I've got a problem on my new installed app
  • kenleytate
    • Jul 2018
    Two days ago I've created .mpp file for my boss. But today when opening, I've noticed that some parts of my data disappeared from it. I've no idea how to fix mpp, but I tried some ways to handle it from Google, it didn't handle my issue. I'm using MS Project 2007 on Win 7 x32.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: I've got a problem on my new installed app
    Right click on the folder with the .mpp file in and click properties. Anything listed under the previous versions tab ?
    • Artefil
      HP officeJet 8012e ... A printer update will be installed to fix this problem
      by Artefil
      One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
      On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
      The screen displays the following message :
      "a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
      But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
      Have you ever...
      09-28-2023, 05:11 PM
    • Camarada78
      Boss delay DD-3 (square ship taiwan) problem
      by Camarada78
      I have a Boss DD-3 (square chip taiwan version) in my bench with a very weird problem. I found no similar problem online, nor a solution for it. It is driving me nuts.
      It passes sound on bypass no problem but as i turn it on it has a constant a noise (that can be clearly shaped by Delay Time, Volume and Mode, but very subtle by Feedback).
      - sounds ok on bypass
      - noise is there even without input connected.
      - all electrolitic caps were changed (!)
      - all tantalum caps were checked, ok.
      - most ceramics were cheked. too many to keep track....
      05-08-2023, 07:44 AM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • Unluckyfett
      Boss DD-3 (b) Problem
      by Unluckyfett
      Bypass works, direct out works. Delay signal is not right. ​​​​​Clock seems to be working. I replaced all 10uf electrolytics just because. No change. Based on sound and experience, should I be looking at the AD part or the DA part? I found a breakdown of how the microcontroller samples 12bit audio, I have a scope, I plan on doing more probing, just bothering me as I sit at home with it on my bench at work waiting to be fixed. If I'm reading correctly pin 7 on IC5 should be ≈ input signal. And pin 7 on IC8 should be delayed waveform? So if I have clean delayed waveform on IC8, the problem...
      07-23-2024, 04:33 PM
