attack of the dustbunnies
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: attack of the dustbunnies
    Originally posted by PCBONEZ
    zandrax
    I used to work on gear for Nuclear plants.
    Approved methods there: (some)
    A brush. NOT plastic/nylon bristles. Had to be horse or hog hair. (Yeah, sounds funny)
    Not so funny: plastic can be charged and you should avoid any electrostatic spark. This is a judicious suggetion.
    Vacuum (Approved models were specified.)
    A 20+ years old vacuum, Vorwerk brand - the one I have.
    Compressed air set to 30 psi max.
    (We'd cheat and crank it up to around 60 cause 30 don't do much.)
    Hmmm ... I can try this option when I'll afford a decent compressor.
    BTW, can compressors ionize the air they blow?
    Isopropyl alcohol (90+%) (with a horse hair acid brush if needed for scrubbing PCB)
    Good cleaner and deoxidizer.
    Most of the other options release things into the environment and are illegal now.
    Before that we used to use TriChlorol-something-or-another fairly often.
    Acetone to remove stickers glue and termal compounds: only in open air because it's toxic. Beware: it melts most plastics and remove some pcb coating layers, so don't use on ICs and on any board.
    We would get 91% Isopropyl in 5 gallon cans so if something got drenched (there's water and steam pipes all over in a power plant) we could literally wash the boards in alcohol to dry out the water. (It works.)
    Thanks for the tip.
    I don't like compressed air on laptops unless I have them completely opened up.
    It can shove dust bunnies into tight spots inside and make matters worse.
    I did actually open the notebooks I cleaned (already out of warranty): I could clean their heatpipes only by blowing air inside them, clouds of dust came off untill I could see some light through them. Computers became a lot less noisy after the cleaning
    Zandrax
    Have an happy life.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      something like cramolin labeloff is better and not melting plastics. citrus based.
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        Thank you: I found the Label Off on the Itw site.
        Zandrax
        Have an happy life.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          As to: Ionization in compressed air:
          Never heard of that being a problem.
          I've painted cars, sand blasted, worked with air powered motors and cylinder.
          Never seen anything to indicate static on compressed air.
          I suppose if you were using some air hose made out of some unusual material it might be an issue, but Ive never seem or heard of it.
          A bigger problem with air is making sure there is no oil in it.
          Usually a problem with old or cheap compressors that leak oil past the rings.
          Also if the air hoses were ever used on an air mister for oiling air tools.
          I use a micro-filter type trap to catch any oil in the air. Also have a designated 'clean hose' that is another color from the hoses I connect to the mister and air tools.
          (Also use that one for painting cars, don't want oil in the line then either.)
          Mann-Made Global Warming.
          - Dr Seuss
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Isopropyl actually works pretty good for 'most' sticker goo too.
            Takes off wax pencil marks very well.
            If you work it a little with a tooth brush it will get some kinds of magic marker and ink pen ink off.
            - Dr Seuss
            • Spacedye69
              • Nov 2005
              • 698
              • US
              #26
              Yes ionization in compressed air is a consideration. I worked at a company that did vacuum coatings for the aerospace industry and and a customer that made sattelites came in and brought their own "anti static, deionizing" air nozzles. I don't think consumer electronics are up there with the Space Shuttle, many people use compressed air to blow dust. This customer was a freak. They would also measure coatings that were microns thick with a micrometer!
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                I've had to do that.
                What's even more fun is trying to measure surface roughness.
                We also had a couple of Faro Arms which has to be the coolest tool I've ever seen.
                http://www.faro.com/contentv2.aspx?c...tem=1018&ct=us
                It can measure the X,Y,Z axis of anything within 8 feet to +/-.0007 inch.
                It feeds the data into a CAD program in a laptop and creates a picture.
                If you wanted to you (and had a LONG time) could touch a car all over and make an EXACT 3D drawing of it on the computer.
                - You would even be able to zoom in and see a chip in your paint.
                - Dr Seuss
                • acstech
                  GrumpyModerator
                  • Jul 2007
                  • 1432
                  It wasn't Trichloroethylene was it? That stuff can be hazardous to your health! It's also used in brake cleaner, although it has been recently replaced with perchloroethylene. Still something I want to avoid. However, I do use it sparingly to clean off heatsinks and processors before applying thermal compound. It absorbs heatsink compound like a magnet and leaves no residue. You just have to be really careful with it, and put the rag ouside when done.
                  A man convinced against his will is of the same opinion still.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    I hate spelling those so I skipped it and I'm not gonna spell check.
                    And, ah, as I already said we stopped using it because it was hazardous.
                    There were several:
                    Trichloroethylene
                    Trichlorotrifloroethylene
                    Trichlorotriethylene
                    There were like a dozen approved for inside NUC plants back then.
                    Considering where I worked that was a pretty small hazardous compared to some of the other hazardous's we had going on.
                    - Dr Seuss
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      There is one of them (or out of the same family) that is still used inside the high pressure oxygen systems on submarines. It's used to remove every trace of hydrocarbons from inside the system after it's closed up. Even the oil in a finger print is to many hydrocarbon present when you press-up oxygen to 3000 or 4000 psi. There have been a few cases where hydrocarbons got missed and the Stainless Steel pipes (on the oxygen side) caught fire. (Yes, in 3000 psi O2 even SS will burn.)
                      They have come up with an alternate chemical and procedure that doesn't harm the ozone but it's MORE hazardous to people handling the stuff than the old stuff was.
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        This stuff "NOC"
                        http://p2library.nfesc.navy.mil/P2_O...k/3_V_B_4.html
                        They make is sound all safe in the DOC.
                        They leave out the fact that to use it: Temps 120f to 170F with agitation...
                        And that the non-liquid parts human body are mostly hydrocarbons.
                        This stuff is so nasty against hydrocarbons that if it touches part of your body that part of your body will be gone. There is NO time to get it off you.
                        (But the ozone layer will be just fine....)
                        - Dr Seuss
                        • starfury1
                          • May 2006
                          • 1256
                          #32
                          well I am told the recommend is vacuum it out with a vacuum thats designed for the job.
                          I am told compressed air blows crap into connectors sockets and chip pins etc.
                          me I use compressed air and haven't had a problem I know of
                          I am a bit careful with the first few hits to try and blow the dust away from things.
                          I've had a few like doods pass my way too...
                          think one of TC's willawake's or yantz posted here thats a real corker for dust
                          sorry dood makes yours pale in camparision.
                          but yours is a fine example of what we got to put up with
                          Cheers
                          You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            #33
                            this one?
                            https://www.badcaps.net/forum/showthread.php?t=1628
                            i would really like a vacuum designed for computers. the photocopy repair guy has one. usually i take things into the corridor outside the office and then vacuum up the remnants from the floor after using compressed air. if i was doing a lot of computer repair i would have one.....because compressed air cans are expensive.
                            • zandrax
                              Hit and miss
                              • Dec 2007
                              • 1157
                              • Italy
                              #34
                              @ willa:
                              Next time you see the photocopy guy do watch if he wears a dust-stop mask: toner dust is thought to be carcinogenic, so better do not breathe it.
                              I once entered a small stationer's crowed with copy machines: the room ceiling was dark gray, not due to mould or cigarette smoke because it was a dry room and nobody used to smoke inside. I could smell the dust
                              Fortunately I did only once because my favourite stationery shop was closed that day.
                              Zandrax
                              Have an happy life.
                                ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                                This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-06-2024, 10:50 PM
                                ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                                This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                09-06-2024, 11:05 AM
                                ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                                This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                                This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                This specification for the ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX461UN-E1042R-CASE boardview and UX461UN-E1042R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-06-2024, 07:07 AM
