Motherboard or IMC
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Motherboard or IMC
    Wierd customers motherboard, possibly CPU issue. After all the troubleshooting I ended up with this:
    If you move the memory to a different slot, it boots. If you turn it off, it dosen't come on, and the system speaker makes a click every few seconds
    move it to a different slot, it comes on, turn it off, same thing. Added a stick of my own to the 8gb that it had, comes on. turn off, dosen't come back on. Take my stick out, comes on, I turn it off, it refuses to post, and clicks from the sys speaker every few seconds
    so basically, ANY change in memory location, size, stick, and it will boot, till you turn it off, then, no post (powers on, intel fan spins down properly). but no video, no HDD access, have to keep the power button down for it to turn off.
    could the cpus integrated memory controller be to blame, or is this motherboard? Its about a year old
    gigabyte b85m-ds3h-a, looked it up, could not find anyone else with this issue
  • cpt.charlie
    • Sep 2013
    • 270
    • Spain
    Re: Motherboard or IMC
    I would consider a bios update and reset just in case.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      well spank my ass and call my charlie, a bios update worked. Thanks!
      not sure why this started, it worked fine for a year
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3264
        • Singapore
        check the power supply as always. noisy power supplies esp. on the minor rails can cause flash rom corruption. that seems to be the issue with power supplies nowadays. everything is on the 12v rail and nobody bothers with designing the minor rails to deliver good clean power anymore.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          It has an EVGA 430w, which has a pfc for whatever that is worth on this thing. CapXon mains and some fair mid-stage caps
          the surge protection isn't even complete it has the caps but no MOV (saw on review)
          it has good ratings on newegg and other places. Still. If this continues, I'll replace it, hopefully if it does it again the corruption is not to the point I can't flash. Though i'm sure it has a flash recovery like renaming the file modelnumber.xx and burned to a cd or dvd
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • fixme2024
            Intermittent Power Issue with HP DV6 Motherboard Occasional Failure to Turn On
            by fixme2024
            Hello everyone, I have an HP DV6 DAOLX6MB6F2 REV: F motherboard. The issue I'm facing is that sometimes the motherboard doesn't turn on. I've checked the voltages for the power on button panel, and they seem to be okay. Right now, it's working perfectly fine, so I can't pinpoint the exact problem. I have the HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2 Rev 1A.pdf schematics, a multimeter, and a 5A power supply. If anyone could guide me on where to start checking first, I would greatly appreciate it. This is my first experience with this. Thank you.
            Here, I have attached a document...
            02-14-2024, 09:24 PM
          • glovecaps
            Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
            by glovecaps
            I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
            My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
            The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
            11-25-2024, 04:23 PM
          • Docus
            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
            by Docus
            Hi everyone 😀,
            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
            1. I already own the exact same model, but its plastic chassis is badly damaged.
            06-10-2025, 04:24 PM
          • ryogadan78
            iMac A1311 - Motherboard 820-3126-A, turn on sometimes
            by ryogadan78
            Hi guys, I have this 2011 iMac A1311 with a strange problem.
            Most of the time, when I plug in the power cord, the first of the 4 LED's turn on, but when I press the power switch the LED turns off and iMac won't boot up.
            Sometimes, when I unplug and plug the power cord back in, iMac starts up correctly by turning on the 4 LEDs in sequence.
            I have already tried a new power supply, but the result does not change. Do you have any suggestions?
            Motherboard 820-3126-A​
            04-06-2024, 05:19 AM
