March's windows 7 update KB4012215 might cause a false postive in MSE
  • R_J
    • Jun 2012
    • 9588
    I just did a mse quick scan on windows 7 Ultimate 64bit with MSE and got the "Preliminary scan results show that malicious or potentially unwanted software might exist on your system" and nothing in the Quarantined or All detected items. Seems I'm not the only one http://www.geekstogo.com/forum/topic...ostive-in-mse/
    I did a system restore to before that update was installed and the false positive is gone, I guess M$ is making things hard for anybody not moving to 10.
    I did find that as soon as it scanned svchost the notice came up. Adding wininet.dll to the Exclude files did not give the false positive when the kb4012215 was installed and the scan run.
    Hope this might help someone that runs across the same issue
  • akwky
    by akwky
    Hi!
    04-14-2025, 01:56 PM
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
  • lordgeny
    z490-f gaming bricked after bios update
    by lordgeny
    I had to assemble a PC with this Z490-F Gaming motherboard and an i7-1700K CPU. Upon the first boot, the CPU LED was red and flashing. I realized that I needed to update the BIOS. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site, and update ME firmware to Version 14.1.53.1649V1.1 to ensure optimized system settings." I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. My attempts to reflash it were unsuccessful. Searching online,...
    11-02-2023, 09:03 AM
  • iMuhtaseb
    A1706 2017 critical update
    by iMuhtaseb
    this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
    we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
    One weird symptom is it takes too long to power on and show the Apple logo for some reason..
    I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
    08-13-2024, 08:41 AM
  • al3m0di
    Update bios EFCN58WW to EFCN59WW
    by al3m0di
    Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
    I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
    The BIOS version is EFCN58WW.
    When I turn on the device, it displays the message:
    "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
    The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
    I've tried
    07-29-2024, 10:32 AM
