Re: Hard drive reliability
I had a 60GB Seagate last 140000 hours before it randomly died (3/4 of the way through backing up no less) - never had any errors or bad sectors, was copying flawlessly, then suddenly dead, a few clicks upon powering up then power down immediately. The 40GB Seagate in the same PC had 160000 hours and was still good the last time I checked two years ago (no point as I backed it up before the 60GB).
Still got a long way to go with this PC - it's a 320GB Hitachi Deathstar HDS721032CLA362 with just 33684 hours.
Is it a Dell?
Thanks! Glad to see you're still around here.
I saw one of those 80GB 7200.7 drives run 24/7 for about ten years and even survive a real-life table flip while it was powered on. I didn't pay attention to power-on hours, but it had no bad sectors when it was taken out of service. I still know where it is, and it might end up in my junk pile eventually to replace other old IDE hard drives (like my previous spare 60GB Western Digital that didn't spin up reliably the last time I tried it).Kudos to that drive though. That's impressive! Back when Seagate was good. I haven't touched new Seagate drives in a long time. I was fully moved over to Western Digital (for new drives) since 2016.
Welcome back.
I saw one of those 80GB 7200.7 drives run 24/7 for about ten years and even survive a real-life table flip while it was powered on. I didn't pay attention to power-on hours, but it had no bad sectors when it was taken out of service. I still know where it is, and it might end up in my junk pile eventually to replace other old IDE hard drives (like my previous spare 60GB Western Digital that didn't spin up reliably the last time I tried it).Leave a comment:
It's a laptop used as a laptop (and its rs232 port), it still works, it's faster than my Atom 1.6GHz by a small margin.
Running Linux and currently trying to update to the rolling release's latest version...Leave a comment:
I have so many PII/PIII/P4 S478 that I don't know what to do with.
I kind of want to run it in the corner on a battery backup just to see how many POH I can get on it
What are you doing with your Pentium M?Leave a comment:
sigh... annoying that they're dropping support of perfectly good hardware...
Can Pentium-D's run 64-bit, thought they were Preshots or something of that vintage, though RAM might be another problem.
currently updating my poor old Pentium-M...Leave a comment:
Here's the highest hours I've seen so far. This hard drive is badass. It had 90,000 hours when I got it. It was in a, wait for it.... SFF case with a Pentium D! Ouch! And the fan PSU failed, but it kept chugging along with bulged caps for who knows how long. So I put it in my IPFire box even though it had reallocated sectors. From the 90k point to this picture (June 18, 2021), it only gained 6 more reallocated sectors. It's currently retired since IPFire is dropping x86 support. That P4 box moved over ~63TB of network traffic while in service.
Here's a picture of the computer it was in. Was only temporarily unplugged lol. Most of those caps were acquired from Badcaps here and installed back in the day. Those alone have given that motherboard at least another 35,000 hours of life! The original 02 date code HNs failed at ~18,000 hours.
My boot drive(Sandisk SSD)
https://pastebin.com/6UH20vF2
/home drive(WD Caviar Black 2TB)
https://pastebin.com/UGEd7L0t
Video Editing drive(same as /home drive)
https://pastebin.com/y0u51AzuLeave a comment:
Well, with WD, I always check, even if it's a low-hours new drive. It all depends how it's been stored. If it's an OEM drive, ideally it wasn't shipped in bulk packaging without a seal or left by whatever OEM used it to sit too long in a damp warehouse before getting used.
Yeah, that's quite a lot. WD should have disabled whatever platter(s) were defective and the HDD sold as a lower capacity one.Last edited by goontron; 07-01-2018, 11:35 PM.Leave a comment:
Originally posted by goontron811 sectors... Over 56 events... Something tells me they didn't mark bad sectors at the factory.Leave a comment:
^ You would think at only 41 hours they wouldn't be corroded. And, sadly, they aren't...
There you go.
So how many reallocated sectors does it have now? Don't tell me none!
Also, I forgot to mention, but since you have a WD drive there - clean the PCB contacts that go to the heads / actuator, as they regularly oxidize on WD drives.Leave a comment:
Just posting an update. Where proprietary software failed, FLOSS succeeded. I ran badblocks on it in destructive mode and the drive came good.Leave a comment:
LOL
Ah well, it would have been a waste of time anyways.No matter what many softwares claim, I don't think you can properly ever fix any physical damage inside an HDD with some mouse clicks. At best, you can just map around bad sectors and hope the HDD doesn't hit that area, then go offline.
But all in all, I too think that regular spinners are safer for data than SSD. With SSDs, your data is spread across many different memory chips, and when one fails, pretty much all of your data is gone. Think of it as a RAID 0 array consisting of many many discs. On that note, multi-platter HDDs also function internally like a RAID 0 array. So the safest bet is usually a single-platter, single-head HDD with a lower capacity. But who wants to use a 40-80 GB wonder from 10+ years ago?
... well, okay - I do. But that's only on computers I use for work (i.e. typing, storing documents and a few personal pictures). With my gaming/multimedia-oriented PCs, I don't care - I just back up start over when things go bad.
7200.7 is pretty damn reliable. I have seen very few truly failed ones (i.e. not detecting or clicking). Yes, a lot of them will accumulate bad sectors over time (some more than others). But despite that, they continue to work fine for many years. On that note, some of the WD's from the same time period didn't fare any better. Moreover, from what I've seen, WDs from that time tend to stop working at random on a cold boot - no warning signs whatsoever. With the Seagate 7200.7 and 7200.9, you usually get a lot of early warnings, like squealing/squeaking and BSODs, to name a few.
In any case, though, both WD and Seagate were pretty reliable back then. Just because you got a bad turd from Walmart shouldn't drive you to conclusions about all models from a particular manufacturer. I mean, anything you get from Walmart shouldn't surprise you if it fails.Last edited by momaka; 06-25-2018, 07:00 PM.Leave a comment:
Looks like Barracuda 7200.7s are shit.In fact, the bad one I got from Wal-Mart on May 14, 2005, was most likely a 7200.7, I had weird squeaking when seeking a lot, and multiple SMART checkers were predicting an early HDD failure!
Barracuda 7200.9=I dunno...
Barracuda 7200.11= It's possible that no other Barracuda gen got a worse reputation than the 7200.11! They reportedly have major firmware issues and possibly major hardware issues as well!
The Barracuda 7200.12s and what appear to be related, seem to be the best later Seagates (besides the Barracuda 7200.10s, where many of them are also made in Thailand.)
On June 2, 2005, at Staples, IIRC, got the Maxtor 6Y060P0, (Singapore, IIRC) which is a 60 GB (7,200 RPM) DiamondMax 9 series, IIRC and it lasted a long time!Last edited by RJARRRPCGP; 06-24-2018, 10:31 PM.Leave a comment:
Ive been running Prime95 and S&M for the past hour... Its acting fine. Memtest is good.Leave a comment:
by federalhouseHi everyone,
I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
**Background:**
I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
**What I've Tried So Far:**
1. I accessed...1 Photo -
by reformattI thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...12-18-2024, 10:34 PM -
by perfm2So I've worked on dozens of HP and Dell laptops and have never encountered this before.
Steps taken in my usual process.
Reset security settings in the BIOS
Ensure existing HD comes up into the OS
Shut down the laptop and disconnected the main battery
Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
Replace battery connector and close up the laptop
Insert my USB drive with my Windows 10 image I've... -
This specification for the HP ProBook 430 G6 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 430 G6 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...09-06-2024, 08:50 AM
This specification for the HP EliteBook x360 1030 G3 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G3 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 1030 G3 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...09-06-2024, 08:50 AM
- Loading...
