need some help please
  • petehall347
    • Jan 2015
    • 4426
    Re: need some help please
    2 things infected ..will need to let it run all night before i know what it is ..bitdefender for unices seems a bit hardcore .
    • Curious.George
      • Nov 2011
      • 2305
      • Unknown
      Take an image of the system. Wipe the disk and install a clean OS. Verify the problem has gone away --> problem lies with something in the disk image
      When I build a new machine, I take several images along the way and store them on a labeled, bare drive (that I keep in a shoebox of similar drives from every other machine I've built). E.g., for a windows machine (those usually the most difficult to keep running properly), I take images:
      • after installing the OS from CD/DVD
      • after installing the drivers
      • after installing any OS updates
      • after installing the "basic/core" utilities
      • after installing the specific applications for that workstation
      • after configuring everything
      In this way, I can roll back to any point in the build process to see where a problem may have been introduced.
      [Often, some combination of applications won't work properly and I don't want to have to start over again just to back out the offending application(s)]
      • petehall347
        • Jan 2015
        • 4426
        after all that i found its facebook causing the issue ..
        radiospares tab was also hogging too
        not sure how to fix facebook issue as yet
          • 30977
          rs and farnel/cpc use a hell of a lot of java,
          fuckbook was predictable, it tries to acess your mic and camera.
          • petehall347
            • Jan 2015
            • 4426
            no mic and camera anyway .plus i deny access to those anyway ..
              • 30977
              it will still burn cycles trying.
              • petehall347
                • Jan 2015
                • 4426
                #27
                tirning this off might be the one ...javascript off on its own did nothing ..."Enable JavaScript source maps"
                • petehall347
                  • Jan 2015
                  • 4426
                  #28
                  damn it ..still same but takes more invoking
                  • petehall347
                    • Jan 2015
                    • 4426
                    #29
                    Disable async stack traces
                    now then i am getting somewhere .. hope so anyway ... multiple reloading of facebook tab can invoke the fault which isnt the fault as such ..
                    now what happens is cpu is freed up in short time instead of being throttled continuously .
                    • petehall347
                      • Jan 2015
                      • 4426
                      #30
                      spoke too soon ..still doing it today .
                      • petehall347
                        • Jan 2015
                        • 4426
                        #31
                        might have it figured now .am away so will try when i get home . i missed the warning when i updated slimjet on the pc .i caught it updating on laptop .https://www.slimjet.com/en/libffmpeg.php
                        • petehall347
                          • Jan 2015
                          • 4426
                          #32
                          that seems to have fixed it but on testing it my power down plug blew up .. i ramped cpu up to 60 percent by reloaded all tabs about 6 times .fan was flat out then pow my amp and screen went off . now the power down plug wont work and smells of burning .. oh well never mind will have to get new one now .
                            • 30977
                            what's a power-down plug??
                            • petehall347
                              • Jan 2015
                              • 4426
                              #34
                              one of these things .. master socket for pc and 2 other sockets for monitor etc ..
                                • 30977
                                interesting, i'v only seen strip-versions before.
                                • FALKLAN
                                  Running Line Voltage and Integrating LED Pods - Automotive
                                  by FALKLAN
                                  Howdy everyone! I hope all is well where ever you are!
                                  I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                                  I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                                  02-05-2025, 12:30 AM
                                • rumpumpel1
                                  ThinkPad X1 Carbon 4th Gen running only at 400 MHz
                                  by rumpumpel1
                                  Oberservation:
                                  X1 Carbon 4th Gen runs very slowly. Task manager shows the CPU running at 400 MHz.
                                  In rare cases (1 out of 20) it runs at normal speed.
                                  It does so when running on battery or only with the charger.
                                  When both are connected - charger and battery (50% charged) - the system switches between charger and battery once per second.
                                  The laptop does exactly the same thing when running Windows or Linux, so OS level problems can be ruled out.
                                  Flashing CleanME and a different BIOS made no difference.
                                  Intel's XTU utility...
                                  09-18-2023, 06:13 AM
                                • Kambi13
                                  Samsung NP370E4K No backlight running on battery
                                  by Kambi13
                                  Hi all, need some help. I have a Samsung NP370E4K-KD2BR, which as a 5th Gen Intel CPU that works fine when running with the charger plugged in, but has soon as I remove it and it's running on battery the screen backlight goes off.
                                  Tried different battery - no change
                                  Tried different screen - no change
                                  Removed the plastic film from the screen inverter and looked for pwm signal which as about 3.3v when running with the charger plugged in, when I take it off the voltage drops down to 2.232v, so my best guess is that the EC is not providing the correct voltage....
                                  09-04-2023, 11:06 AM
                                • Skgod
                                  Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
                                  by Skgod
                                  Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
                                  Black screen, freeze
                                  The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
                                  When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
                                  So can anyone tell me what would be the possible cause?...
                                  10-16-2024, 08:11 PM
                                • Comp_Pro
                                  820-01949 Running Slow Fast Fan ASD Software Download?
                                  by Comp_Pro
                                  Hello all,
                                  I'm trying to repair this A2251 macbook pro. Board is 820-01949. The original issue was liquid damage which all cleaned up well and the board was not heavily damaged. Unfortunately after liquid damage cleaning the computer is running extremely slow and the fan is running at full speed. Even the cursor is lagging. Because of this I can't use the built in hardware diagnostic to give me a clue as to what is happening. Does anyone know if Apple Service Diagnostic software is available for this model? Any other clues which could help me out? Seems to me there is an issue with...
                                  11-30-2023, 05:33 PM
