SMBus: a viable alternative for motherboard diagnostic codes?
  • japlytic
    • Oct 2005
    • 2086
    You may have noticed that a number of chipsets and motherboards no longer include parallel PCI slots, but instead, only PCI Express slots are available.
    One thing I have noticed on the standard PCI Express and Mini-PCI Express slots is the presence of the SMBus signals.
    The LPC bus (which can output POST/diagnostic codes) is a bit hard to tap into, since you would need to know the location of these signals.
    So even on a motherboard with PCI Express (standard and mini) slots, the use of a diagnostic card which uses the SMBus is quite viable for obtaining POST/diagnostic codes from the motherboard, provided the motherboard can output these codes to the SMBus.
    I may have seen diagnostic code readers which tap into the SMBus on the Smart Battery connector on notebooks some time ago on eBay.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: SMBus: a viable alternative for motherboard diagnostic codes?
    All depends on the firmware. If they don't dump the codes somewhere as a standard, then it's not viable. Plus the fact that iic/smbus controllers are not standardized as much as port 0x80 which is a very well defined standard (though obsolete as this is for ISA, and yes this is on LPC.)
    Plus the fact that more than one iic bus can be available on any particular machine - which one will have the diagnostic codes.
    I think my IA64 box actually does output diagnostic codes to IIC. I unfortunately do not have the chip to display them...
    • Nevillet
      Dyson V6 Handheld (SV03) Diagnostic LED Codes
      by Nevillet
      Hi All,
      I'm looking for information on LED codes on a V6.
      The battery appears fully charged. i.e.when connected to the charger the LED lights solid blue - then goes out.
      Disconnecting the charger then pressing the trigger makes the motor run for about a second. The battery LED then flashes amber - then flashes blue 10 times.
      The motor will not run again until I reconnect the charger - then disconnect it.
      Measuring the battery off the body It reads 24.3V (with the battery button pressed)
      If I press and hold the battery...
      02-25-2021, 02:55 PM
      Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
      Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
      various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
      Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
      trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
      what is wrong with your PC in just seconds. It saves you time and money.
      Our new and improved design...
      11-01-2024, 06:29 AM
    • michalk3777@gmail.com
      Sharp Hisense - LC-65N7004U Error codes
      by michalk3777@gmail.com
      Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
      Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
      Regards,...
      12-15-2024, 09:20 PM
    • Sinnyone
      Yamaha RX-V3900 dim display and turns off
      by Sinnyone
      This is a repost since I never completed this fix. I just left it, but now the receiver powers off into safe mode and does not complete the Self-Diagnostic when i start with those buttons pushed. It says it is, but does not do the diagnostics and does not show any faults or that it has none, which it should do. So here i am again. The previous post did have a schematic but I think it was cut off somewhere. I do not know what board it is referring to. Any help would be appreciated.
      I have searched through the forums and have not found anything about my problem. So,...
      08-30-2023, 08:35 AM
    • ktmmotocross
      PS5 Slim - no video, butchered hdmi, after replace still no video, diagnostic said APU was overheating and now not responding
      by ktmmotocross
      Have this PS5 Slim with no video, HDMI connector was horribly butchered. but after replace i have no video. diagnostic said APU was overheating and now not responding,
      checked fuses and all are good
      any hint?...
      07-24-2025, 02:12 AM
