Turn your trashed LED TV into a shop light
  • Shock2cure
    Test Subject
    • Jul 2018
    • 140
    your LED TV's display screen puckered from that well placed beer bottle shot??, Or is it gonna cost too much to repair??...
    simply need more light??
    fret not frustrated friend, simply make your own shop light or area light from it.
    I tried this as a joke, but dang it...it worked. I just gutted this 42" Vizio I found on the curb (made 117$ off it selling the boards on fleBay) then added a 24v PS from an ancient HP to it, kept the diffusers in it, and Ta-Da!! ...instant bright light source!!
    added a couple handles and a kick-stand ... whole thing weighs about 2lbs
    got a 42" and a 26" model...lolz
    "Our technologies have surpassed our humanity" ~Einstein
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: Turn your trashed LED TV into a shop light
    I did similar with a ~22" HP monitor (the kind with the rigid front glass) to make a "light box" for tracing (think: X-Ray viewer)
    • petehall347
      • Jan 2015
      • 4439
      • United Kingdom
      i pulled one from recycle bins . never used it . seems to work ok though .. i prefer the lighting i use as the old tv is not as durable .
      • Shock2cure
        Test Subject
        • Jul 2018
        • 140
        a lightbox!! ....brilliant!! (pun intended)
        my brother owns a T-shirt silk screen biz (1988- 30 years), I used to do a lot of the artwork back in the true cut-n-paste b4 winblows existed daze, this would have been a cheap alt... good one
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          I did this years ago with 2x 30" monitors that had a broken LCD panels. They were CFL backlit. The only exception, I didn't light a shop with it, I mounted 2 of these 30" panels over a 9ft pool table. Best pool table lighting I've ever had! I have since taken them down, as I want to find one more and make a decorative wooden housing for them to live in. I ran them long-way with the table, I want to turn them sideways and run 3 of them....that will be a work of art when I finish it!
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • Shock2cure
            Test Subject
            • Jul 2018
            • 140
            Originally posted by Topcat
            I did this years ago with 2x 30" monitors that had a broken LCD panels. They were CFL backlit. The only exception, I didn't light a shop with it, I mounted 2 of these 30" panels over a 9ft pool table....
            oh snap ... friend o mine just got a 7ft one... he's wanting to buy a used one from a defunct bar here for crazy mad $$$...
            • Curious.George
              • Nov 2011
              • 2305
              • Unknown
              Most lightboxes are rather thick -- typically employing fluorescent lamps (T12's, etc.). This is considerably thinner so doesn't take up much space to store when not in use (you 86 the base, of course).
              I've been waiting to find a suitable LED monitor to see if I can make an even thinner version...
              • Adogabriel100
                Macbook pro A1278 820-2936 No light/turn on
                by Adogabriel100
                Hey! how are you guys? i wonder if you could help me with this macbook 820-2936 that does not turn on. (Doesn't have green/orange light).
                History:
                this macbook came for a short on C6990 that blows D6990 and R6990 on his way. i re-placed the componets and it work again.
                A month later comes back again and has the actual problem (no green/orange light and dont turn on)
                The macbook can turn on with only the battery connected but in fact, dosent charge.
                Voltajes:
                PP3V42_G3H = 3.3v
                PPBUS_G3H = 12.2V
                PM_PWRBTN_L...
                06-28-2023, 07:41 PM
              • dionzarek
                PS5 Slim EDM-040 Only turn on 1 Sec, Blue light then immediate off.
                by dionzarek
                Hello everyone, I am new to this PS5 troubleshooting, I need help on diagnosing the problem. My PS5 Slim board EDM-040 that beep and only shows blue light then immediately turn off.
                I've checked the PSU its normal 12V. I've checked all the capacitors its all good no shorts, but there are 2 caps shorted, I think its near the SSD. You can look at the image attachment.
                When tested it only shows 0.003 while other caps show 0.4 to 1. WHen in continuity mode those 2 caps goes beep/shorted.
                Any help to where should I check on or suggestion would be very appreciated....
                02-08-2025, 11:00 PM
              • vdrokko99
                MBP wont turn on Only green light on charger
                by vdrokko99
                I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
                SMBUS_SMC_BSA_SCL 3.5V
                SMBUS_SMC_BSA_SDA 3.5V
                12-01-2024, 12:18 PM
              • ruletero
                HP Omen only do not turn on, only flashes white light
                by ruletero
                Hi everyone
                Please help me with this laptop
                HP Omen 15-dc0003la , MB DAG3DBMB8D0 REV. D
                It doesn't turn on, when I connect the charger with battery orange light appears on power jack and without battery white light appear, it is fine I think
                But if I press power button, power led flashes white once, only that, not consumes anything power, not start, nothing more.
                Bios was programmed with a working version, no changes.
                Voltages
                +3vS5 = 3v when I connect charger, next goes to 0 (I think is fine)...
                06-07-2023, 10:11 AM
              • jxrepman
                Asus X453MA won't turn on and green led light blinking
                by jxrepman
                Hi there,
                I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                I have checked the charger and it is giving 19+ V
                I have disconnected the battery and pressed power button for 30 seconds.
                I tried another RAM stick.
                Tried disconnecting the keyboard and touchpad.
                Tried disconnecting the HDD and the wifi adapter.
                The problem persists.
                Hope you could help me out on this one. Thank you.
                12-14-2024, 06:40 AM
