Paxville or Bust! The Supermicro X6DA8 Project
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    It's been a while since I've done one of these threads...so what the hell!!
    The X8DA8-G2 is a 7525 chipset, and technically *should* support Paxvilles,but aren't listed in their 'CPU happylist" on their site....just incase I can't get Paxville CPU's to run in this board, I did grab a cheap pair of 3.8GHz Irwindales...
    This system was the freebie from the county. Stellar solid Enlight case with Enlight 470w PSU. I did the usual inspection of the PSU (whch appeared to be working)....and lo & behold, some bad fukyou caps, but otherwise its a very beefy PSU. The original board is an X5DPL-G8, old and slow server board (onboard graphics, no sounds, etc). It'll be retired and replaced with the theme of this thread.
    Anyway, some pics....
    Disassembled.
    SCSI cage & controller.
    Really beefy PSU. This case was intend for a dual redundant PSU, which can be had for about $65....not sure if I'll ante up for that though.
    Retired board....
    More to come...
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Paxville or Bust! The Supermicro X6DA8 Project
    That power supply sure looks familiar . Oh wait, here is its cousin :
    https://www.badcaps.net/forum/showpo...postcount=2352
    In short, it's a Topower unit. Oldschool half-bridge design, but built very well (minus the caps). No APFC BS either, so might just last forever (or for quite long).
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      No bust this time.... X6DAE/X6DA8 will run Paxvilles.
      Team : 49813
      Join in!!
      Team Stats
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        ^I'll be curious to see if it's stable with both CPUs running (and reported in windows). If so, I might see about grabbing a pair for my setup, assuming my cooling is up to par. My concern is that the VRM won't like the added load and cause instability and the like.
        sigpic
        (Insert witty quote here)
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          I dont forsee any problems. VRM *appears* the same as the DAI (hell all 4 of these boards use the same BIOS). W7 pro x64 sees all 4 cores + HT (8 CPU's) and 16gb RAM. Those pics were taken using one CPU and a Dell Precision 470 heatsinks for POST purposes. It is adequate for cooling in abovementioned precision 470, which runs the Paxvilles used for this experiment. I never had cooling issues, and I've had some interesting loads on that machine (used it for testing some things back in the day). It's permanent coolers will be some solid copper OEM Intel heatsinks.
          Team : 49813
          Join in!!
          Team Stats
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            ^That's what I have, fan swapped (PWM) Solid intel heatsinks. Maybe I need to buy a set on ebay to try out in V4.1?
            sigpic
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Looks like as long as there isn't a cheapo-socket AM3+ (and AM3) motherboard-like-incident, you're probably OK.
              I just hope that there don't end up being a Kentucky-fried power delivery system, like with MSI AM3+ motherboards...
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                That's not too much of a worry with these type of boards....they're pretty robust in that department.
                Team : 49813
                Join in!!
                Team Stats
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  ^Got benchmarks?
                  Just curious, I'd like to see what the paxvilles can do compared to my 3.8 Irwindales.
                  Oh what the hell, I found them for $10 a pop shipped. I'll take that to my thread...
                  sigpic
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    ^Got benchmarks?
                    I dont yet, but I will....unless you get to it first.... Yea, netburst era stuff is filthy cheap!
                    Team : 49813
                    Join in!!
                    Team Stats
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      And as cheap as that was ($20 for a pair, although the listing said lot of 2 in the description so maybe I got 4???), the 16GB of DDR2 in it was cheaper ($16 shipped, hell yes!)
                      sigpic
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16958
                        I got 16gb today for 12 bucks shipped. If you do end up with 4 CPU's, let me know....I'll take the 2 extras off your hands if you don't have a need for them.
                        Team : 49813
                        Join in!!
                        Team Stats
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          See my thread. I might have a use for them...
                          sigpic
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            My 16gb of $12 Micron memory arrived today... When I have some time, I'll start piecing this one together.
                            Team : 49813
                            Join in!!
                            Team Stats
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Hmmm.. So I did some search on what these Paxville CPUs are, and correct me if I am wrong, but looks like they are the server version (Xeon) of the Pentium D based on the Pentium 4 architecture, no? If so, it's interesting to note that these Xeon CPUs have HT, whereas the Pentium D CPUs don't.
                              In any case, these are 135 Watt TDP CPUs according to my research, so good heatsinks are definitely needed (like the 6-pipe Dell Precision 470 heatsink that Topcat showed above). Also probably not so great to run these in the hot summer months. But they might be just what one needs to keep the house warm in the winter.
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16958
                                Just for the sake of tinkering, and the fact that I already have 2 fully functioning Paxville systems, I'm going to do some diddling around with this system and the 3.8GHz Irwindales....
                                The burning question (pun for netburst), what will perform better? Will it be 4x cores @ 2.8GHz or 2x cores @ 3.8GHz...hmmmm
                                Team : 49813
                                Join in!!
                                Team Stats
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  ^Taking benchmarks?
                                  sigpic
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16958
                                    ^Taking benchmarks?
                                    Yes, I'm working on a little 'showdown'. A X6DAI vs a X6DA8, paxville vs irwindale. One will be SAS, the other U320 SCSI (both in RAID configurations), but otherwise pretty identical. I have to find (or dig through my stuff) another FX4800 GPU so they'll be on par...but otherwise they're the same system other than the HDD interfaces...which will make yet another point of comparison albeit we know which interface will win...but still kinda cool to see and put numbers to.
                                    Between the house build and other stuff, it may take me a little bit to get this together, but it'll get done.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      I have benchmarks on 3.8 Irwindales. 16GB Ram, GeForce 9800GT GPU. HDDs are 2 7200RPM WD 160GB's (RAID 0) on a 3ware 9650SE. I haven't swapped to Paxvilles yet as me AS5 shipement hasn't come yet (and I won't be back home until Sunday).
                                      sigpic
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16958
                                        I diddled around with this a little this morning... Mainly for testing purposes to make sure I have working hardware. This test is with the Irwindale processors. Of course this post was created from it. Wtaerfox 56.1.0 functions excellent on it. Quick load and smooth as silk browsing....although I haven't put it through the youtube test....
                                        I now remembered one of the sucky parts about SCSI, its the slowest booting bastard, even though its U320 with a 15k RPM HDD. Once it boots, its fine (benchmarks to come when I get it to a permanent state).
                                        Missing caddies located and replaced.
                                        CPU-Z:
                                        More to come, but back to my other project for now.
                                        Team : 49813
                                        Join in!!
                                        Team Stats
