Overclocking problem
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Ok, so I have this system I just built:
    Athlon X2 4000+ 2.1GHz
    Biostar T-Force 7025-M2
    2GB Kingston DDR2-800
    Samsung 250GB HD
    Samsung DVD-RW
    AcBel 550w PSU
    Here is the problem. I can overclock it fine to about 250fsb. I set the max ram speed in the bios to DDR2-667, which results in an actual memory frequency of about 375MHz, or somewhere in there. Then I lower the HTT multiplier to 4x. After setting the voltages for everything correctly, it will all pass Prime95 (the new dual threaded version) nicely. Above 250fsb things don't work too well. But that's ok, 250 would be enough.
    The problem is that pretty much anything above about 210 I get this strange problem. While it will all pass Prime95 for many hours, if I shut the system down and turn it back on, it will just sit there and beep at me like it has a memory error. The one long beep followed by silence, then another long beep, and so on. At which point, I need to reset the bios via jumper.
    Things of interest:
    CPU stepping as best I remember it: NAA4G-0806BAG, Made in China
    Motherboard is a new revision, 5.1. The other 7025 boards I've used have all been version 5.0, and have all had a stable FSB up to at least 300MHz.
    Memory read speeds in Everest seem a bit low for the timings and speed it's running.
    Any ideas? I have a test computer with very similar hardware, I may start swapping and try to see where the problem is.
    A man convinced against his will is of the same opinion still.
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Overclocking problem
    Update:
    It just did it again at stock speeds. Everything set to normal.
    • acstech
      GrumpyModerator
      • Jul 2007
      • 1432
      It appears to have been the memory. I swapped that out and the problems seem to have gone away. Funny that it passed Prime95 but still had problems.
      • pkslowk
        Debug Card Error Code and Solution
        by pkslowk
        Sr. Motherboard Debug Error Code Solution
        1 Intel 845 E9 Bios Related Problem
        2 Intel 845 D4 CPU Socket Related problem
        3 Intel 845 37 Bios Related Problem
        4 Intel 845 7C Bios Related Problem
        5 Intel 945GCPE 34 Bios Related Problem
        6 Gigabyte 845 2 Ram Related Problem
        7 IBM Server A6 A7 Ram Mismatch Problem
        8 Asus 845 29 CPU Related Problem
        9 Lenovo I946 97 C-Mos Jumper related
        10 Gigabyte 845 A0 CPU Related Problem
        11 Asrock G31M-VS D7 Bios Related Problem
        12 Compaq 845 BD-70G B0 CPU Socket Related problem...
        01-28-2021, 12:51 PM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • Zeonalbasta
        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
        by Zeonalbasta
        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
        09-13-2024, 01:17 PM
      • Gibon378
        Problem with stopping audio and video for no reason
        by Gibon378
        PC Specs:
        • CPU: Ryzen 5 1600
        • GPU: GTX 1080 Palit JetStream
        • MOBO: ASRock ab350 PRO4
        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
        • PSU: XFX 650W (don't remember what model)
        • OS SSD: ADATA SP920
        • OS: Windows 10 21H2
        Problem description:
        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
        11-19-2022, 09:41 AM
      • perzyk23
        Lenovo T580 - LCD Panel problem - error 0288
        by perzyk23
        Good morning,
        I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
        10-25-2024, 12:42 AM
