Medion 5000 v1.2 Mobo (MS-6701) Mobo
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    This has a CPU with a HSF, and HSF cowling (plastic clip-on type)
    The HSF has the CPU welded to it - eek! Usually after use with the
    HSF still warm you can twist the CPU off the HSF (with a bit of persuasion if you do it right)
    But this CPU refuses to budge!
    I believe the HSF is specific to the mobo and a Medion design by virtue
    of the HSF retaining clips.
    The cowling is connected to a vent on the side of the case (by design)
    I would like to upgrade the CPU in this mobo to a s478 HT 3.0/3.2GHz
    It will have to be a Northwood 512k cache FSB 533
    Anyway,
    Suggestions as to how to remove the P4 already attached please?
    I would not like to destroy the CPU in place.
    Thx
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Medion 5000 v1.2 Mobo (MS-6701) Mobo
    Mount the CPU in a motherboard that has no retention bracket in place to get in your way then use a thin blade knife to slice off the heatsink.
    Keep the knife's edge slightly toward the heatsink so you don't scratch the CPU.
    Twist on the heatsink a little as you go and you can tell when it's starting to free.
    (I don't mean twist with like a pry bar, okay....)
    Kind scary but it usually works when there is no other way.
    It's usually best if the finger count before and after are the same.
    Mann-Made Global Warming.
    - Dr Seuss
    • JEWilson
      • Sep 2007
      • 369
      Thanks for that. I will give it a go.
      This thing is stuck tighter than a gnat's chuff!
      Dunno what heat cure or paste they must be using to get it solid as it is.
      Do you think it may be a phase change material (here's hoping) and
      becomes more maleable when heated or is just glue such as an epoxy?
      Epoxy does have good thermal properties but I have never known it
      used on a FRU such as a heatsink and CPU (for obvious reasons).
      Thanks anyway. Will let you know how I progress.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Without knowing what is in there I can't say about heat.
        Some kinds are brittle when cold and that can help too.
        With the kind that's brittle if you can get a crack started though it the crack will keep going, if you warm it up then it won't crack it will just flex like semi-hard glue.
        Think of how hard candy behaves.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          If it's really tough the place the jig-motherboard on a board and drill at least two holes in the board through the retention bracket holes.
          With the board aligned to the holes put screwdrivers through the board into the holes.
          [Might need another pair of hands next.]
          Use the shafts of the screwdrivers to keep the board from moving...
          .. and use one as leverage against the back of the knife.
          - Dr Seuss
          • gonzo0815
            • Feb 2006
            • 1600
            It is the usual phase change thermal pad, i would bring the cpu up to max temp by disabling the fan and running prime or hot cpu. Then it should be possible to disassemble with a little force.
            Apart from that, acetone or a sharp knife as mentioned will work too.
            • JEWilson
              • Sep 2007
              • 369
              Just a thought - What about using a hot air gun?
              I have one of these for use with sleeving and it can run hot (very).
              see for example - http://heatshrink.com/prod-steinel-hg.htm
              This has attachments for very localised use.
              Get the HSF hot and remove as with methods mentioned above?
              Or would this simply fry the CPU?
              • zandrax
                Hit and miss
                • Dec 2007
                • 1157
                • Italy
                Beware: cpu junction temps are around 80-85 °C, so if you heat a lot the cpu you can damage it even if is not operating.
                I'd try the PCBONEZ' knife approach: put the cpu into a socket and twist the heatsink. It requires some torque, so be gentle and try to move it slowly. OTOH, acetone may melt the termal compound enough to clean and twist it easily.
                Zandrax
                Have an happy life.
                • JEWilson
                  • Sep 2007
                  • 369
                  Ok - thanks for the insight
                  Will try the acetone approach first - less likely to cause damage - ermm...
                  Acetone is easy enough to come by
                  What of stronger stuff like MEK? Toxic by god but will strip anything!
                  see http://www.tapplastics.com/shop/product.php?pid=33
                  • zandrax
                    Hit and miss
                    • Dec 2007
                    • 1157
                    • Italy
                    Sorry: I never tried it.
                    The most dangerous chemical I used once is trichloro-ethylene, which is really toxic and it's still sold in Italy as a stain-remover called "Trielina". It melted easily an old Pentium 3 termal pad, but I felt a bit dizzy after using it, though I cleaned the heatsink on my house balcony during a windy day.
                    So I suggest to stick with acetone and isopropyl alcohol: they are safer for you and should remove the pad effectively.
                    Zandrax
                    Have an happy life.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      i heat the heatsink by blowing thru it with a heatgun.
                      once hot you can pry GENTLY on the area outside the heatspreader.
                      i remove any plastic parts to avoid melting them.
                      • JEWilson
                        • Sep 2007
                        • 369
                        I relented with this job as I was getting nowhere trying to
                        get the HSF removed.
                        As it was a 2600/512/400 Northwood, I simply moved the whole
                        HSF and duct to another mobo. It was bit tricky trying to get
                        the assembly to drop into the socket with the cpu socket
                        clip closed but a little persuasion got there in the end.
                        It works fine.
                        So now, I'll just get a CPU for the former board and try to
                        get a HSF with duct to the side panel as before.
                        As the case is small, it was there for a reason in the first instance.
                        Thanks for the help
                          ACER Predator Orion 5000-610 Predator Orion 5000 i7-8700K Specification for Upgrade or Repair
                          This specification for the ACER Predator Orion 5000-610 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 5000-610 boardview and Predator Orion 5000-610 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-12-2024, 03:28 PM
                          ACER Predator Orion 5000 PO5-610 Predator Orion 5000 i7-9700K Specification for Upgrade or Repair
                          This specification for the ACER Predator Orion 5000 PO5-610 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 5000 PO5-610 boardview and Predator Orion 5000 PO5-610 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          ACER Predator Orion 5000 PO5-610 Predator Orion 5000 i7-8700 Specification for Upgrade or Repair
                          ACER Predator Orion 5000-610 Predator Orion 5000 i5-8400 Specification for Upgrade or Repair
