VP6 and Linux
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    VP6 and Linux
    Well....its been a couple months since I put Mandrake 10.1 on the one VP6. Its one of 4 machines on a Belkin KVM switch. I seem to have to reboot the LInux box at least once a week. I switch over to it and the machine is locked up. No OCing, no screensaver, no power saving stuff at all.
    Mouse and keyboard are USB.
    The only thing running is RC5-72 from distributed.net.
    I'm thinking that maybe Linux don't like the KVM...... :?
    Anyone have similar experiences????
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
  • bushytails
    Moderator
    • Dec 2004
    • 217
    linux works with my kvm perfectly... and if linux didn't like something, it would probably cause panics/oopses, not hard lockups.
    Start with general troubleshooting... I assume you've checked the caps.
    Check/swap ram, cards, power supply, etc...
    --Randy
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      LOL Check the caps Mikey!! HAHAHA
      I actually had a similar experience with a KVM switch, until I got a nice Cybex. I'd switch it back to the Linux server (with the old KVM), and it would appear the system had froze, no KB or mouse. However, the system was a web server, and the sitte was still up, so I knew the machine was still alive. I'd get a PS2 KB & mouse for it, USB KB's and mice are a PITA as it is. Or try another KVM.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • stretch0069
        • Oct 2003
        • 2658
        The caps "look" good, but its a refurb from Abit. I might just replace them just because.
        I'm going to pull it off the KVM and just put a monitor and PS2 KB and mouse on it to see if it makes a difference. If it runs fine, I'll see how USB KB and mouse do. Should pretty much tell me where the weak link is.
        Been busy with work so I don't have the time to put into this stuff that I'd like to.
          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-06-2024, 05:30 AM
        • Natob82
          Micro Momentary Push Switch?
          by Natob82
          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
          12-21-2022, 05:22 AM
        • grimacelord
          NEC TurboExpress On/Off Power Switch Replacement Help
          by grimacelord
          I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
          I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
          I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
          11-09-2023, 09:49 AM
        • SluggerB
          Help making a switch work the opposite way with a relay
          by SluggerB
          I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
          I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
          It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
          02-07-2025, 07:57 PM
          Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
          by sam_sam_sam
          Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
          ( needs more cam circuits for the machine to work correctly again )
          https://www.ebay.com/itm/275321870186
          To
          3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
          ( not 4 positions but the right amount of cams circuits )
          https://www.ebay.com/itm/274660439950
          I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
          03-18-2023, 05:12 PM
