bought 2 Dell E172FPB computers both would not power on... I took them apart and went through them step by step removing the components trying to see what was wrong with them.... When i remove the ribbon cable that goes to the lcd screen the back light comes on and is nice and bright. When i put it back on i get no power.. Is that the video card? I tried both video cards from both monitors and they both did the same thing...also tried both screens. Any suggestions? Thank you very much.
Dell E172FPB Lcd Help!
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
by SMDFleaDell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
Some models have a choice of 2 different firmwares, it depends on the dell SKU.
The SKU is in brackets (****)
EDIT: NVM65...-
by dell_sadnessBIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
Have extracted the BIN and want to know how to rebuild a clean BIOS
I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...-
- Loading...
