Motherboard Quandary
  • SonicExplorer
    • Aug 2017
    • US
    Hi Guys,
    I have a bit of a dilemma and was hoping to get some advice from the forum. I need to rebuild a few XP DAW machines, which means the replacement motherboards are likely to be 5-10 years old to begin with. I'd like the machines to last another 10 years if possible, so I want to make a wise choice on boards.
    Is there sound evidence WRT the polymer vs. electrolytic cap argument such that I should be targeting only boards that have primarily polymer caps and claim high MTBF rates? For example, one group of Intel series boards I am looking at (DG41) offers a nearly identical board from each class. One claims 107,000 hours MBTF the other 270,000 MTBF. Does that actually assure anything in the real world or are electrolytic just as prone to potentially survive over a 15-20 year period?
    Anything else I should be watching for, or to avoid, WRT board selection as it pertains to life span?
    Thanks for any help in making a more informed decision.
    Sonic
    (PS. I understand XP is old but it works for what I need and I have a ton of complex software with a much time and money already invested. So buying new systems with a current OS and new software is not a viable solution)
  • Agent24
    I see dead caps
    • Oct 2007
    • 4951
    • New Zealand
    Re: Motherboard Quandary
    Polymer will last longer, supposedly, so they would be the logical choice.
    Make sure you use decent power supplies too, otherwise there's no point getting the best motherboard.
    Get boards made by decent companies in general too, avoid the awful ones like ECS. If your boards are made by Intel then you should be fine...
    -David VanHorn
      • 31003
      make sure you can get xp drivers for the chipset before you buy.
      what is the critical software?
        master hoarder
        • May 2008
        • 12170
        The rest of the build quality on the board matters a lot more than the caps. The caps can be replaced easily. A BGA chipset, on the other hand, is not so easy to replace.
        For example, avoid motherboards with nVidia nForce 5 or newer chipsets. Even nForce 4 is borderline playing with fire. The most reliable chipsets are Intel ones. For XP, I would go with i965 or DG31/33/41/45.
        Want to make the board last even longer? Then make sure the chipset runs cool. Add a fan to blow cool air on it, if necessary.
        Finally, make sure you are NOT using a stock Intel heatsink with push-pins, because they warp the board like crazy and break the socket BGA over time. Use an aftermarket cooler with a backplate and tighten the screws on the heatsink only enough to hold it in place. Anything more may warp the board again, because even some aftermarket coolers are not so well designed.
        • glovecaps
          by glovecaps
          11-25-2024, 04:23 PM
        • Docus
          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
          by Docus
          Hi everyone 😀,
          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
          1. I already own the exact same model, but its plastic chassis is badly damaged.
          06-10-2025, 04:24 PM
        • Archimedes
          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
          by Archimedes
          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
          Fans are spinning. Blindly could install windows11 and got the device manager...
          07-30-2024, 05:14 PM
          ASUS P5GC-MX motherboard recap
          by momaka
          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
          So here is what the motherboard looked like with its original caps:
          CPU VRM area up close…...
          01-27-2021, 11:59 PM
        • dhenion
          Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
          by dhenion
          I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
          The original board was:
          ASUS X510UNR REV 3.0 A
          The replacement board is:
          ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
          It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
          01-30-2024, 01:45 PM
