V5-573G upgrade from WXGA screen to WUXGA
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    So, I've got this laptop with a cracked screen and would like to order a new screen. Was thinking about upgrading it while I am at it.
    There are already FullHD versions of this laptop so I know it's possible.
    My question is, do I need to change the cable too or the current cable works with FullHD panel aswell?
    This laptop uses eDP, not LVDS.
  • cpt.charlie
    • Sep 2013
    • 270
    • Spain
    Re: V5-573G upgrade from WXGA screen to WUXGA
    i guess it should work, however i don't know if the LCD pinout is the same for all manufacturers, have a look to the datasheet first.
    • RethoricalCheese
      • Mar 2013
      • 1517
      • Estonia
      eDP seems to have a standardized pinout, unlike LVDS.
      Did some further research. Didn't find a 100% sure answer about my particular laptop nor its cable but similar Acer products didn't need cable replacement when upgrading.
      So I think I will just order a new 15.6" eDP FullHD Matte IPS panel later.
      • RethoricalCheese
        • Mar 2013
        • 1517
        • Estonia
        Got the new screen. Works perfectly without changing cable.
        • rioreno
          • Feb 2009
          • 540
          • Indonesia
          nice... would you post your led type/brand before and after you changing??
          thanks
          • RethoricalCheese
            • Mar 2013
            • 1517
            • Estonia
            Original HD screen was N156BGE-EA1 rev. C1
            And well, I did not check what was actually written on the back of the FullHD screen but invoice says it's B156HAN01.2 (and it probably is)
            • rioreno
              • Feb 2009
              • 540
              • Indonesia
              thanks for the information...
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • smic717394
                by smic717394
                07-25-2024, 10:16 AM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • spice_disc
                Vizio TV M50-C1 reboot cycle and static on screen
                by spice_disc
                I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                09-08-2024, 02:37 PM
              • ipatch
                ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                by ipatch
                i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                08-24-2024, 02:36 PM
