Help identifying an older file system
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    I found a floppy disc, it's a 1.44MB 3.5" floppy. My Linux box doesn't understand it. It had a sector or two that was bad but I was successfully able to make an image using ddrescue. file cannot identify it. I open it in a hex editor and I see the words:
    Code:
    XEROX 1.44MB
    Can someone help me identify what file system this is and what type of system used it? There's a number on the disc, 1995. I think this might provide a clue. Any thoughts?
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • 31084
    Re: Help identifying an older file system
    upload the image.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Maybe Xenix Fs? Used by early interactive Unix 386 and the like. I think FreeBSD supports it...
      Follow the white rabbit.
      • SteveNielsen
        Retired Tech
        • 2327
        Perhaps it was formatted on a big Xerox copier/scanner/network-printer machine. We had some around ten+ years ago at a job. Nobody ever used the floppy drives once they figured out how to just shoot it across the network. I don't recall what file-system(s) it used/supported.
        • Spork Schivago
          • Mar 2012
          • 4734
          Originally posted by stj
          upload the image.
          I don't want to upload the image because it may contain sensitive information. Using a hex editor and loading the image, just looking through it, it appears to be using ASCII as the character set, not EBCDIC. It appears to contain shipping information for a larger company. Account information, addresses, etc. I'm not sure if credit card numbers are in there or not (I'd hope not). No idea where or how I acquired it. I've had it for years. I remember having it back in high school. Wasn't able to read it back then but didn't know enough about PCs. Just kept it all these years and ran into when I was looking for some older disks I had info on.
          • Spork Schivago
            • Mar 2012
            • 4734
            I believe there's a Xenix FS module for Linux. My system should be setup to autoload FS modules on demand (ie, when I try to mount the image, it should be able to load the appropriate module). I'll check the kernel source to see if the Xenix FS module is enabled or not. If it isn't used so much anymore, it might be in the odd ball section. What's kinda weird is file cannot detect it. Usually, file is pretty good with stuff like this.
            I contacted Xerox a while back asking them if they knew anything about the FS but they never responded.
            • Spork Schivago
              • Mar 2012
              • 4734
              Would these copier / scanner / network-printer machines store the data, perhaps a spreadsheet or something, on the disk before doing whatever they did with the data? I really appreciate you guys providing information on this older technology for me. I was still in middle school back in 95. That was the year I started getting into Linux. Had no idea what a mainframe was or even a server, let alone a fundamental understanding of a file system. I just knew in Linux, we used ext2, in DOS, we used FAT16.
              • Spork Schivago
                • Mar 2012
                • 4734
                I'd scan an image, but right now, my wife's laptop is down. I'm using a customers PC. Jessica's hard drive should come tomorrow. Anyway, a little more info..on the disc, the metal part that slides open, has stuff printed on it:
                Code:
                [B]XEROX[/B]
                Formatted
                Micro Diskette
                Double Sided
                High Density
                Reorder No.
                [B]8R3827[/B]
                The paper that the person wrote on, it says:
                Code:
                7080 Pgh Inv.
                PittsShip 1995
                So it appears that Xerox actually shipped these discs, preformatted. Didn't they try to sell a home PC back in the day but failed miserably or something? It was very similar to another system, I want to say it was similar to a TSR-80 or something like that and not too many people where impressed. I highly doubt this could be from something really old like that though, being 1.44MB in size.
                • Forest79
                  by Forest79
                  However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                  07-23-2023, 07:39 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • hazem3636
                  need Bios Bin file Dell server 220
                  by hazem3636
                  hi everyone
                  i need dump file for dell server r220
                  i have download Flash BIOS executable file but i dont know how to conver it to Bin file
                  i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
                  if anyone has this method please need his supporting .
                  all the best
                  EXE file is attched and Original Bin file from the Bios Chip is attached also
                  and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
                  11-05-2022, 06:20 AM
                • Sebastian Codrean
                  BIOS file for ASUS F542UN laptop
                  by Sebastian Codrean
                  Hello to all of you! I need help with a BIOS file.
                  The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                  So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                  02-20-2025, 10:25 AM
                • maanee11
                  Help to get Lenovo BIOS bin file for Thinkpad T560
                  by maanee11
                  Hello Everyone,
                  I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                  https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                  In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                  05-15-2022, 11:59 AM
