World's most useless capacitor product?
  • bushytails
    Moderator
    • Dec 2004
    • 217
    I'm sure this has been posted before, but can't find it...
    http://cgi.ebay.com/ws/eBayISAPI.dll...742576231&rd=1
    Notes:
    1) their "large" capacitor is only 1000uf, dwarfed by the capacitance available on every motherboard I've ever seen.
    2) adding an extra pair of connectors to the circuit probably adds far more resistance-based problems than would ever be solved by adding capacitance.
    3) why does that look like a badcap, likely to fail, causing problems?
    --Randy
  • RoadKill
    • Jun 2004
    • 49
    Why does this exist? What purpose does it serve?
    Why did someone pay 8 bucks for it? This makes no sense.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      it serves the purpose of leaving you with 8 bucks less in your wallet
      • RoadKill
        • Jun 2004
        • 49
        Good point. Utterly wasteful, though.
        • bushytails
          Moderator
          • Dec 2004
          • 217
          Actually, he paid 13 bucks. don't forget shipping.
          --Randy
          • MORETTIGIAN
            Capacitor detached from PCB – RTX 2070 Super Founders Edition
            by MORETTIGIAN
            Title:
            Description:
            During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
            I did not notice it detaching, so I am unsure of its original location on the PCB.
            Procedure performed:
            - Removed backplate
            - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
            - Reapplied thermal compound
            - Reassembled card
            Observed behavior after reassembly:
            - GPU powers on and operates normally under...
            09-18-2025, 12:14 PM
          • devsigner
            identify capacitor for MacBook Pro with rare logic board 820-02037-06
            by devsigner
            Hi
            While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
            resistance tests show a rising resistance value, indicating a capacitor.
            The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
            i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
            It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
            Yesterday, 01:39 PM
          • Prolog
            RTX 3080 FE Identifying capacitor
            by Prolog
            Hi people, I hope this is the correct spot to post this, I'm new to the forum.
            I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
            I hope these photos make it clear which component I am referring to:
            (yes, the soldering is a bit botched from removing the blown one, I know)
            I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
            12-01-2024, 08:27 PM
          • Agent24
            Dick Smith Q-1760 linear power supply filter capacitor question
            by Agent24
            I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
            It has at least one problem.
            The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
            I have already ordered a replacement potentiometer, so that's not an issue.
            Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
            All are CapXon...
            10-21-2025, 05:39 PM
          • chth96
            If I replace with inferior capacitor, Is it No harm to other IC components at all?
            by chth96
            I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
            Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
            It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
            So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
            I know that these capacitor will not last as long as nichicon capacitor...
            12-22-2023, 04:34 AM
