Real Quick Question
  • weirdlookinguy
    • Sep 2007
    • 1638
    Real Quick Question
    My laptop has been ridiculously slow lately. I mean unusably so. 6+ minute bootup times, hell even just switching tabs in Firefox brings everything to a screeching halt sometimes. I suspect the four-year-old Hitachi drive in it, because I just did a clean install of XP and it's still horrendously slow.
    While I'm getting a new HDD for it, I figured what the hell, might as well get it that RAM I've always wanted to buy.
    It's a 2005-ish HP Pavilion ze2113us. Crucial tells me it takes 200-pin SO-DIMM PC2700, DDR333. I want to put this in it:
    http://www.newegg.com/Product/Produc...82E16820134186
    Is that gonna be fine? It's a one gig stick of Kingston 200-pin SO-DIMM PC3200, DDR400. I'm 99% sure it's gonna be fine but returning shit to online retailers is a bitch.
  • Harvey
    • Apr 2007
    • 264
    Re: Real Quick Question
    You'll find 99% of others will be 99% sure it'll work fine too. Just once in a blue moon you get a system (generally a laptop) that doesn't play with a particular make/size/speed of RAM, but there's no way of guessing what will/won't other than actually try it.
    • zandrax
      Hit and miss
      • Dec 2007
      • 1157
      • Italy
      The ram should be fine; anyway check the disk for bad sectors with Hitachi's Disk Fitness Test.
      Zandrax
      Have an happy life.
      • cnti
        Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
        by cnti
        Hi.
        BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
        This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
        BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
        RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
        burned, measured 10M ohm.
        QM801 [real PSU:...
        10-19-2023, 05:33 PM
      • mecha1166
        KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
        by mecha1166
        KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
        11-25-2024, 05:22 PM
      • CapLeaker
        Dell ATX PSU won’t start, but forcing it works fine?
        by CapLeaker
        Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
        Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
        10-28-2024, 06:59 PM
      • emil_t
        RTX3090 working fine but fans not spinning
        by emil_t
        Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
        04-12-2024, 06:54 AM
      • omeggga
        G502 lightspeed not working except for battery lights
        by omeggga
        Good morning, I signed up for this forum because I need help fixing my LogitechG502 Lightspeed.
        So I got a cheap used G502 under the pretense that the USB was busted and while it would charge, on wired mode it would not work, windows would not recognize it, or even give the little jingle when plugged in... but it would charge.
        So I think "ok challenge accepted, it's probably that the data bus on the usb is busted. I solder in a new one and I get a cheap wireless G502 that I've been wanting for years!"
        Nope, wireless doesn't work either, G-hub detects...
        03-13-2025, 04:27 AM
