Does anybody know the approximate stock VID for an Intel QX9770??
  • gg1978
    • Dec 2004
    • 431
    Reason for this question is that I'm wondering how close i'm running to Intels 136W rating for the QX's TDP, with my Q9450 at 400*8, 1.300VID, which gives about 1.26 Vcore idle, drooping to 1.18/1.20 under full Prime95 loading on all 4 cores.. I mean it's fun getting the performance of a $1500 CPU from a $330 one, but then again it's getting kinda hot, and i think i need a better heatsink to fit in my MicroATX chassis... Right now i have a Scythe Ninja Mini with a 80mm PWM controlled fan, which promptly revs to its full 3500 RPM rated speed under full CPU load..
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Does anybody know the approximate stock VID for an Intel QX9770??
    VID range for these processors is 0.85v - 1.3625v.
    A quad core on a Ninja Mini? Wow. I hope you have some good ventilation in there!
    Maybe a better fan? You are running PWM, so it shouldn't be that obnoxious unless you really load down the system:
    http://www.newegg.com/Product/Produc...82E16835221002
    A man convinced against his will is of the same opinion still.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      http://www.newegg.com/Product/Produc...82E16835101026
      Good heatsink, small enough to fit in a micro atx case.
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • AkaBukai
        Is it okay to flash stock bios onto the motherboard's BIOS?
        by AkaBukai
        Hi there,
        I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
        The little LED on the power button is flashing slowly and nothing happen.
        This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
        So I decided to flash the BIOS using a cheap programmer.
        And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
        I also...
        12-19-2024, 12:15 PM
      • ignacio.ino27
        (BIOS) Asus X541UVK Rev 2.0. Stock ME REGION
        by ignacio.ino27
        I share with us this binnary file that i have edited the ME Region (from original dump version to stock 11.6.0.1126).
        It is "stock" region and working.
        BIOS: X541UAK.306
        MOTHERBOAD: X541UVK Rev. 2.0
        CPU: Intel Core i3 7100U Kaby-Lake R
        ║ Family │ CSE ME ║
        06-08-2021, 05:39 PM
      • tbsmith
        Ninja DCT401 Double oven/air fryer Possible microprocessor issue?
        by tbsmith
        I'm having a random issue with this otherwise nice double oven/air fryer. It sometimes does not respond to the controls. Sometimes only the upper control buttons work, sometimes they all work and sometimes none of them work. The power supply is good as the control board has a steady 5V and 3.3V. The pushbutton switches are all good as tested with multimeter. When the buttons are working, there is about 2.5V to the high side of the pushbutton. I'm assuming pressing a button grounds the input pin to the microprocessor. When the buttons are not working, there is about 0.3 volts on the high side....
        07-12-2025, 11:40 AM
