Does anybody know the approximate stock VID for an Intel QX9770??
    Reason for this question is that I'm wondering how close i'm running to Intels 136W rating for the QX's TDP, with my Q9450 at 400*8, 1.300VID, which gives about 1.26 Vcore idle, drooping to 1.18/1.20 under full Prime95 loading on all 4 cores.. I mean it's fun getting the performance of a $1500 CPU from a $330 one, but then again it's getting kinda hot, and i think i need a better heatsink to fit in my MicroATX chassis... Right now i have a Scythe Ninja Mini with a 80mm PWM controlled fan, which promptly revs to its full 3500 RPM rated speed under full CPU load..
    Re: Does anybody know the approximate stock VID for an Intel QX9770??
    VID range for these processors is 0.85v - 1.3625v.
    A quad core on a Ninja Mini? Wow. I hope you have some good ventilation in there!
    Maybe a better fan? You are running PWM, so it shouldn't be that obnoxious unless you really load down the system:
    http://www.newegg.com/Product/Produc...82E16835221002
    A man convinced against his will is of the same opinion still.
      http://www.newegg.com/Product/Produc...82E16835101026
      Good heatsink, small enough to fit in a micro atx case.
