I opened my inbox folder in MS Outlook, an error appeared: FileName.pst file could not be opened. I applied scanpst tool, it didn't recover all the data for 100 percent. Does someone restore outlook by any method?
Outlook .pst 2016
Re: Outlook .pst 2016
ScanPST helps only in a half of cases at the best, for other situations, you must have backup copy of data or another machine or another version of program.
In the event if you don't have one of such conditions to get your data back is heavy task, but you can use alternative way Outlook Restore Toolbox, I called in that manner, because such tools are applied only in impossible cases, you make sure of on https://www.restoretools.com/outlookrestore.htmlComment
The Inbox Repair Tool may need to be run several times in order to fully repair your personal folder (.pst) file.
this is from here: https://support.microsoft.com/en-us/kb/272227
Not sure if you read it but maybe it can help.Comment
This specification for the LENOVO S510 + Office 2016 Home & Business can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the S510 + Office 2016 Home & Business boardview and S510 + Office 2016 Home & Business schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...09-12-2024, 01:58 PM
by Flasman90I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
- "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
- "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
...08-30-2025, 10:27 AM -
by iMuhtasebA2338 - Pristine condition.. I took out of the board and inspected it.. nothing.. as if the computer is barely used even.
Anyway, customer said they tried erasing/formatting it and it got stuck on Apple logo preventing to go further.. I asked them why they tried to erase it from the first place? They said it turned off randomly once.. then they erased it and it worked out for a few days then it shut off again..
I put the computer in DFU; I downloaded the latest Ventura IPSW and restored it.. during the "Installing.." it restarts then it shows the exclamation...09-11-2023, 08:43 AM -
by lab10.haifaGood day, friends. Got this problem with M1 macbook - it starts, chimes, tries to boot and stuck with a message "support.apple.com/mac/restore"
It works with DFU mode, but it's cannot be restored. With "revive" function - same problem. Internal restore mode doesn't work, as well as Internet Recovery.
There is no damage on the motherboard. No short circuits.
Could it be a NAND problem? (but usually, if NAND is dead - mac simply wouldn't turn on)
Thanks....10-08-2025, 02:55 AM -
by yheriatovychHi. I need some help troubleshooting the issue (which is a bit odd to my limited experience) with the A2338 Macbook.
Initial symptoms:
One day the laptop refused to wake up (as it seemed at first), spinning the fan on full blast, with no picture on the screen.
Force rebooting didn't help. To check if it boots at all I connected the external display and surprisingly it booted to the system, and I was able to log in to the system.
However, I noticed that it was in some weird state:- The fan was still blasting at full speed. It's blasting even when the system
- Loading...
