When a 10,000 RPM drive is not the best
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Out of curiousity, I decided to take a peek at how my different hard drives in my system compare, speed-wise. This is strictly a read test, as I do not have the full version of HD-Tune to be able to do a write test.
    What I found was a little surprising to me, in that my 10,000 RPM drive, which I figured would be best for my primary, was actually outperformed by a vanilla Seagate 80gb drive.
    On doing some research, I found that the Western Digital WD360 was the first 10k RPM drive WD released in SATA150. And there's the biggest difference... the 10k drive is 150, and the 80gb is 3.0.
    Numbers:
    10K WD drive
    Min- 25MB/Sec
    Max- 55MB/Sec
    Avg- 45.9MB/Sec
    Access- 9.5ms
    Burst- 88MB/Sec
    CPU- 18.8%
    Seagate 80gb 7.2k drive
    Min- 32.5MB/Sec
    Max- 70.2MB/Sec
    Avg- 57.5MB/Sec
    Access- 14.3ms
    Burst- 105.6MB/Sec
    CPU- 18.2%
    Now, obviously the access time on the 10k drive is much higher due to it's higher spindle speed. However, I was suprised to find that the Seagate beat it everywhere else!
    Ludicrous gibs!
  • Wizard
    • Mar 2008
    • 2296
    Re: When a 10,000 RPM drive is not the best
    What's the size of this 10K WD?
    Cheers, Wizard
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      It's a 36.7gb drive. It's a WD360GD-00FNA0 Raptor drive. Made May 18th, 2004
      The Seagate drive is a ST3808110AS
      Ludicrous gibs!
      • 370forlife
        Large Marge
        • Aug 2008
        • 3113
        Compare a WD 10K sata 1.5 to a WD 7.2K sata 3.0:
        My 320gb WD 7200rpm sata 3.0:
        min: 33.6MB/s
        max: 76.5MB/s
        Avg: 59.9MB/s
        Access time: 12.3ms
        Burst rate: 120.1MB/s
        • Wizard
          • Mar 2008
          • 2296
          This 36GB raptor is very old now and has low transfer speed due to lower density platters. This is the reason the 1 platter seagate 80GB is stomping on the 1 platter raptor, interface speed effects some.
          Now, if you compare with a VelociRaptor 150 or 300GB version to a 320GB one platter 7200, then you will see some difference but cost is 1 buck per 1GB. costly.
          Go with typical 32MB SATA 300 one platter 320GB or larger, costs around 60 or so these days, even for a Hitachi.
          Cheers, Wizard
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            Yeah, I understand the differences now that I've read up on the old WD drive. I guess my point just was that when I originally installed it in my system, I assumed 10k RPMs would be better than anything else for a primary drive. Not so... I'm now even happier with the 80gb drive as my primary
            Ludicrous gibs!
            • gdement
              • Jan 2007
              • 690
              Biggest downside IMO with 10k drives is that they definitely need a fan to run safely. I prefer doing that even with 7200rpm but at 10k it's a more serious issue.
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                Actually, according to SMART (and the highly scientific finger-tip test), the 10k RPM drive was the coolest running out of all three. Probably because my drive bays go like this:
                200gb maxtor
                Floppy
                250gb seagate
                empty
                10k rpm drive
                open space to the bottom of the case
                So, there's some airspace above it, and an 80mm case fan a little ways below it. But I've never had a fan blowing directly on it.
                Ludicrous gibs!
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Well, STR programs don't really show very much about how a harddrive performs
                  Instead look at the Storagereview performance database, check loading performance for really hughe games like World of Warcraft and Far Cry;
                  http://www.storagereview.com
                  But yea, that old Raptor isn't worth much today, which also clearly shows in the benchmarks
                  The latest Raptor is amazingly almost 2 times as quick as the old Raptor in these real world tests!
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    Seagate 7200.11 1tb
                    Min- 52.5MB/Sec
                    Max- 108.9MB/Sec
                    Avg- 84.1MB/Sec
                    Access- 13ms
                    Burst- 61.8MB/Sec
                    CPU- 0.9%
                    hey why my burst sucks?
                    • Harvey
                      • Apr 2007
                      • 264
                      It shows how much of a difference areal density makes:
                      HD Tune: Hitachi HDS721616PLA (A 'fast' 160GB drive when it was new, ~3 years ago)
                      Transfer Rate Minimum : 32.1 MB/sec
                      Transfer Rate Maximum : 74.2 MB/sec
                      Transfer Rate Average : 56.1 MB/sec
                      Access Time : 16.0 ms
                      Burst Rate : 156.2 MB/sec
                      CPU Usage : 2.7%
                      HD Tune: Hitachi HDP725050GLA (A 'slow' 500GB media storage/quiet drive)
                      Transfer Rate Minimum : 47.2 MB/sec
                      Transfer Rate Maximum : 91.8 MB/sec
                      Transfer Rate Average : 75.1 MB/sec
                      Access Time : 18.6 ms
                      Burst Rate : 176.7 MB/sec
                      CPU Usage : 3.0%
                      - the 500GB cost less than half the [actual] price of the 160GB
                      • zandrax
                        Hit and miss
                        • Dec 2007
                        • 1157
                        • Italy
                        Early Seagate 7200.11 drives with 32 MB of cache had a lot of trouble with cache: first firmwares seemed to disable it or, at least, motherboards were unable to detect it and reported 0 MB, decimating transfert rate. Updating the firmware should solve the issue.
                        Zandrax
                        Have an happy life.
                          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                          09-12-2024, 02:00 PM
                        • federalhouse
                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                          by federalhouse
                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                          **Background:**
                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                          **What I've Tried So Far:**
                          1. I accessed
                          08-01-2024, 07:03 PM
                        • reformatt
                          Intel iMacs, 3rd party SSD failures and Fusion setups
                          by reformatt
                          I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                          As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                          So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                          12-18-2024, 10:34 PM
                        • perfm2
                          HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
                          by perfm2
                          So I've worked on dozens of HP and Dell laptops and have never encountered this before.
                          Steps taken in my usual process.
                          Reset security settings in the BIOS
                          Ensure existing HD comes up into the OS
                          Shut down the laptop and disconnected the main battery
                          Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
                          Replace battery connector and close up the laptop
                          Insert my USB drive with my Windows 10 image I've...
                          03-21-2023, 08:45 PM
                        • karto95
                          Repairing a Seagate hard drive with damaged logic board
                          by karto95
                          I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                          I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                          If anyone has any suggestions or experience with this...
                          03-21-2023, 04:05 AM
