hp pavilion zd 8008ea no charge
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: hp pavilion zd 8008ea no charge
    That information (scheme - schematic) is not released to the public for laptops.
    Mann-Made Global Warming.
    - Dr Seuss
    • marketta
      • Nov 2007
      • 70
      #42
      top secret ?
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        #43
        A sort of: schematics are intended for authorized tech service only; moreover, nowadays almost nobody repairs at single component level, you usually replace the damaged part so detailed schematics aren't that useful for assistance, unfortunately can be vital for hobbists. I think only tv manifacturers offer a board schematic with their products.
        ----- Italian: -----
        Piu' o meno: solo l'assistenza autorizzata dovrebbe avere gli schemi; inoltre quasi nessuno ripara il singolo componente danneggiato, di solito si sostituisce il pezzo guasto quindi l'utilita' di schemi circuitali dettagliati e' dubbia per l'assistenza, ma e' sfortunatamente vitale per gli apassionati. Penso che solo le tv siano vendute con lo schema della scheda.
        Zandrax
        Have an happy life.
        • starfury1
          • May 2006
          • 1256
          #44
          schematics for anything seem to be rare these days, computer especially
          lest wise as far as the net generally is concerned.
          (excluding torrent newsgroups etc here)
          you best bet is to post a photo and hope someone can identify what part you are asking about or alternatively.
          Try tracing chip numbers if you can locate a PDF for the chip you stand a chance of possibly working out how it functions.
          The real down side here is that multi layer PCB make it had to know what exactly connects to what.
          (that could be harder being a lap top, where maybe more likely some in house number is used)
          Maybe you have already tried this, so ergo the post for a technical manual
          If you require a part number then I guess you will have to contact HP and see if you can get a part list or something
          I suppose that would depend on how much of a closed shop they are with regard to tech stuff in relation to the public.
          (That I dont know)
          Good luck
          Thanks for the translations Zandrax it helps a lot
          cheers
          • marketta
            • Nov 2007
            • 70
            #45
            @ starfury1
            I have tried online on internet but I have not found anything.
            To me it serves the electric scheme
            I am a technician and I need the electric scheme at least of the section feeding
            I have already contacted HP but doesn't give listening to the privacies technical repairers
            Me being a technician I want to see us clear on the reparation
            I explain you, being the consequential breakdowns of this laptop from the general feeding and from the feeding that recharge the battery I have to follow the line of the feeding +19,5volt to individualize the cause of the breakup of the ICs 4407 and of the instant turning off of the laptop.
            That's why I need the electric scheme and the list parts
            I know him/it that it is difficult to retrieve him/it but it is not impossible payment hips if it is possible
            You excuse my poor man English because I use a translator
            Thanks to ZANDRAX Per The Translation
            ITALIAN
            @starfury1
            Ho provato in rete su internet ma non ho trovato nulla .
            A me serve lo schema elettrico
            Sono un tecnico e ho bisogno dello schema elettrico almeno della sezione alimentazione
            Ho gia contattato HP ma non danno ascolto ai privati tecnici riparatori
            Io essendo un tecnico voglio vederci chiaro sulla riparazione
            Vi spiego, essendo i guasti di questo laptop derivanti dall'alimentazione generale e dall'alimentazione che ricarica la batteria devo seguire la linea dell'alimentazione +19,5volt per individuare la causa della rottura degli IC 4407 e dello spegnimento istantaneo del laptop.
            Ecco perchè ho bisogno dello schema elettrico e della lista parti
            Lo so che è difficile reperirlo ma non è impossibile anche a pagamento se è possibile
            Scusate il mio povero inglese perchè uso un traduttore
            Grazie a ZANDRAX PER LA TRADUZIONE
            • zandrax
              Hit and miss
              • Dec 2007
              • 1157
              • Italy
              #46
              I fear schematics aren't available: you can find service manuals (a troubleshooting and disassembly guide), both for free or for money, but not board designs as they are a sort of "industrial secret".
              Anyway I won't discourage you: someone shares your same trouble and posted something on zd7000forums. He found only the ic schematics and had to trace down the board by hand: perhaps he will help you if you email him.
              I'm sorry I can't help you more, this exceeds my knowledge.
              ----- Italian -----
              Temo che gli schemi che cerchi non siano disponibili: trovi i service manual, per risolvere i problemi e smontare il portatile, sia gratis che a pagamento, ma non troverai mai i progetti della scheda perche' sono un segreto industriale o qualcosa di simile.
              Comunque niente paura: qualcun'altro si e' imbattuto nel tuo stesso problema e ne ha parlato su zd7000forums. Ha trovato solo le specifiche dell'integrato, qindi ha dovuto seguire le piste sulla scheda: se gli mandi una email, forse puo' aiutarti.
              Mi spiace non poterti aiutare di piu', non ho le conoscenze adatte per farlo.
              Zandrax
              Have an happy life.
              • marketta
                • Nov 2007
                • 70
                #47
                @ zandrax
                I thank you for your answers the ZD8008ea you/he/she has been sheltered replacing the 4 chipses 4407
                I now have in reparation another laptop ZD8369ea that al'improvviso is extinguished and you/he/she has not turned on anymore it seems dead they don't ignite the leds of signaling
                make to know me
                • marketta
                  • Nov 2007
                  • 70
                  #48
                  italian
                  @ zandrax
                  Ti ringrazio per le tue risposte lo ZD8008ea è stato riparato sostituendo i 4 chips 4407
                  Ora ho in riparazione un'altro laptop ZD8369ea che si è spento al'improvviso e non si è piu acceso sembra morto non si accendono i led di segnalazione
                  fatemi sapere
                  • zandrax
                    Hit and miss
                    • Dec 2007
                    • 1157
                    • Italy
                    #49
                    @ marketta: the notebook seems dead because it won't turn on, nor leds?
                    It may be a power related problem: check if it start with only a charged battery inserted. If it does start, check if power connector is loose or even detached from motherboard, because this prevents the computer to be powered and the battery to be charged of course: usually you can solder the connector or buy a replacement.
                    If it doesn't boot at all and you're sure both psu and battery are in working state, then check the mainboard: the 8300 series is based on the 8000 one, so I fear it may share the same design defect. I found no useful information, so post any relevant photo about the motherboard.
                    ---- Italian: ------
                    Il portatile sembra morto perche' non sia avvia ne' i led si accendono?
                    Potrebbere essere un problema di alimentazione: provalo con solo la batteria carica. Se si accende, controlla se lo spinotto di alimentazione sulla scheda madre balla oppure e' staccato, perche' impedisce l'alimentazione e la ricarica della batteria: in genere puoi risaldarlo in posizione o comprare un ricambio.
                    Se non parte e sei sicuro che sia l'alimentatore che la batteria funzionano, allora controlla la scheda madre: la serie 8300 e' basata sula 8000, temo che possa condividere gli stessi difetti di progettazione. Non ho trovato nulla di utile, quindi posta qualche foto della scheda.
                    Zandrax
                    Have an happy life.
                    • marketta
                      • Nov 2007
                      • 70
                      #50
                      HI ZANDRAX
                      1) The motherboard is equal to that 8000
                      2) I have tried with the loaded battery but it doesn't turn on equally
                      3) the integrated 4407 are not broken
                      4) not having an electric scheme I cannot go on
                      5) I have tried with another CPU it is equal it doesn't turn on
                      6) I am trying the motherboard with power supply, card frontal leds, card of lighting, (I have not connected RAM, DVD, HD, Keyboard and other cards because however they are had to turn on the frontal leds)
                      I think there is some open component or in short-circuit but with the multimeter I don't succeed in individualizing.
                      if you can tell me some other test I would be thankful of it
                      If someone has the same defect and you/he/she has resolved an email you send me
                      thanks
                      • bgavin
                        • Jan 2007
                        • 1355
                        #51
                        Thanks to you both for providing both English and Italian, so the rest of us don't lose out on the conversation. Very much appreciated.
                        • marketta
                          • Nov 2007
                          • 70
                          #52
                          CIAO ZANDRAX
                          @ to all
                          1) La motherboard è uguale a quello 8000
                          2) io ho tentato con la batteria caricata ma non accende ugualmente
                          3) gli integrati 4407 non sono rotti
                          4) non avendo un schema elettrico io non posso seguire
                          5) io ho tentato con un altra CPU ma è uguale non accende
                          6) io sto provando la motherboard con alimentazione elettrica, scheda leds frontale, scheda di accendere (io non ho connesso RAM , DVD, HD, Tastiera e le altre schede, perché comunque si devono accendere il leds frontali)
                          Io penso c'è del componente aperto o in cortocircuito ma col multimeter io non riesco nell'individualizzare.
                          se Lei può dirmi dell'altra prova io ne sarei grato
                          Se qualcuno ha lo stesso difetto mi mandi una e-mail
                          grazie
                          • zandrax
                            Hit and miss
                            • Dec 2007
                            • 1157
                            • Italy
                            #53
                            @ marketta: first clear obviuos doubts: clear the cmos by removing the button battery for about 20-30 mins, then inspect the motherboard for obvious damages (unstable or "cold" weldings, broken tracks, shortcircuited pins, capacitors and so on).
                            Then begin troubleshooting: you need to hear motherboard beeps, which are complains, to make sure the board is functioning: some motherboards don't have a beeper (a 0.4" cylinder) onboard but use the audio codec instead.
                            Just to be sure, connect to the mainboard only an external monitor (use the vga port), the cpu with the heatsink (plug the fan cable inside its socket, otherwise the bios think the fan is defective and hangs at boot), the keyboard (checked at boot), the led card and the audio module, then plug an head- or earphone into the audio jack and power the motherboard: if the motherboard beeps, it means it recognizes the lack of ram so there is a fault after ram check, perhaps an onboard integrate. If it doesn't beep, there is something preventing the ram from being initialized: being the ram is one of first components tested, this is a big issue ranging from a corrupted bios to phisical damage or broken components. A correct diagnosys may be really hard or even impossible without schematics, an online one is even more harder: however if neither the fan does spin, the trouble is serious, I think power related.
                            Chiariamo i dubbi palesi: azzera la cmos togliendo la batteria al lito per circa 20-30 minuti, poi controlla la scheda madre per guasti evidenti (saldature instabili o fredde, tracce rotte, pin di integrati in corto circuito, condensatori ecc).
                            Poi inizia il troubleshooting: per sapere se la scheda madre funziona bisogna sentirne i beep, i lamenti; alcune schede non hanno un cicalino (un cilindro di un centimetro di diametro) ma usano il chip audio in genere presente su una scheda a parte.
                            Per essere certi di sentirlo, collega alla scheda madre un monitor esterno (tramite la porta vga), il processore con il dissipatore (non dimenticare di colleare il cavo dela ventola alla scheda, altrimenti il bios pensa che la ventola sia rotta e blocca l'avvio), la tastiera (e' controllata all'avvio), la scheda con i led e la scheda audio, poi inseriscici una cuffia o un'auricolare: se senti il beep, allora la scheda madre rileva l'assenza della ram e il problema e' a valle, forse in un integrato della scheda; se non lo senti, qualcosa impedisce il controllo della ram: essendo la ram uno dei primi componenti inizializzati dal bios, il problema e' grave e spazia da un bios guasto fino ad un danno fisico o componenti andati. Una diagnosi corretta e' quindi molto difficile o pure impossibile senza lo schema della scheda madre, figuriamoci una diagnosi a distanza: comunque se non parte nemmeno la ventola, il guasto e' serio, penso legato all'alimentazione.
                            Zandrax
                            Have an happy life.
                            • marketta
                              • Nov 2007
                              • 70
                              #54
                              @Zandrax
                              possiamo sentirci in PVT o con un cell
                              dove sei in italia
                              grazie
                              • zandrax
                                Hit and miss
                                • Dec 2007
                                • 1157
                                • Italy
                                #55
                                You have PM.
                                However I'm not a technician (I suck at soldering) and I'm quite busy during all day: mostly I can try to help you at night.
                                Controlla i messaggi del profilo.
                                Comunque non sono un tecnico (sono una frana col saldatore) e sono impegnato durante il giorno: al massimo posso cercare di aiutarti la notte.
                                Zandrax
                                Have an happy life.
                                • marketta
                                  • Nov 2007
                                  • 70
                                  #56
                                  ok Zandrax
                                  also I am busy the day and it doesn't interest if you are a landslide with the welder, important it is to help us.
                                  Ok I will write you in your Profile
                                  italian
                                  ok Zandrax
                                  anche io sono impegnato il giorno e non interessa se sei una frana con il saldatore, importante è aiutarci.
                                  Ok ti scriverò nel tuo Profilo
                                    HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                    This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                    09-12-2024, 03:44 PM
                                    HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                                    This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                    HP Pavilion Pavilion p6560be-m Desktop PC Bundle Pavilion p6500 E6600 Specification for Upgrade or Repair
                                    This specification for the HP Pavilion Pavilion p6560be-m Desktop PC Bundle can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion p6560be-m Desktop PC Bundle boardview and Pavilion Pavilion p6560be-m Desktop PC Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                                    This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                    HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                                    This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
