.....hmmmm.....
Project : Tillamook
Project : Tillamook
<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsTags: None -
Team : 49813
Join in!!
Team StatsComment
Permanently Retired Systems:
Kooky and Kool Systems
sigpicComment
Re: Project : Tillamook
IDK man... I've had some cool routers. Plenty of IO and nice large EEPROMs. slap WRT on them and you have a dev environment that could compete with a Pi!Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
The CPU is too weak for anything serious, but good enough for a basic web server and BIND DNS.Last edited by ddscentral; 06-28-2017, 05:25 PM.Comment
What package and chip is it?
300MHz Tillamook overclocked too 350?"The one who says it cannot be done should never interrupt the one who is doing it."Comment
Team : 49813
Join in!!
Team StatsComment
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
Its flawlessly stable @ 350/100. The goofy part is the multiplier is 4, but this board isn't recognizing it at that. Even at 66FSB, it only post's at 233, not 266. Board is a Mitac 5114VU super7... I would love to see this thing run at 400/100, and the Tillamook CPU is known to be able to do it. Super7 boards can be loads of fun....I ran a P55C 166MMX @ 250/100 with no issues at all. XP was a bit overwhelming for it, but W2K ran quite nice. The ulterior motive here is a win9x/DOS game experiment.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
And even on a socket 462 Athlon, I could feel a difference between Windows 2000 and Windows XP... Windows 2000 benched better...Last edited by RJARRRPCGP; 07-01-2017, 02:25 PM.ASRock B550 PG Velocita
Arc A770 16 GB
because Windows 2000 wasn't as bloatedDon't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpicComment
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by sam_sam_samRight now Battery Hookup has these e-bike battery packs that are used but I am going to remove them and test them and see how good they are and maybe resell or reused them for another project this is for another day
When I get the rack mounted enclosure that I mentioned in another post I will see how well they fit in the enclosure and how much room I will have left
https://batteryhookup.com/products/3...ttery-with-bms
These battery packs are a little bit hard to get out of the enclosure because they were a little bit glue... -
by BladibladI have an interesting project here. I have a HP RTX 3060 12GB VRAM GPU with a shortcircuit between a (what I believe is) a coil and a cap. The short circuit is so bad that it will trigger a failsafe on the PSU.
I'm a beginner in this field and have managed to do only very simple board repairs so far. I have basic understanding of the components (mosfets, caps, nand chips) but completely diagnosing a board with schematics would be challenging. In this case though, I'm going to hope that replacing only the two shorted components will bring the card back to life (if none of the IC's... -
by EasyGoing1So based on some of the comments in my other posts, there seems to be some confusion or maybe some assumptions, I'm not sure exactly, so I wanted to hit the reset button on the entire discussion and make a few things clear that might not have otherwise been obvious.
First of all, the reason I post in this forum is that I simply do not have enough knowledge in electronics to do some things that I would like to do. So I post my questions in here and I try to be as thorough as possible MOST of the time, so that those of you who do take the time to respond, will be as informed as possible... - Loading...
