main ground, especially in units that have audio. I see this occassionally in TVs and some good audio combined with other systems in one. That will have extra text to the voltages like this for example: It is easily seen when you study one of those power supply that measured with no connection between audio supply and the other supplies especially ground paths. And good designer always put for every wire of power gets at least one ground wire to prevent ground loops through other chassis if number of ground wires is insufficient. Generic units are notorious for skimping on this.
        12V
        12V
        5V
        ground
        ground
        ground
        audio_ground
        audio_ground
        audio_+24V
        audio_-24V <---sometimes have dual supply with this -V supply when a ampifier uses pull-push design (better than most single supply audio amp.)
        Cheers, Wizard
        • jepezus
          • May 2009
          • 8
          well poorly drawn you can clearly see that wire 1(blue) and 2 are connected together 3 and 4, 5 and 6, 7 and 8 and the negative 5 is ground thats on the pc power suply and the negative 12 is ground also
          Asus 775 P5KPL-CM
          4gb ram
          Cat 32 inch monitor
          Fixed projects:
          • jepezus
            • May 2009
            • 8
            the color of the wires is as they are one blue and the others are all grey, and the molex are the standard colors dont wanna be rude but even my boss who has no knowledge of electronic understands what i have drawn.
            Asus 775 P5KPL-CM
            4gb ram
            Cat 32 inch monitor
            Fixed projects:
            • EGuevarae
              • Nov 2008
              • 1336
              You would be surprised the kind of people that lurks around here.
              There are 10 kind of people in this world: those that understand binary, and those who don't.
              • ASUS ROG Maximus IX Code
              • Intel Core i5-7600K 3.8GHz
              • 16gb GSKILL TridentZ RGB DDR4-3200
              • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
              • Windows 10 Pro x64
              • GeForce GT1050
                2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
              • HTR-Informatique
                Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                by HTR-Informatique
                YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                I also changed the screen because the PC fell and the screen was broken.
                I changed the battery with a new and original battery.
                I also had corrosion/oxidation on the...
                02-09-2025, 06:51 AM
              • cmlewis89
                LG 47LB5DF blown power supply board
                by cmlewis89
                Hi folks,
                I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                09-03-2024, 07:50 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • Swedishpower
                Dell G3 15 3500 black screen
                by Swedishpower
                Hello
                I have search everywhere for a solution for my problem, but cant find it anywhere.
                When I was away to trow some garbage i always look in the electronic bin.
                and this time i find a laptop.
                Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                the lamp for charmig is white.
                Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                but no Dell logo.
                I tryed with a hdmi cable to another screen, still black.
                I started to search solution and tryed...
                07-06-2025, 06:18 AM
              • Garret Matt.
                DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
                by Garret Matt.
                I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
                Thank you in advance for any assistance you can render.
                Inductor In question. Buzzes like...
                06-20-2025, 01:21 PM
