Pionner DVR-109 issues.
  • stevo1210
    • Oct 2006
    • 4156
    I recently bought a Pioneer DVR-109 DVDRW drive that was sold AS-IS for $10. It works and reads every disc I chuck at it and also burns discs from what I can remember. But there's a problem with it and I dunno if it's serious but it's downright annoying. When the drive reads a discs or spins up a disc there's this noise that comes out of the drive that sound like it wants to fall apart and set itself on fire. I can hear very loud crunching noises coming out of it. It sounds like when you get two plastic gears, one being still and the other moving and forcefully scrape them together. Or like when you shift into the wrong gear in a car. Like from gear 4 to gear 3 at high speed in a manual car. But anyway, does anyone know what might be wrong with it or at least a solution which I can use to fix the drive. I know it works and reads discs but that scraping noise inside it is so loud and so annoying. Also it makes me very nervous and anxious when I use it because I don't know if it's going to start ruining my discs or setting itself on fire.
    Thanks.
  • Wizard
    • Mar 2008
    • 2296
    Re: Pionner DVR-109 issues.
    Open it up and check microswitches for drawer and optical transport mechanism. Clean and lube.
    It can be optical sensor as well.
    Otherwise trash if you was able to check out the mentioned sensors and they function but problem is uncorrected.
    Cheers, Wizard
    • zandrax
      Hit and miss
      • Dec 2007
      • 1157
      • Italy
      @ stevo: First try reducing rotational speed at 2x for DVDs and 12x or slower for CDs with Nero DriveSpeed: the noise should be way less audible and irritating. Then follow Wizard instructions, but be aware that the Pioneer may be defective or worn if the noise you hear seems due to difficult readings or continuous head repositioning.
      I have an old Sony CDU-624 cd player which does the same trick and in my case it was unable to read correctly the disc: I tried cleaning the inside and lubing head rails without success; I even cleaned the laser without notable improvement. At the end I got it: the main motor was slightly out of axis so the laser had trouble in reading the whole cd because it changed position everytime; it may read the TOC and some files, but not anything else.
      Zandrax
      Have an happy life.
      • gretti
        MSI Z370-A Pro, works but does not power off or reboot and USB issues
        by gretti
        I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
        The MSI BIOS included the ME firmware for the board. The size...
        10-16-2025, 02:14 AM
      • render1967
        Problem with the Logitech G27 gaming steering wheel gear lever
        by render1967
        Hello! First, please excuse me if my English is not good enough because it is not my native language!
        Now let me describe my specific problem. For two days, the gear lever on my Logitech G27 has shown the following defect. When switching in the game (for example ETS2) it often does not detect 1st, 3rd and 5th gear - in these positions it shows neutral or flashes between the specific gear and neutral (for example - 1st <> neutral). When I press the gear lever to the left or right while it is in a position, it still manages to guess the gear and engage. In addition, instead of rear...
        11-13-2021, 01:35 PM
      • SoulFreeze
        Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
        by SoulFreeze
        Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
        After repairing the above issue, I realized the following remaining problem,
        Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
        The computer recognizes headphones are connected and displays a popup in windows
        Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
        06-21-2025, 09:53 AM
      • Nagyesz
        Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
        by Nagyesz
        I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
        All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
        How can I extend its lifespan? Could reflow help?
        It has ryzen 5 5500h, rtx 2050, no soldered ram.
        Example of the artifacts:
        03-01-2025, 11:11 AM
      • pwnjuice
        Bitlocker issues
        by pwnjuice
        Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
        Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
        Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
        01-06-2025, 05:33 PM
