Is there any reliable way to determine the number of layers on a PCB??
PCB layers
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
by WillowfixHi
i have a a2179 which is locked. On the other hand I have an unlock t2chip(just the upper layer of ic)I wanna know if I can just change the upper layer of the t2 chip.
any way does anyone know what each layer do?08-03-2024, 01:46 AM -
by tongshadowI got this set for very cheap, it works perfectly but the catch is that the protective coating was damaged. About 45% of the screen had a green tint, you can see exactly where the layer changed colors to a blueish tone (that actually makes everything green).
"Ok, that's probably just the anti-glare layer" - I thought. So using a microfiber cloth and automotive metal polish I was easily able to turn it into a nice mirror.
Unfortunately, the damage was beyond this layer and everything still had a horrible green tint. I initially... -
by 13mh13The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
https://i.postimg.cc/kGrR6BpZ/image.jpg
I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
I have not tested/replaced those alum. SMD electro PCB caps.
Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
All the thru hole electros I removed / replaced on this CDP (and most...-
- Loading...
