Dyson V6 Handheld (SV03) Diagnostic LED Codes
  • Nevillet
    • Sep 2019
    • 272
    Hi All,
    I'm looking for information on LED codes on a V6.
    The battery appears fully charged. i.e.when connected to the charger the LED lights solid blue - then goes out.
    Disconnecting the charger then pressing the trigger makes the motor run for about a second. The battery LED then flashes amber - then flashes blue 10 times.
    The motor will not run again until I reconnect the charger - then disconnect it.
    Measuring the battery off the body It reads 24.3V (with the battery button pressed)
    If I press and hold the battery button down the LED lights blue for a second - then briefly flashes green - then goes out.
    Does anyone know what these codes mean?
    And is there a listing somewhere of all of these error codes?
    BTW: I have completely stripped down and cleaned the cyclone unit and the brush head.
    Many thanks
  • PNI E.
    Dyson v15 problem with the dust detector board
    by PNI E.
    Hi guys, I have a Dyson v15 that didn’t work. The battery blink 10 times. If i disconnect the cable of the dust detector board, the Dyson turn on but after some seconds stop because didn’t feel the flow of the air because I disconnected the bird sensor, if I connect the Dyson is death. I notice the big mosfet I think with 3 pins. If I check the mosfet I have a short circuit from the center pin ne the left pins…so I think that s the problem or I wrong? The problem I can’t understand what type of mosfet is….someone can help it s hard to find. New board...
    10-02-2025, 10:18 AM
  • odie34
    Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
    by odie34
    I am a hobbyist (not a professional) so please be gentle...
    I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
    I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
    02-18-2024, 09:11 AM
  • Toueno
    Dyson Pure Hot+Cool HP00 - Datasheet needed
    by Toueno
    My Dyson Pure Hot+Cool, model HP00, no longer starts.
    After disassembling and accessing the electronic motherboard, I found that the 16A fuse soldered to the motherboard is dead. I decided to do an electronic shunt to see the reaction, and the Dyson turns on for a few seconds and then turns off.
    It is likely that a voltage control chip or a safety chip is dead, but without the electrical schematics, the repair becomes complicated…
    Thank you in advance for your help.
    Best regards
    08-14-2024, 10:38 AM
    Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
    Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
    various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
    Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
    trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
    what is wrong with your PC in just seconds. It saves you time and money.
    Our new and improved design...
    11-01-2024, 06:29 AM
  • AstutePauciloquent
    Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
    by AstutePauciloquent
    Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
    I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
    11-23-2023, 11:02 PM
