Gigabyte GA-7DX+
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Gigabyte GA-7DX+
    This is a new board - only started using it 3/4 months ago
    The gigabyte website tells me the mobo supports the following CPUs
    http://www.gigabyte.com.tw/Support/M...ProductID=1301
    I only use it because of the ECC Reg Support for DDR SDRAM
    Q - Can I get a Barton unofficially to run on this mobo (at 2400+/2600+
    thoroughbred core speeds) but have the fatter (512k) cache?
    Any help appreicated
    Thx
  • Fizzycapola
    • Oct 2006
    • 423
    Re: Gigabyte GA-7DX+
    I wouldn't test unless someone knows for sure.
    I had a bad experience from upgrading an 266Mhz Bus Althlon to a 333Mhz Bus Barton, smoke came out as RAM & CPU started burning, socket was burned CPU only partially worked after that. It was a case of the manufacturer being right for once.
    Rubycon Rubycon Rubycon
    • kikkoman
      • Jul 2007
      • 691
      Why? It doesn't make much of a difference since the Barton is clocked ca. 150-200MHz lower than its T-Bred counterparts at the same speed ratings.
      And the fastest available T-Bred B@266 is a 2600+. Probably cheaper,too. oh, and it seems there's a 2800+ Barton (266FSB) OEM model.
      All Mobile Barton models run at 266FSB, too.
      But frankly, I have no idea if a Barton would work at all. Usually mobo manufacturers release a new BIOS even for single new steppings, so there must be something to it.
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • starfury1
        • May 2006
        • 1256
        well looking at what they say Id be very wary
        Id check the exact specs on the CPU and What the MB can do
        what kikkoman says you might get away with if the barton falls in that category.
        I have no idea and he would know more then I do on that score
        Agree too that a BIOS is normally updated to support a new CPU if the hardware is capable of using it.
        So maybe look at the Bios firmware and see what updates there are and what they are for or support.
        Seems 333 400 (FSB) are all N/A
        I think there may be a Voltage thing you had better what out for too.
        (I sort of remember this when I looked at the max and type of CPU's for my old gigabytes
        here the bios page but it don't say much
        personally unless you can confirm it as being workable
        I wouldn't risk it..better a slower working MB/CPU then a (worse case) Smoked MB/CPU
        As FizzyC has stated by bad example sorry Fizzy
        (Actually almost fell into that trap when I seen a good price on a CPU)
        Cheers
        • gonzo0815
          • Feb 2006
          • 1600
          I would say it should work, from my understanding Bartons and T-Bred are pin compatible.
          I have never read or seen problems like smoke or fire, unless there where another problem present (which is by the way very very common for those platforms. Very sensitive core).
          Most probable reason for smoke is one of those very cheap and bad PSU`S from that time wich can`t handle any seriouse load (e.g. a new GFX or a Barton).
          So i would certainly advise to check PSU model & manufacturer, before do any upgrading.
          The only thing which is for sure is the missing FSB 330 &400 support of this mainboard.
          But unless you find some one who tried that, nonone can guarantee anything to you.
          • JEWilson
            • Sep 2007
            • 369
            Agreed,
            The mobo voltages can be monitored via the BIOS on this mobo.
            The present CPU in situ, a TBred 2400+ 256k 133MHz FSB is
            a 0.13um 1.65V AXDA2400DK3VC Model 8 - requires 68.3W from the
            AMD data.
            The CPU core voltage is the same for a Barton, gives me next,
            the problem as to whether (not) the mobo CPU VRM can supply
            sufficient power. Barton's require 68.3W to 76.8W.
            I suspect it can.
            I do also have the reference design for this series of mobo,
            a GA-7DXR which has been recapped.
            As is normally the case, on subsequent releases of mobo,
            the silk screen details where all the caps were and of course,
            are amiss on subsequent versions.
            Thx
            • starfury1
              • May 2006
              • 1256
              Humm interesting point on PSU Thanks Gonzo
              My above post, just to clarify a bit,
              it sort of comes back to me what it was..
              The GA-7ZXE I have is a Version 1
              http://www.gigabyte.com.tw/Support/M...ProductID=2307
              Supports Palomino only
              Version 2 (revision)
              http://www.gigabyte.com.tw/Support/M...ProductID=1318
              supports up to AthlonXP 2600+ Thoroughbred 266
              I am not 100% sure so correct me if I am wrong
              but I think this was due to voltages used with cores
              (I know the VRM is told by the CPU what is required (VID ? from memory)
              TBirds (probably) didn't exist when version 1 come out
              so I am guessing Rev 2 was a modded MB to support later CPU's at the time
              So the above post was to advise extreme caution with any later CPU's and older MB's really
              (checking specs might avoid extreme wallet pain)
              I think (but could be wrong ) Tbird is 1V6 ? palomino is 1V85 ?
              Cheers
              • starfury1
                • May 2006
                • 1256
                just re reading gonzo's post...and its question I am asking here
                Being "socket A" shouldn't they all be pin for pin compatible?
                Palomino T'Bird Barton
                (granted I know pins can be change and NC pins and socket molding can be used as "key way" so that only the right chip can be used )
                Just wondering since it was mentioned.
                Cheers
                • JEWilson
                  • Sep 2007
                  • 369
                  The details for AMD CPUs are here
                  I also found this page for CPU upgrades (refer to Gigabyte GA-7DX)
                  http://www.upgradeware.com/english/p...patibility.htm
                  But this refers to a hardware multiplier control (see unlocked below)
                  The fastest Barton has x11 mult with an FSB 200MHz
                  The T-Bred in situ has a x15 mult with an FSB 133Mhz
                  So...
                  Feasibly, I could run the Barton at x11 mult 133MHz
                  This would be equivalent to an XP 1700+ with a 512k cache
                  Of course, if I could get an unlocked Barton - it would be a different matter
                  As it would be running at 133MHz, suspect I would probably save on
                  the power budget available from the CPU VRM also.
                  Any thoughts?
                  • JEWilson
                    • Sep 2007
                    • 369
                    Some clarification required
                    Max mult x13 with a Barton at 166MHz
                    So this would give me a TBred XP2100+ at 133MHz
                    • starfury1
                      • May 2006
                      • 1256
                      I'll let someone who really knows what they are talking about reply on the above.
                      If electrically compatible "I think?" it just a matter of juggling the numbers and yeah unlock but no guru so not going to stick my neck out on that one.
                      But a DOH! that should be T'bred not T'bird...
                      not the famous Thunderbirds are Go! or Car for that matter.
                      Cheers
                      • kikkoman
                        • Jul 2007
                        • 691
                        vcore voltage can be set via bridges (or pins).
                        sure, they're all pin compatible. no problem there either.
                        BUT: i think you're ging to run into some kind of trouble without a proper BIOS. either it's not going to work at all, or maybe the extra cache can't be addressed. i can't tell for sure, but i doubt it'll run smoothly.
                        i still suggest you get the fastest t-bred and unlock it (which is easy with t-breds compared to bartons).
                        t-breds are cheaper than bartons, and i think it'll be faster, too. the extra cache really doesn't make THAT much of a difference.
                        as i said above, the bartons are a bit underclocked compared to the respective (PR) t-bred models. if you underclock them even further, the cache is clocked slower, too.
                        i'd say it ain't worth the hassle.
                        • JEWilson
                          • Sep 2007
                          • 369
                          Agreed
                          Upon reflection, it is not going to be worth the hassle
                          Thanks all
                          • gdement
                            • Jan 2007
                            • 690
                            Easier yet, just get a mobile thoroughbred. But I'm not sure how fast those come, so maybe you can't get the best performance that way.
                            regarding BIOS, I've noticed that many times the newest BIOS for a given machine will add support for newer CPU cores, but the fact won't be advertised in the changelog. Depending on the date of the newest GA-7DX bios, you might get lucky with it. But thoroughbred is a much safer bet, those will surely be supported with an update, if not out of the box.
                            Thanks all
                            Fair enough. But if you see a good price on a good thoroughbred, especially if it's a mobile, then I'd go for it. TBred shouldn't give you any trouble if you just flash the BIOS first.
                            • JEWilson
                              • Sep 2007
                              • 369
                              Thanks for the info
                              Appears a mobile Barton which operates at FSB 133MHz and also
                              has clock multiplier up to 16.5x is a route to follow as with;
                              AXMA3000FKT4C - Athlon XP 3000+ Barton 2200MHz 16.5x 133MHz 1.65V
                              AXMA2800FKT4C - Athlon XP 2800+ Barton 2133MHz 16.0x 133MHz 1.65V
                              AXMA2600FKT4C - Athlon XP 2600+ Barton 2000MHz 15.0x 133MHz 1.65V
                              All of the above have 512k cache as well
                              The 2600 and 2800 should be drop in replacements without any issues;
                              1. FSB 133 - what I require
                              2. Core voltage 1.65V
                              3. Multiplier up to 16.0x
                              Any other issues required?
                              I suspect the CPU details will be implemented with the latest BIOS
                              which has been applied.
                              Again, thx for the details
                              • kikkoman
                                • Jul 2007
                                • 691
                                see, that's the thing I'm concerned about.
                                the lastest official BIOS version is F7 from June 19th 03
                                ---and the Barton XP-M was introduced (to the public, I assume) only twelve days earlier (according to wikipedia).
                                the T-Bred 2400+ and 2600+ (support for these is the official purpose of the F7) however were introduced WAY earlier (MArch 12th '03).
                                given this and the fact that this mobo wasn't designed for Barton cores in the first place - and for mobile CPUs neither - there's still a chance that the BIOS doesn't support this CPU (to whatever extent).
                                • JEWilson
                                  • Sep 2007
                                  • 369
                                  You may well be right
                                  As I recall, adding new stepping codes which were not available
                                  with a BIOS update was a trivial matter provided the hardware
                                  could support it.
                                  I have done some experimentation with this feature on an old
                                  Tyan Tiger 100.
                                  For example, Tyan state (as I recall but my memory is hazy on this)
                                  max CPU is 800Mhz Katmai with the latest and last BIOS.
                                  As it was a dual CPU system, I patched the bios with a stepping
                                  update from sandpile.org to make the BIOS see new steppings.
                                  To that end, I made the mobo see and load Coppermine 1GHz
                                  in Slot 1 and the system was stable. You might think, how did
                                  I get a uMine to work. Simply used a slocket adapter!
                                  However, the mobo would not boot with two slockets with
                                  a uMine each This was a matter attributed to the CPU VRM
                                  not being able to cope with the power requirements.
                                  The VID was correctly identified (I checked) and such like - still have
                                  the board.
                                  Albeit I left that little project at that point (too busy), I
                                  could have beefed up the VRM to accomodate both CPUs.
                                  So...
                                  It may well be possible in this specific instance where the
                                  latest F7 bios for the GA-7DX+ whilst not immediately
                                  supporting a Barton mobile Athlon XP, can be patched with
                                  a BIOS stepping code to get it to run on this mobo.
                                  This of course remains to be seen (and done)
                                  I believe this was Kikkoman's major concern. Correct me if wrong.
                                  Thx
                                  • JEWilson
                                    • Sep 2007
                                    • 369
                                    Possibly another issue...
                                    I've started monitoring board voltages and find the AGP voltage at
                                    1.07/1.09V
                                    As this is an AGP 2.0 board, it is populated with an ATI FireGL 8800
                                    AGP 4x adapter
                                    As this adapter is a 1.5V board, should this undervolt condition be
                                    something I should be concerned about?
                                    I should add, albeit the other voltages appear to be ok, it may
                                    be, compensation for the difference between read voltages
                                    with a m/meter and those reported by MM5 will be necessary.
                                    But, given the other MBM 5 readings below, the other voltages
                                    appear ok;
                                    CPU Core - 1.68V
                                    +3.3V - 3.34V
                                    +5.0V - 5.08V
                                    +12.0V - 12.25V
                                    -12.0V - 0.0V - pls ignore
                                    -5.0V - 0.0V - pls ignore
                                    AGP V - 1.09V
                                    And I have yet to get m/meter readings also
                                    Any suggestions, opinions appreciated
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      check it with a dvm.
                                      • JEWilson
                                        • Sep 2007
                                        • 369
                                        Erm....
                                        I made an error with the AGP voltage label.
                                        In fact, I established this to be the DDR voltage after I ran
                                        the supplied VIA Hardware Monitoring Utility v2.5 and it reports
                                        regular alarms as being in error.
                                        Obviously, the rail should be 2.5V.
                                        This is a new board and has hardly been used.
                                        I cannot fathom how the DDR DC-DC block could be in error or
                                        how this may be attributable to bad caps albeit, the mobo
                                        does have crapacitors by GSC etc.
                                        I only have two of PC2100 ECC Reg DIMMs in situ - these are matched.
                                        Perhaps time for a recap after all....
                                        • DynaxSC
                                          GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                                          by DynaxSC
                                          I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                                          General test conditions:
                                          - Tested with Core i5 6500 and Core I7 6700K - no difference
                                          - Default BIOS settings, but tried also altering several memory setting - does not change anything
                                          What is wrong:
                                          With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                                          When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                                          03-21-2025, 06:23 PM
                                          Thermal pad thickness for various laptop GPU / Graphics Cards
                                          ASUS Dual RTX 2070 OC 8GB
                                          ASUS ROG STRIX RTX 3080 OC
                                          ASUS ROG STRIX RTX 3090
                                          ASUS TUF Gaming RTX 3080 OC Edition
                                          ASUS TUF GTX 1660 S-O6G GAMING
                                          EVGA RTX 3060 Ti XC GAMING 8GB
                                          EVGA RTX 3060 XC GAMING 12GB GDDR6
                                          EVGA RTX 3080 FTW3 ULTRA GAMING
                                          EVGA RTX 3080 TI FTW3 ULTRA GAMING
                                          EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                                          Gainward RTX 2080 Phoenix GS Specs
                                          Gainward RTX 3070 Phoenix 8GB
                                          Gainward RTX 3080 Ti Phoenix
                                          GIGABYTE AORUS RTX 3080 MASTER 10G
                                          02-09-2024, 08:08 AM
                                          A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                          by momaka
                                          More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                          And a shot of the label:...
                                          01-26-2022, 03:26 AM
                                        • nikovmiroslav
                                          Gigabyte A5 X1 Need Bios
                                          by nikovmiroslav
                                          Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                                          Gigabyte A5 X1
                                          From motherboard:
                                          S/N: 1TNH55ER1350895
                                          P/N: 6-77-NH55ERQY-D02-2CGB
                                          On sticker from the back of the laptop:
                                          S/N: SN21351J000657...
                                          08-24-2025, 09:15 AM
                                          LENOVO ThinkCentre M91p ThinkCentre M i7-2600 Specification for Upgrade or Repair
                                          This specification for the LENOVO ThinkCentre M91p can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M91p boardview and ThinkCentre M91p schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:36 PM
