XP SP3 Network Install.
  • Sparkey55
    • Jan 2010
    • 1523
    Re: XP SP3 Network Install.
    Originally posted by Spork Schivago
    Thank you Sparkey55. I just couldn't find it on there. I even showed a picture showing that I didn't have the Microsoft category on the left that you had and the search function didn't return any files. I no longer need it though, but thanks for sharing.
    I used Google to find the link in the first ten results. Many many more links after that one. I chose majorgeeks because that website has been around for eons.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      If i had caught this thread earlier.... I'm a member of the larges abandonware archive in the world...
      Follow the white rabbit.
      • Spork Schivago
        • Mar 2012
        • 4734
        • United States of America
        What was your search query? I've used Windows XP SP3 Network Install, Windows XP SP3, kb936929 and "WindowsXP-KB936929-SP3-x86-ENU.exe". It wasn't until I went to my Linux box that I found it in the first 10 results. I remember something a long time ago about Google having an option to remember your previous search results and try to give you search returns based on your previous searches. I wonder if that somehow got turned back on.
        I've done a lot with slipstreaming, customized bootable OS installs, SLIC, pre-activation, a LOT!!! of troubleshooting issues (like Windows Updates not working on customers PCs.) I wonder if that was somehow affecting my returns on my wife's Windows 10 laptop that I'm using.
        -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
        • Sparkey55
          • Jan 2010
          • 1523
          xp sp3 offline installer redistributable
          • Spork Schivago
            • Mar 2012
            • 4734
            Thank's Sparkey55. Definitely something going on here. First ten results are mostly .Net Framework 4.5 and some technet downloads. Absolutely no workable SP3 download links, and no MajorGeek sites listed. Once I get out of the shower, I'll give it a shot on my Linux box and see if it gives me the proper links. This leads me to believe that Google might be returning search results based on my previous search queries. I was looking for a .NET Framework 4.5 redistributable maybe a week ago or so for a customer.
              • 31046
              http://www.softpedia.com/get/Others/...s-XP-SP3.shtml
              • Spork Schivago
                • Mar 2012
                • 4734
                #27
                I had seen that early on but it links to the Microsoft page. I already have the SP now though and don't need it. I just want to know why I'm getting different results in google than the rest of the world. I wonder if Windows 10 has anything to do with this...
                  • 31046
                  use yandex or duckduckgo
                  https://www.yandex.com/
                  https://duckduckgo.com/?kp=%2D1&kl=wt%2Dwt&kh=1&kv=1
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #29
                    Originally posted by stj
                    Do you know any programming friendly search engines? You know, search engines that accept and process queries like X & A or x >> 18, #include, stuff like that?
                      • 31046
                      most can - if you can work out the syntax.
                      unfortunatly there is no standard for & vs AND or the use of brackets.
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        #31
                        I remember one a while ago that was supposed to be programmer friendly. Like it was written just for programmers or something. It turned out to be an epic fail though. I wonder if they continued working on it and fixed the bugs or just gave up.
                        You're right though, if you know how to word things, generally, you can find what you're looking for. For example, in google, something like C Programming x >> 18 might not get you much but C programming bitwise operators will!
                        • ivtec
                          • Dec 2008
                          • 1967
                          I still use my Sony Vaio Centrino Pemtium M 1.5ghz 1 G ram 32bit NONPAE system with Pro XP SP3, i had Chrome,but no more support for 32bit , now i use OPERA,i turned off the Updates and and it does a great job on streaming IPTV that's what i use it more,i have 2 Recovery disks with Sp1,and i downloaded to a DVD Sp2,Sp3 and Ethernet drivers, so if i need to recover system i'm set.
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            #33
                            Have you ever played around with pre-activation? If they ever shut down the activation servers and if you can't activate over the phone line pre-activation can come in real handy. A lot of times, when I redo a system that has 7 on it, I'll just put a fresh copy of 7 on the PC and use the pre-activation key that the company used when they installed the OS at the factory. Saves me the time of having to call Microsoft to activate 7 all the time.
                            I used to do it with XP back in the day.
                              • 31046
                              just use the technet iso, it has no security check rubbish in it.
                              no hacks, bios-patching, bios-emulators needed.
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                #35
                                Yeah, but I don't think I can legally put that on customers PCs. The way I do it, I'm not breaking any laws or anything. At least not in Microsoft's eyes. They sent me a white paper a while back about it and everything. I think with the TechNet ISOs, you're not supposed to put them on other people's PCs, just the ones you own.
                                • piernov
                                  NVidia bumpgate
                                  by piernov
                                  Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                                  Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                                  May complete this post at a later date with more details.
                                  Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                                  03-27-2021, 10:34 AM
                                • howardc64
                                  Samsung UN55JU650DF network/streaming problem
                                  by howardc64
                                  Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                  This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                  07-09-2025, 12:44 PM
                                • japlytic
                                  DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                                  by japlytic
                                  In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                                  Tried (only with keyboard/mouse connected):
                                  • BIOS + database update
                                  • Using latest Windows 11 image built with official image creation tool
                                  • Previous setup version for Windows 11 installer
                                  • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                                  • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                                  • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                                  06-19-2025, 04:59 PM
                                • davg
                                  Home network connection problem
                                  by davg
                                  I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                                  03-06-2021, 07:13 AM
                                • japlytic
                                  Maximum speed should be marked on network ports
                                  by japlytic
                                  I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                                  One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                                  12-19-2024, 05:04 PM
