A2179 t2 upper layer replacement
  • Willowfix
    • Aug 2024
    • canada
    Hi
    i have a a2179 which is locked. On the other hand I have an unlock t2chip(just the upper layer of ic)I wanna know if I can just change the upper layer of the t2 chip.
    any way does anyone know what each layer do?
  • spleenharvester
    Whirlpool PACF212HP W portable air conditioner, upper fan only turns slowly.
    by spleenharvester
    I just acquired this portable aircon, history unknown. Its behaviour is quite strange:
    • When turned on and placed into cooling mode, the upper fan (cold air out) just spins slowly. The compressor and lower fan do not run.
    • If the device is then placed into heating mode and then back into cooling mode, the lower fan and compressor kick in and start cooling, but the upper fan still only spins slowly.
    • If the device is placed into fan-only mode, the upper fan does not respond to low/medium/high speed toggles - just keeps running slowly.
    • Display and buttons all behave normally aside from the
    06-27-2025, 07:49 PM
  • Darren Hibbert
    MacBook A2179 Audio board+Power button boardview & schematic needed
    by Darren Hibbert
    Hi.
    Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
    There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
    Many thanks. ...
    08-21-2025, 02:38 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • ezenia
    PS4 controller left stick potentiometer replacement issue
    by ezenia
    Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
    So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
    I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
    09-30-2023, 02:19 PM
  • boosti45
    Macbook pro logic board replacement parts quesion
    by boosti45
    i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
    08-21-2024, 05:23 AM
