Ratdude's Main Rig V5.5???
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Possible new build time....
    Main Rig V6 is built and running, and I have some leftover hardware when V5.2 was gutted to make V6:
    • Two 3Ghz Quad core Harpertown Xeons
    • Dynatron coolers for ^
    • 32GB of DDR2 FB-Dimms
    • An adaptec UIO SAS card
    • an unreliable supermicro X7DWA-N motherboard
    Topcat, lately my main source of workstation build inspiration, suggested I look at these:
    https://www.ebay.com/itm/Super-Micro...torefresh=true
    Compared to the X7DWA-N that I can't find a replacement for, that's pretty cheap! What the hell, I tossed in an offer... even for $50, that's hard to pass up. Sure I only get 6 RAM slots (24GB limit, which I would max out with what I have), but that's not a huge loss. UIO slot too, so I can reuse my SAS card!
    However, I am missing some required parts for this... mainly HDDs, and Case/PSU. And backplates, since these normally are made for SM cases with standoffs and holes for the coolers. Although whatever this goes it can probably be transfer punched and drilled to accept standoffs (with nuts or screws from behind the motherboard tray).
    I really don't know where to go with this... whatever I do, it will need very good cooling for the wickedly hot FBDIMMS.
    One idea is to find an OEM ATX case of some sort, throw in an appropriately beefy PSU, and make a sleeper. If it cooled better (and wasn't trashed), My dad's old HP D530 case would fit the bill. Being an ATX board, I have more options than my usual EATX builds.
    Another option is supermicro ATX cases, which do exist. Not "different" compared to my other builds, but an option nevertheless.
    Also, I don't have a GPU for it, but if I ever SLI V6, I'll have to get different GPUs for it, so that Zotac GTX 970 might be available.
    All suggestions are welcome, please don't be butthurt if I raise questions or have concerns.
    sigpic
    (Insert witty quote here)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Ratdude's Main Rig V5.5???
    My 'supermicro tree' gave me one of those. They do not support 1600FSB. 1333FSB is the max. The Dolby thingamajig also has one. The dobly came with a pair of 3000/1333 CPU's, and for the other one I managed to score a cheap pair of 3.33/1333 for it....I did try a pair of e5472's (3000/1600) in it, and no-go. The chipset is said to support it (greencreek IIRC), but they don't....and SM's site says 1333FSB is the max. The X7DWA is the Seaburg chipset. Both of mine have the latest BIOS.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Well, I'll retract my offer then. Too much expense when CPUs are added. Said it would run quad core harpertowns, but obviously not mine (E5472, 1600FSB).
      Damn.
      Edit- The X7DWE is the seaburg version. No 16x PCIe though... So X7DWA-N or go home for this hardware (unless I ditched the SAS card and rebuilt a dell precision or HP something... )
      OT: apparently SM makes Dual-CPU micro ATX boards: http://www.supermicro.com/products/m...00/X7DCA-L.cfm
      Hell of a sleeper there, too bad no 1600 (seaburg only )... actually the only common thing is the coolers (I do have a spare set of 771 tall coolers, another project idea!)
      sigpic
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Never mind on the micro ATX wonder... Cheapest I've found costs more than I'd want to spend and is a audio-less version:
        https://www.ebay.com/itm/1PC-Supermi...EAAOSwx2dYGG38
        But hey, if I found one cheap, I could toss it in some cheap ass acer/compaq/other cheap OEM case and make the ultimate sleeper. Regular non-FB DDR2 doesn't run too hot, and with a 16x slot one could really go crazy.
        sigpic
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          https://www.ebay.com/itm/272434058025
          Interesting little board there....I've got an old Asus P4-era minitower (model VINTAGE-S800) that it would fit nicely in. Talk about a sleeper!
          Team : 49813
          Join in!!
          Team Stats
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            ^see my last post
            sigpic
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              For shits & grins, I threw them a lowball offer for one.
              Team : 49813
              Join in!!
              Team Stats
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Go for it. For once the inspiration will flow the other way *
                *- Ok, not really, dremel'd I/O shields and UIO SAS cards are ideas of mine you've used. Still, I have to point it out...
                sigpic
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16956
                  I've been dremeling IO shields & cases since back in the 90's....but the UIO card is an original for you. I didn't know (or even research) what that goofy slot was even for. ...and you'll even get credit for this one, I never knew this little critter existed.
                  What really piqued my interest with this board was it not requiring fully buffered memory (reduces both power loads & heat dissipation). Surprisingly, that little Asus case breathes very well, but looking inside it, some modifications would be required....now we're talking fun! I've got plenty of hardware of this era to get rid of (CPU's and memory)....what better way!
                  Team : 49813
                  Join in!!
                  Team Stats
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Shame it's the version without onboard audio... When you only get 4 slots, that kinda sucks.
                    You're right on the I/O shield, I just got my name attached to it later at least in a few mentions.
                    sigpic
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16956
                      Yes, I remember 'ratduding' an IO shield for some other build...yea, it stuck.
                      I saw that...but for a build like this, I'd use all the onboard IO stuff with an SSD most likely. GPU and audio card would be all. Wouldn't really be a problem...but yea, would have rather had the onboard.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        I see.
                        If you don't want to use up dynatrons, I have a pair of barely used supermicro 771 coolers you can have if this project becomes a thing. They are the original tall ones for V5.0 that were swapped for 2U dyantrons to accommodate the fan duct of my case. More role reversal for ya
                        sigpic
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16956
                          memory is certainly cheap enough for it.... can max it out for ~54 bucks if I couldn't get the price down....but I bet I could!
                          https://www.ebay.com/itm/282705620925
                          all hinging on the lowball offer on the motherboard.
                          Do those SM heatsinks have fans on them?
                          Team : 49813
                          Join in!!
                          Team Stats
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            Yes they do.
                            https://www.newegg.com/Product/Produ...82E16816101288
                            That RAM is dirt cheap. I obtained 16Gb for $30 or so for V4.1, same stuff. I also have 8GB of it sitting, although I'm sure you do too
                            sigpic
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16956
                              Yea, I'll take those....even if this one doesn't come through, i've got another I could use them on.
                              Team : 49813
                              Join in!!
                              Team Stats
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                More use than I have...
                                sigpic
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16956
                                  Cool...send 'em my way then. They'll have a home.
                                  No response from the seller...I guess I offended them.
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16956
                                    I found one cheap (x7dca)....and was given a good sleeper-like case to put it in...
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      Sweet. I'll have my wife mail you some copper.
                                      sigpic
                                      • cheeky2
                                        by cheeky2
                                        05-25-2024, 03:27 AM
                                      • Dani_2024
                                        by Dani_2024
                                        10-28-2024, 05:06 PM
                                      • ygorsan
                                        by ygorsan
                                        🧩 Problem Summary:
                                        • I
                                        07-28-2025, 08:34 AM
                                      • Asraf Atb
                                        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                        by Asraf Atb
                                        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                        01-27-2025, 05:02 PM
                                      • JSin21
                                        Compatibility of main boards between different variations of samsung MU6100
                                        by JSin21
                                        Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                        I have Samsung Smart TV UA65MU6100WXXY version DA01
                                        Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                        11-27-2023, 04:54 AM
