Random Lockup Blues
  • omendata
    • Jun 2015
    • 25
    Re: Random Lockup Blues
    You first need to isolate hardware or software as another user said - Install an Ubuntu live cd and see how stable it is.
    If its hardware:-
    Have you checked your cpu temps and hdu smart?
    I use Acronis drive monitor and Speefan as they are free and being Scottish I am a bit of a tight arse.
    Burn a memtest cd - sounds like either faulty psu or more likely memory.
    Swap in the memory modules one at a time.
    Motherboard bad caps are less likely these days.
    You are only too old when you say you are too old!!!
      • 31283
      Originally posted by eccerr0r
      I thought Unicomp is now the official IBM Model M patentkeeper and official source for new keyboards and spare parts?
      I recently got an true blue 1986 Model M but it's missing a keycap. I might have to go buy one from Unicomp but not sure how I can tell them I want the "original" key (the printscreen key, which should have sysrq printed on the skirt and not the cap?)
      the mechanism changed over the years, you should look on ebay for some robbing bastard selling individual keycaps like they do for laptops.
      Unicorp is the owner, but i dont think the current model is backward compatable.
        • 31283
        make sure the harddrive is fully unplugged, infact if you have an ata dvd drive or can boot from a usb stick then that's preferable.
        sata can hang the system if you have a faulty drive or cable.
        i dont understand how - i'v seen it happen though.
        • mockingbird
          • Dec 2008
          • 5488
          Originally posted by Hondaman
          Gigabyte 970A-UD3
          The 870A-UD3 had a design flaw that would cause the board to exhibit very random untraceable memory errors that ultimately led to BSODs if the RAM were run at more than 1066Mhz. Took me months to figure it out. I needed the board specifically because it had a floppy port.
          Try lowering the RAM speed and see if that fixes your problem.
          • Hondaman
            • Sep 2008
            • 1092
            Thank you for your help, I may have fixed it. My CPU fan was twitching. That's right. Twitching every couple of seconds. It spun freely with fingers, so it wasn't seized. But apparently 12 volts was not enough to run it anymore. Electronics on board the fan probably malfunctioned. The CPU temp was 95 C at one point when I was in BIOS setup after a sudden shutdown. I took the cover off and put my hand between the CPU fan and the back of the case, and it was pretty darn warm. I think I forgot to hook up a speaker when I built the system, so BIOS overheat warnings did not sound. I'll put in a speaker this weekend.
            I'm using the original BARAM heatsink (from S. Korea, it comes fanless). When I built it, I put a 4-pin 12 cm Scythe fan on it because of good reviews. Just now, when I plugged a 3-pin Corsair 12cm fan into two different fan ports on the motherboard and hit the power switch, each time the Corsair came alive immediately. The Scythe only twitched on both fan ports.
            Let me tell you something: This is the first (AND LAST) Scythe product I will EVER buy. I saw the fan twitching some time ago, but I did not think anything of it. Did I damage the CPU or something in the VRM area? I hope not.
            As for a spare identical board and CPU (to keep my Windows 7 license), I may still get them (forget about that giant passive video card, I don't think you can get another one).
            I'll monitor temps from inside Win 7 and post again if there are troubles.
            EDIT: Thanks again for all of your help !
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              #26
              ^i've overclocked a lot of thing in my short lifetime. one was a 600mhz ARM CPU to 1.2ghz. It was on a phone. A huawei ascend ii to be exact. You are probably fine.
              Follow the white rabbit.
                • 31283
                i blame the motherboard maker.
                for years they have not bothered to fit the small buzzer on the board even though the space is always there for one.
                i always fit them.
                • TechGeek
                  Computer Geek
                  • Jan 2015
                  • 2254
                  ^^^I had a computer repair company literally STEAL the buzzer I paid for. I was pretty &%#!*&$ %%^##*. Note to self: Remove buzzer before professional maintenance.
                  Permanently Retired Systems:
                  Kooky and Kool Systems
                  sigpic
                  • rhomanski
                    nowhere man
                    • 5157
                    • U S of A
                    #29
                    I let a shop work on my car once and when I got it back no change in the holder. Guess they wanted a couple dozen soda's from the machine.
                    sigpicThe Sky Is Falling
                      • 31283
                      you should strip a car out before leaving it with a garage.
                      i know a few people who have lost cd's
                      on the bright side, one of them found a factory-service/alignment cd in the player when he got it back!!
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        #31
                        Might not have been put back in. Doubtful a professional person/company would steal a buzzer but they might use their own for diagnostics.
                          • 31283
                          more likely they replaced the board and the new one didnt have it.
                          • DynaxSC
                            GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                            by DynaxSC
                            I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                            General test conditions:
                            - Tested with Core i5 6500 and Core I7 6700K - no difference
                            - Default BIOS settings, but tried also altering several memory setting - does not change anything
                            What is wrong:
                            With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                            When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                            03-21-2025, 06:23 PM
                            Thermal pad thickness for various laptop GPU / Graphics Cards
                            ASUS Dual RTX 2070 OC 8GB
                            ASUS ROG STRIX RTX 3080 OC
                            ASUS ROG STRIX RTX 3090
                            ASUS TUF Gaming RTX 3080 OC Edition
                            ASUS TUF GTX 1660 S-O6G GAMING
                            EVGA RTX 3060 Ti XC GAMING 8GB
                            EVGA RTX 3060 XC GAMING 12GB GDDR6
                            EVGA RTX 3080 FTW3 ULTRA GAMING
                            EVGA RTX 3080 TI FTW3 ULTRA GAMING
                            EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                            Gainward RTX 2080 Phoenix GS Specs
                            Gainward RTX 3070 Phoenix 8GB
                            Gainward RTX 3080 Ti Phoenix
                            GIGABYTE AORUS RTX 3080 MASTER 10G
                            02-09-2024, 08:08 AM
                            A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                            by momaka
                            More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                            And a shot of the label:...
                            01-26-2022, 03:26 AM
                          • nikovmiroslav
                            Gigabyte A5 X1 Need Bios
                            by nikovmiroslav
                            Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                            Gigabyte A5 X1
                            From motherboard:
                            S/N: 1TNH55ER1350895
                            P/N: 6-77-NH55ERQY-D02-2CGB
                            On sticker from the back of the laptop:
                            S/N: SN21351J000657...
                            08-24-2025, 09:15 AM
                            Gigabyte G series G5 KF-5 Notebook Specification for Upgrade or Repair
                            This specification for the Gigabyte G series G5 KF-5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G5 KF-5 boardview and G5 KF-5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...
                            09-07-2024, 07:19 AM
