Dell set to cut 1,900 Irish jobs
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Computer giant Dell is to cut 1,900 of the 3,000 jobs at its manufacturing site in Limerick in the Irish Republic.
    Dell said the move - which will see production moved to a new factory in Poland - was part of a $3bn global cost-cutting effort. full article
    BRUSSELS, Jan 8 (Reuters) - The European Commission said on Thursday it was investigating 52.7 million euros ($71.4 million) of aid given by the Polish government to U.S. tech company Dell's (DELL.O) Polish unit.
    "The EU Commission is undertaking an in-depth investigation ... into 52.7 million euros aid for a project of Dell Products Poland for the establishment of a new manufacturing plant in Lodz (Poland)," the EU executive said in a statement. (Reporting by Darren Ennis, editing by Dale Hudson)
    sad thing is that all these newer entrants to the eu, production shifts there cos cheaper. makes one wonder wtf the purpose of eu is. nation on benefits?
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • master3112
    by master3112
    07-29-2025, 01:55 PM
  • F R 2568
    Dell Latitude 5420 does not start (no post) need help to find the reason why
    by F R 2568
    Hello all,
    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
    If the laptop is only connected to the AC adapter (battery removed):
    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
    The power/battery...
    01-08-2025, 05:45 AM
  • diamon
    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
    by diamon
    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
    Pictures of these boards:
    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
    Dell...
    02-28-2024, 12:51 PM
