melted laptop screen? err... what happened?
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    i recently took my mom's old laptop out of storage and this happened to the screen. please refer to the attached pictures. any idea what happened? the screen seemed to have crumbled into tiny pieces of white plastic. did the high humidity do this to the screen? can moist air cause lcd plastics to degrade?
    oh boy... not sure how i'm going to sell the laptop now... a pentium-m laptop prolly isnt worth anything these days...
  • dmill89
    • Dec 2011
    • 2534
    Re: melted laptop screen? err... what happened?
    I would think probably think heat rather than humidity. Where was it stored? If it was some place like a garage, shed, attic, or commercial storage unit (the corrugated metal rental ones) it can absolutely get hot enough in the summer to cause plastic to deteriorate or even melt depending on what type of plastic it is. The same can apply if it is stored inside a building near a radiator/baseboard heater/furnace, etc.
    Not sure what the market is like in Singapore on these but in the US that would probably be worth less than $30 (in working condition, and only worth scrap with a bad screen).
      • 31281
      is the brown nichotine or rust?
      btw, i think those are p4, not p4m - very power hungry room heaters.
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        it wasnt stored near anything hot or warm. just kept in a laptop bag on the shelf, away from sunlight. i guess even the tropical heat is too much for old stuff to handle.
        the brown stuff is just mold growing on the plastic, i think. its been kept in a dark and humid environment so i guess even plastic would get mold.
        and its indeed pentium m dothan core. i checked it before my mom bought it many years ago to make sure she bought the right stuff and the good stuff... lol!
          • 31281
          if you have strange mold that likes plastic then maybe it's in between the defuser layers and you can try to clean it off.
          • RukyCon
            A Fake Rubycon
            • Jan 2017
            • 816
            The only time i've seen something like that was with an water damaged NEC monitor.
            I'm not a expert, I'm just doing my best.
            • brethin
              • Dec 2008
              • 1907
              That's what I was thinking.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Hard to tell because of the flash, but it looks to me like the anti-glare coating/layer may have started to come off. If that's the case, just remove the anti-glare coating entirely from the LCD. It will probably turn the screen into a glossy one, though.
                And worse, some LCDs have the anti-glare coating/layer also fused with the polarizing screen - in which case, the screen will appear all white after the removal of this layer. But fear not! - The screen should still be visible with sun glasses (and some movie theater glasses too). Some people actually do this on purpose to create a "private screen" - a good idea if you want to watch pr0n at a public place and not have anyone else notice (or not anyone without sunglasses anyways).
                By the way, what screen size is this? I have a non-working Dell Latitude D600 with supposedly a good screen and bad mobo. Maybe we can piece something together.
                Pentium M is indeed quite slow and outdated these days, but with 1 GB of RAM and XP, it may still do some very VERY basic web browsing, or used as a word-typing PC. So not 100% useless. That, and the fact that this laptop likely has a serial port may make it useful for some folks who do hardware/firmware flashing.
                • Stunt
                  Hp Laptop Stuck on Hp protected by hp sure start screen
                  by Stunt
                  Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                  I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                  I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                  Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                  screen that's it and stuck there. I left it until the following day and i still...
                  09-02-2025, 01:51 PM
                • jean luc ferre
                  laptop hp g72 b52sf screen problems
                  by jean luc ferre
                  on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                  the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                  i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                  i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                  06-07-2025, 03:27 PM
                • Admin
                  Other Useful Threads - Laptop Screen Compatibility, Useful ICs, BGA Chip Suppliers, NVidia bumpgate
                  by Admin
                  Some sticky topics have been moved to this thread:
                  - finding a compatible laptop screen with LED-backlight.
                  Most Common ICs - a list of the most common ICs (Integrated Circuits) required for repairing a laptop
                  MOST COMMON IC FOR LAPTOP YOU SHOULD HAVE IN STOCK
                  Let's Talk About BGA Chip Suppliers - anyone who repairs computers at component level has had to order chips from China at some point. Large BGA chips like graphics chips, chipsets and now CPUs are in increasing demand, due to their...
                  12-27-2023, 03:43 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • almarhum
                  To fix laptop screen vertical line by working on its EDP cable
                  by almarhum
                  Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                  As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                  05-07-2024, 02:12 PM
