Socket 478 pins
  • stevo1210
    • Oct 2006
    • 4156
    Socket 478 pins
    I picked up a Celeron D 2.53Ghz socket 478 CPU from the e-waste recycling plant yesterday for 50c.
    It had a lot of bent pins and I managed to straighten out 99% of the bent pins, except one which broke. It's in the closest line to the center of the CPU. I still have the broken off pin here and I think the solder pad went with it as well because I dont see any silver bit remaining on the CPU as it's stuck to the gold pin that broke off. So I'm looking for a schematic of the socket 478 CPU off the net to try and determine if this pin is just a common ground pin or if it's an important pin to the CPU.... is there a schematic of the socket 478 CPU anywhere on the net?
    Otherwise, if I can't fix it, it will become a wall decoration.
    Thanks.
  • kikkoman
    • Jul 2007
    • 691
    Re: Socket 478 pins
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      Re: Socket 478 pins
      if you are lucky that pin is a redundant vcore or ground.loss of 1 wont stop it from working.
      • stevo1210
        • Oct 2006
        • 4156
        Re: Socket 478 pins
        Missing pin is labelled as "M6" on the diagram. It is a source/synch pin. I guess it's pretty much screwed up isn't it?
        • PM650
          • Dec 2008
          • 37
          Re: Socket 478 pins
          M6 is #8 address line, certainly not redundant, unfortunately.
          "A[35:3]# (Address) define a 236-byte physical memory address space. In subphase
          1 of the address phase, these pins transmit the address of a transaction.
          In sub-phase 2, these pins transmit transaction type information. These signals
          must connect the appropriate pins of all agents on the Pentium 4 processor in
          the 478-pin package system bus."
          • kiddznet
            • Jul 2010
            • 176
            Re: Socket 478 pins
            As a noob and with nobody to tell me different I found that using a hobby knife blade is about the thickness between pins, and just gently leaning the blade against the bent pin rows works for me
            I've managed to recover some horribly mangled P4s this way
            939 DualCore AMD Opteron, 1800 MHz (9 x 200)
            Abit AN8 / Fatal1ty AN8 SLI Series
            3072 MB (PC3200 DDR SDRAM)
            ATI Radeon HD 4300/4500 Series (1024 MB
            Lian LI Aluminium mesh case
            • tiagooliveira95
              My first attempt at board repair - Asus Prime X670-P
              by tiagooliveira95
              Hey everyone
              I decided to dive headfirst into board repair. I'm a computer engineering student, and I'm attempting to fix my first board.
              I have made some progress, and I feel super excited. Still haven't fixed the board tho, but I decided to make a post here to share my progress.
              This is an X670-P, seller stated bent pins and no power on, the socket has 2 bent pins, the pins are slightly bent upwards (VSS and a Channel A pin), so it's an easy fix, don't even need to replace the socket, tested all power rails on the CPU and found no shorts, the bent pins...
              08-22-2025, 08:20 PM
            • DynaxSC
              Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
              by DynaxSC
              I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
              I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
              Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
              Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
              05-04-2025, 12:08 PM
            • moritz1992
              iMac 27" Retina 5K i5 3.2Ghz no chime, no display, LED 1 and 2 on
              by moritz1992
              Good evening guys, im new to this forum and searched around it to find a way to fix my broken imac 27 retina late 2015. Logic Board is 820-00292-A
              Here“s the problem :
              After i changed the blade ssd with an NVME SSD and accidentially bent some cpu socket pins (managed to get them straight up again, one pin broke but seems to be N/C) while trying to get some fresh thermal paste, i hear no chime and have no display. LEDs 1 and 2 are green but 3 and 4 not. I did some measuring and it seems that gfx_ok, is ok but dp_ok, is not okay. Checked some caps and diodes in circuit but everything...
              11-04-2023, 06:25 PM
            • Isabella91
              Possible to convert eMMC Socket to a micro SD Card socket?
              by Isabella91
              I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
              Read/Write a Micro SD Card from an eMMC Socket.
              I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
              Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
              Not to remove...
              01-14-2024, 05:10 PM
            • langbaobao
              DIY 3D-Printer WSON8 Pogo Pin Adapter
              by langbaobao
              Hi.
              I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
              I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
              01-08-2024, 05:58 PM
