Manjaro Linux
+ More Options
Posts
  • bigbeark
    • Jan 2010
    • 661
    Manjaro Linux
    After my problems with PureOS and Zorin, I decided to load Manjaro XFCE on its own hardrdrive so as to avoid partitioning screwups.
    This is an Arch-based distro. It installed painlessly and quickly. I've never used an Arch-based distro before so a lot of the software is new to me.
    The amount of software available in this distro is enormous. You could spend forever getting acquainted with all the applications. Lots of Sofware categories outside of the usual Distro. Games section is huge, also Science, Education etc.
    Some Gnome apps and KDE apps are in there.
    Performance is very good. XFCE seems quicker than GNOME. I also use Linux Mint XFCE which is really excellent too. It's more familiar to me as it's software set is similar to the MATE and CInnamon Distros from Linux Mint.
    About the only quibble so far with Manjaro is the wallpapers available which are minimalist and unattractive (to me).
    Any other Arch-Linux users with suggestions on what's good and what's not?
  • petehall347
    • Jan 2015
    • 4426
    Re: Manjaro Linux
    what sort of problems come with PureOS ? its just i was thinking of trying it next month when i have enough data allowance to download it .
    have been running ubuntu for many years now with very minimal problems
    • retiredcaps
      • Apr 2010
      • 9271
      Re: Manjaro Linux
      I tried Manjaro LXDE 3 times in the past. It would work well for a few weeks and then some upgrade would eventually leave it in a non booting state. This happened 3 times and after the 3rd time, I decided to stay with Lubuntu on my test machine for now.
      While I could have found the answer to why it wouldn't boot, I don't think it is ready for the average user. With Lubuntu, I have never had a problem where it would fail to boot after an upgrade.
      I have tried a lot of distros in 2014, but for everyday solid reliable performance, I settled on Lubuntu.
      On my test machine, I'm willing to try anything, but staying away from all the fat bloated distros.
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        Re: Manjaro Linux
        It helps if you have a separate physical PC just for testing. On my local kijiji, I can find dual cores (core2duo) in the $10 to $20 range.
        • bigbeark
          • Jan 2010
          • 661
          Re: Manjaro Linux
          My previous tthread on Linux Distros outlined the problems, but to recap, the partition manager used by Pure destroys whatever data is in your target partition. In Ubuntu and it's derivatives you get to resize without data loss.
          Also, Pure would not recognize my USB keyboard, I had to quit the install. When I booted up again my Ubuntu 18.04 had been wiped out and the Pure partition had 500 bytes of data in it.
          • Stefan Payne
            • 1267
            Re: Manjaro Linux
            Whenever I try stuff, it ends always with Linux Mint.
            Because most stuff comes in a .DEB Package these days. And that's only compatible with Debian based Linux shit. And Mint is based on Ubuntu wich is based on Debian.
            The only thing other than Mint that I've used for a longer period of time is OpenSuSe...
            OpenSuSe has some kind of Auto Updater that at least annoys you at login that there are new updates. Don't remember if there is an auto update setting though...
            With Linux Mint there is no such thing and you have to install the updates manually - wich is rather stupid for a more or less beginner OS.
            If you want to sell it to the uninformed Populus, you should activate some kind of Auto Update thing or it should come with something like that...
            Bad thing with OpenSuSe is that its a bit of a pain to install other stuff like Discord...
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8104
              Re: Manjaro Linux
              I've tried Manjaro a few times. There are some things I really like on it, but it breaks to often for my liking. So I went back to Linux Mint and Ubuntu. I've screwed Linux Mint up on time myself and I had to reinstall the NVIDIA driver once, because a update had screwed that up. Other than that it has been A1 reliable to me. I am running Linux Mint on 3 computers here and Ubuntu on one computer. Works like a charm and no headaches.
              • retiredcaps
                • Apr 2010
                • 9271
                Re: Manjaro Linux
                Yep, it mirrors what I found.
                I also tried Linux Mint, but since Mint runs on top of Ubuntu and Ubuntu runs on top of Debian, I figured I didn't need the extra overhead.
                I would run Debian LXDE natively, but the Ubuntu fonts are so nice and easy to read, I'm sticking with Lubuntu.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8696
                  Re: Manjaro Linux
                  Uh... doesn't exactly work that way. The "overhead" if there is any is done by the maintainers of ubuntu/mint - your PC does not see that "overhead." There's nothing "extra" that runs "on top" - they merely flavored the Linux and packaged it for you.
                  If you really care about this so-called "overhead" you might well run LFS where you get as little packaging/flavoring at all.
                  • ivtec
                    • Dec 2008
                    • 1967
                    Re: Manjaro Linux
                    I have old Pc with 32Bit and tried many of those distros but always go back to Xubuntu 14.04 Xfce
                    • Stefan Payne
                      • 1267
                      Re: Manjaro Linux
                      Wait, wasn't manjaro a rolling release distribution??
                      If so, then you know why its dying from time to time. Not everything is well tested.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8696
                        Re: Manjaro Linux
                        Anyone else here run a rolling release and keeps up with the rolling?
                        I have to say it's "fun" with the breakages that happen from time to time... Fortunately updates work just fine nowadays...
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8104
                          Re: Manjaro Linux
                          Last time I tried Manjaro 2 months ago on 2 different computers and ran it for 8 weeks or so and did the rolling update. Both went back to Linux Mint. Some stuff flat out doesn't work like it does in Linux Mint or Ubuntu. Other stuff I liked working better in Manjaro. However it broke too often for me. I don't have that kind of time to frig around with computers because they did an update. Other than that I could have stayed with Winblows. I do like Manjaro, but it is too buggy for me to consider it at this point. If the Manjaro team is able to sit on their @$$es, fix the known issues and are a bit more careful with these cutting edge updates, I may consider it again.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8696
                            Re: Manjaro Linux
                            I've been using Gentoo for over a decade now. Yes, the rolling release is frustrating at times.
                            • mr.malcom
                              HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
                              by mr.malcom
                              this is a very strange Problem:
                              Notebook hang instantly on Boot. BIOS is accesable.
                              Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
                              Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
                              i have tried:
                              - only one RAM Stick, another working RAM, both RAM channel
                              - BIOS Flash to newest Version F.50, BIOS Reset
                              - Memtest86 hang instant at Test 2
                              - HP UEFI Diagnostic wont find...
                              02-26-2022, 05:19 AM
                            • tsavpyn
                              Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                              by tsavpyn
                              Dear all,
                              I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                              Now I have a problem that I am unable to dump my BIOS into bin file.
                              My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                              I searched for FPT but there is no Linux version and none of them work.
                              I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                              I would really appreciate it if anyone...
                              05-28-2024, 11:18 PM
                            • Topcat
                              The 2025 Operating System Thread
                              by Topcat
                              What OS are you running these days? I am down to 3 Windows workstations and one Windows Server on my LAN, everything that doesn't have a windows-specific need has been moved to Linux. Printing abilities with my large document centers are Linux's kryptonite; the reason for 2 of the Windows machines. The third machine still has Win7 on it, and isn't connected to the outside world. It has tons of software on it I use for diagnostics and updating various hardwares. My main rig is still Win10 Enterprise, so I had to vote Win10 in the poll...but I have overwhelmingly more linux machines than windows...
                              Windows 11
                              29.41%
                              15
                              Windows 10
                              23.53%
                              12
                              Windows 8/8.1 or 7
                              13.73%
                              7
                              Windows Vista (I'm a glutton)
                              0%
                              0
                              Windows XP (I just can't let go!)
                              3.92%
                              2
                              Windows 2000 / ME / 9x (Ok, this one is a funny, maybe!!)
                              0%
                              0
                              Some flavor of Linux (brag on your distro in a post)
                              25.49%
                              13
                              MacOS - OSX (Poor diluted souls!!)
                              3.92%
                              2
                              Google Chrome/chromebox/chromebook
                              0%
                              0
                              What's a PC? (The option for those with a phone stuck in their faces)
                              0%
                              0
                              01-01-2025, 10:19 AM
                            • survivalbloke
                              MS Surface Book 3 - Keyboard works only in UEFI/Linux
                              by survivalbloke
                              This is a very weird issue which I'm having trouble finding a common thread.
                              The keyboard is registering keypresses in either the UEFI, or a live Linux USB environment - I used Ubuntu for testing. The keyboard backlight is lit.
                              The keyboard is registering keypresses in Windows or any Windows-related bootable device. For example, it does not work in Hirens Recue or a Windows 11 bootable installer.
                              When booted to Windows, not only is the keyboard not registering keypresses, but my USB keyboard is not either!
                              USB mouse and integrated trackpad...
                              07-14-2025, 03:17 PM
                            • keepread
                              SPD reading/writing under Linux and/or Windows
                              by keepread
                              Where can I find the mysterious 'eeprom' kernel module that some use under Linux to read/write SPD?
                              I installed 'i2c-tools' and got 'decode-dimms' tool under Debian but not under Fedora, but both of them are missing the 'eeprom' module.
                              Also tried the SPD.exe tool from EVGA, which correctly lists all of the DIMM slots but reads zeroes from all of them.
                              Basically I need to dump SPD from some modules that were sold to me as DDR-1866 but are made of DDR-1600 chips, and they do not work. There is no access to RAM clock rate in the BIOS, so I am SOL unless I can rebin...
                              01-20-2025, 08:07 AM
