Ratdude's 3U Server Shenanigans
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Ratdude's 3U Server Shenanigans
    Ordered PCBs... trying easy EDA this time since the per-PCB price was slightly better. Hell, I ordered 10 of them and also 10 of another project of mine some of us know about and DHL flat rate was still more expensive. As for the other project, I've used up all 3 of the OSH park PCBs from that project (Main rig v3.8, v4.1, and one hand delivered in a kit to Topcat a few visits ago) and my PCB milled V0.1 version (single sided PCB with jumpers, used to test my college's PCB mill) is too special to use. Also I have a surplus of the switches and dual pin headers, so I might as well whip up a few more (read: if you own a supermicro case/board combo and want to remap your HDD or NIC2 LED, PM me ).
    sigpic
    (Insert witty quote here)
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Look what I found:
      http://www.ebay.com/itm/Vericom-Glob...IAAOSwTqdZsIhZ
      From what I can research that's legit copper Cat5e, not CCA (copper cladded aluminum) horsesh!t. Unless they're lying about the part number, in which case I'll be getting a refund.
      Hopefully I made a good gamble...
      sigpic
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Time has passed, I now have a house, and this thing is just too noisy.
        I'm biting the bullet and re-fanning it using some Arctic Cooling F8's.
        Too bad the stupid fan controller idea didn't work... I may revisit it again. IDK.
        sigpic
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Head scratcher:
          Lately (hot no A/C office closet) this thing will randomly die. Upon reboot, it's giving a bunch of beeps. I'm guessing that it's the "8 beep" Video memory fault... bad BGA joints on the mobo?
          Anybody seen this before? Maybe an excuse to get a new board//platform for the beast???
          sigpic
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Head scratcher:
            HEY MORON, CHECK THE PSU!
            Well, she died in a storm (or a momentary loss of power).. this time, power on, immediatly shuts down. Sounds like a PSU issue, right? Well, let's take a look:
            This server uses a redundant pair of Etasis PSUs:
            Unlike my SM 1U modular supplies, these supply all ATX voltages (and raw line voltage too ). Not just a massive 12V rail that is stepped down (buck converter) in the secondary
            Oddly they installed heatsink screws under the label:
            And no, this wasn't to double as a warranty void sticker. they had one of those over another screw. Not that 2003-2005 server has any warranty left for that matter
            Anyway, lets look at the secondary:
            Well there ya go, dumb*ss. So much for "Teapo's are OK in PSU's"... obviously not here! This would explain all the random errors.. hell that might have been the backplane fauting due to one PSU failing (it will not run without both installed).
            I didn't get pics, but the other PSU was worse.
            Side note- unlike most PSUs I've worked on, this one actually uses a replaceable fuse:
            A week later and all is better:
            I mostly used Panasonic FR's for this. Normally I do PSUs in Nichicon HE, but the 10V 2200uf options they have are all too fat or too tall to fit. One value wasn't available in the form factor I needed, so I used some Illinois Capacitor's.
            This PSU was a PITA to recap... especially the aformentioned 10V 2200uf's some of which were wedged under the lip of the heatsink... ugh. I got the job done, but not the cake walk PSU jobs usually are.
            Reassembled and reinstalled... she's alive again!
            Lesson learned: Kill Teapos with fire. All of them.
            sigpic
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              After 10 years around this site, and it took you this long to figure this out? THis should have been one of the first things you check....and I've told you many times that Teapo is trash....Trust them no more than you trust a politician!
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • dmill89
                • Dec 2011
                • 2534
                There are a few caveats to that. Teapo's are generally ok (but not ideal) in normal ATX PSUs used for the "normal replacement intraval" (generally 3-5 years, though I have seen much older Teapos as long as they aren't too stressed), but in a 10+ year old 1U PSU (most of which could double as a toaster/space heater) it isn't surprising to find them failed.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  I got lazy.
                  sigpic
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    #69
                    Best quote I've seen in quite a while on this site!
                    • omega
                      Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                      by omega
                      Hello all,
                      as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                      Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                      02-09-2024, 03:34 PM
                      by momaka
                      03-12-2025, 03:42 PM
                      HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
                      This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
                      09-06-2024, 11:39 AM
                    • harp
                      Comparing FreeNAS, FTP server, SMB server, multimedia server...
                      by harp
                      I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
                      I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
                      Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
                      What is general difference between this products, and what be most useful...
                      01-04-2024, 02:44 PM
                    • Fireballcz
                      Windows 2016 server L2TP/IPsec VPN - two subnets
                      by Fireballcz
                      Hello, please how to properly configure VPN in this environment?
                      I have two subnets in two different (geographical) workplaces, connected via IPsec (thru gateway routers)
                      Main subnet: 192.168.11.0/24, gateway (router IP) 192.168.11.1, Windows 2016 server (VPN, DHCP, DC etc.) 192.168.11.3
                      2nd subnet : 192.168.22.0/24, gateway (router IP) 192.168.22.1 - just client computers.
                      I need to allow external (home office) users connect via VPN server (192.168.11.3) to the 2nd subnet (192.168.22.0/24) to their computers (via RDP).
                      I have no problems with VPN connection...
                      07-29-2022, 03:20 AM
