Building an auto shop computer
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    I am doing work for an auto shop replacing their gx620's with core i3's and samsung ssd pros with msi m4 class motherboards.
    They want to replace the one in the shop that is inside a cabinet. With texas heat I am concerned. I know the msi military 4 boards can take more than usual heat. But power supplies, and the Dell screen that suprisingly still works
    Anyone have a good solution for this heat situation?
    • 31214
    Re: Building an auto shop computer
    fans - lots of 120mm fans blowing into the case.
    and filters on all the fans.
    that way you have constant airflow and no dust / paint-particles etc getting inside.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      msi makes good boards. i use them almost exclusively. anyway, i don't think you have to worry about it. 2nd gen+ i3s create so little heat and with an ssd power draw will be very low.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        besides heat, out in a shop, you will get a lot of dust & dirt.... take it from me, I have to blast mine with the air hose atleast twice a year....but to conquer heat, airflow is the only answer.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          theoretically wouldn't the opposite be better? a fanless pc? then the dust will not be an issue.
          http://www.amazon.com/SeaSonic-SS-40...dp/B003ZWQXUQ/
          http://www.amazon.com/ZALMAN-Ultimat...dp/B00CEQXLV8/
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            ...but then the heating problem is amplified a tad... A PC enclosed in a cabinet in a garage in texas heat would be miserably hot
            Team : 49813
            Join in!!
            Team Stats
            • dmill89
              • Dec 2011
              • 2534
              ^This, no airflow in an enclosed cabnet in an un-airconditioned garrage is going to cook. The PSU is probably the biggest issue, an I3 with an SSD shouldn't produce much heat, but even with a low load the PSU will get tosty with no airflow (note: most "fanless" PSUs are really designed to be used in a case with atleast one fan, so there is at least some airflow).
              I'd stick with components rated for higher temps, a nice big heatskin for the CPU, and use fans sparringly (probably just the one in the PSU, CPU fan and 1 case fan should do, or maybe you can even skip the case fan, especially is the PSU has a 120mm+ fan) , and use filters on the intake vents, cleaning a filter a couple times a year is alot easier then opening the PC and cleaning the inside (especially for an end user that may not be very "computer savy").
                • 31214
                i have worked on workshop computers - real comercial ones.
                they are custom steel cased with big fans and filters on one end, and filtered vents on the other end.
                the filters are deep multi-layer jobs too - not the ones from pc parts sellers.
                if i had to make one, i'd try to use an air filter from a car.
                keyboard looks like it has a giant condom over it too - to protect it from oil & grease.
                  • 31214
                  no, you need to ram the air in and filter it on the fan itself so that clean air is leaking out of every orifice.
                  if you dont do it that way, crap will bypass your filters and get in through every tiny hole and even use your dvd drive and usb ports as air filters!
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    this.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      Hate to break it to y'all, filters don't stop it all....mine is filtered as well, but unless you have a completely air-tight case, dust will find a way in.....which yes, will require a blow job periodically.
                      Team : 49813
                      Join in!!
                      Team Stats
                        • 31214
                        the case does not need to be airtight if it's pressurized.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Cooler master Hyper 212 or newer they are great coolers. It takes a while for them to get clogged due to the heatsink fins being quite well spaced and the fan is very effective even at low RPM Also more fans blowing in than out, will cool things alot better and help reduce dust getting trapped.
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            it will still get dust in it though. anytime theres air movement, there's also dust movement, and in a garage (especially a working one) there will be no shortage of dust. it will get in. filters will reduce it, but nothing will stop it. Unless you've got some MEGA fans blowing (8500RPM or higher), you'll have a hell of a time creating positive pressure in a computer case.....and if you have something drawing that much air in, cleaning the fitlers will be a daily chore, and I won't even begin to mention the noise....
                            Team : 49813
                            Join in!!
                            Team Stats
                              master hoarder
                              • May 2008
                              • 12175
                              I would suggest building a very low power PC - perhaps the lowest TDP core i3 you can find. That way, you won't have that much heat inside the case to deal with and might be able to get away with very little air movement going through the case. Perhaps just a single fan (or two) running at low speed and sucking air through a filter on the front, as stj suggested, would be the best. If the PC runs hot, maybe have another fan inside the case that simply only circulates air in the case.
                              Also, if the PC will be running hot, avoid all of those cheap CPU heatsink retention mechanisms that use the board to provide the clamping force - these designs *will* warp the board and could cause BGA failures. Go with a design that uses screws with springs.
                              From personal experience, I can tell you that my Dell OptiPlex has no problem handling the temperature in my room in the summer, which I usually let it slide up to 29-30C (82-86F). And that thing has a P4 Press-Hot HT CPU
                              It does sound like a vacuum cleaner though. Took it about 3 years to get some dust in it. But then again, I do vacuum and dust at least a few times a month. A dusty shop would be many times worse, no doubt.
                              Yup, I've seen that myself with one of my dumpster-picked PCs. Floppy drive and CD drives were a mess inside.
                                • 31214
                                now your getting there,
                                my old server has 3 120mm fans on the front running a total of about 250CFM
                                the filters dont clog as fast as you would think.
                                noise? who cares if it sounds like a small turbine - the bank of scsi drives arent exactly silent.
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  Just got an idea, what about a mini-itx system with an antec isk case? Found a great gigabyte motherboard with integrated wifi (they currently use a usb extention cable with s usb wifi adapter taped on a pole on the cart).
                                  It's sn antec isk 110 vesa (can be mounted on the back of the monitor)
                                  Motherboard is a GIGABYTE GA-H97N-WIFI
                                  Processor is a Pentium G3460 (53 watts)
                                  Ssd is a ss 850 pro 256g
                                  No dvd drive (not possible)
                                  Not 100% the 90w power brick can take all this, any ideas/experiences?
                                    • 31214
                                    whatever you do, you need to push air through the case,
                                    99% of the work is modding the case - blocking all vents etc so air only goes in through the fans and only gets out through the psu.
                                    saying the cpu is 53w dont mean much these days, i see a lot of mobo's that need bigger heatsinks on the chipset than the cpu - they still generate heat.
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5042
                                      • US
                                      It's an external psu brick, the case had no psu, just an open board on top. This case is tiny. Only place for s fan is the side grill
                                      • chowder
                                        • Feb 2016
                                        • 44
                                        If it's in a cabinet, I wouldn't have thought dust or fan noise would be major issues. Go for a massive fan and a decent PSU (upgrade the fan(s) in that as well).
                                        • shouri
                                          Dell latitude e5490 auto restart
                                          by shouri
                                          Hi guys, can someone help me?
                                          I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                                          Board model is dm70 la-f401p rev:1.0 2017-09-20.
                                          At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                                          After a few days test, is seems ok.
                                          Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                                          12-10-2024, 09:27 PM
                                          Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                                          The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                                          Securing a good thermal interface between...
                                          10-07-2024, 04:35 AM
                                        • classicandy
                                          Lenovo G50-80 Auto Power On when AC is detected
                                          by classicandy
                                          Hi Everyone,
                                          I have a Lenovo G50-80 that auto powers On when AC (Charger) is connected. I have checked the BIOS settings and there is no option to turn On or Off that feature as it is in some HP EliteBooks. I did update the BIOS and still same.
                                          I then flashed the BIOS with a different bin file I downloaded here, It worked (didn't auto power on) for some time (after testing up to 5 times) but has now started again to auto power on when AC is connected.
                                          The CMOS battery voltage is 3v. I have also tested with two main batteries as well. I would be glad if anyone...
                                          03-21-2024, 05:48 AM
                                        • harp
                                          detecting heat with IR LED receiver
                                          by harp
                                          I have some dark IR led, and want to know if it is be situable to detect pure heat (not visable glow ir radiation) in well lighted desk?
                                          So, if I put hand over it in near distance like few centimeters, that detect rising heat, not covering it from light.
                                          Something like termal camera, but in one spot, any simple circuit?...
                                          09-06-2023, 06:03 PM
                                        • ludovik
                                          Moto G84 short after heat
                                          by ludovik
                                          i was reballing the power manger of a moto g84, after applying heat i tried to power on and it wouldn’t.
                                          i injected 1.5v to some capacitor that seem in short because both side beep if tested.
                                          when i inject i feel the cpu burning;
                                          since the cpu is exactly on the other side of the board, is that possible that the heat from the reballing damaged the cpu? do you know where i can find schematics or what can i do?
                                          i know this is not enough to explain the situation so if you need any other info ask me please!
                                          Thank you very much in advance
                                          11-08-2024, 02:13 PM
